Tip & How-To about Computers & Internet
What Can We Do Before and After Forgetting Windows Password?
BEFORE Forgetting Windows Password Disaster:
Do you think it is none of your business to do this right now? But we don't know what will happen in the future. Creating a password reset disk is the best way to prevent you into the forgotten windows password disaster. With it, you can easily reset your password and get right in to Windows.
With it, you don't ever have to worry about forgetting your password again.It's true that there are ways to recover Windows password without a password reset disk but they are often complicated and time consuming.
BEFORE creating a password reset disk you have to prepare these:
  1. a floppy disk drive.
  2. a blank floppy disk.
  3. A computer with Windows OS.
  4. Less than 5 minutes of time.
  5. A sober brain.
Let’s begin! I will take Windows XP for example. Other OS is very similar to do this.
1.Click on Start and then Control Panel.
2.Click on the User Accounts link.
Note: If you're viewing the Classic View of Control Panel, double-click on the User Accounts icon.
3.In the pick an account to change area of the User Accounts window, click on your Windows XP user name
4.In the Related Tasks area on the left, click the Prevent a forgotten password link.
5.When the Forgotten Password Wizard window appears, click Next
6.On the next screen, verify that a blank floppy disk is inserted in your floppy disk drive. Click Next to continue.
7.With the disk still in the drive, enter your current account password in the text box and click Next.
8.Windows XP will now create the password reset disk.
When the progress indicator shows 100% complete, click Next and then click Finish in the next window.
9.You can now remove the floppy disk from your computer.
Label the disk "Password Reset" and your “user name” and then store it in a safe place.
NOTE:
  1. You only need to create a password reset disk for your Windows XP logon password once. No matter how many times you change your password, this disk will always allow you to create a new one.
  2. While a password reset disk will certainly come in handy if you ever forget your password, keep in mind that anyone who possesses this disk will be able to access your account at any time, even if you change your password.
  3. All the user accounts have to make its OWN disk!
AFTER Forgetting Windows Password Disaster:
OK. I admit that this is the most important part. Because when you read this article, it is probable that you already forgot your important windows password. But this might help you ou!
1. Use the “Reset Disk”.
Windows XP and further versions also provide another method to recover forgotten password by using "Reset Disk". If you created a Password Reset Disk as above in past, you can use that disk to reset the password. To know more about it, please visit following links:
How to create and use a password reset disk for a computer in a domain in Windows XP
How to Log On to Windows XP If You Forget Your Password or Your Password Expires
2. Using Windows XP Setup CD
If the above mentioned tricks don't work, then try following trick which is actually a loophole in Windows XP Setup and a big security hole:
A. Boot using Windows XP Setup CD and follow the instruction like Accepting EULA, etc.
B. When it asks to repair your existing Windows installation, accept it and press "R" to run the repair.
C. Setup will start repairing your Windows and will start copying files, etc.
D. After a few minutes setup will restart your system and when it restarts don't press any key when it shows "Press any key to continue..." otherwise Setup will start from the beginning. Don't press any key and setup will resume where it left. E. Now it'll start doing other tasks and will show a small progress bar with a few details in left side.
F. Look carefully at the details and when it shows "Installing devices", press +F10 keys in your keyboard.
G. It'll open a Command Prompt window. Now type nusrmgr.cpl and press .
H. It'll open the same "User Accounts" window which you see in Control Panel.
I. Now you can remove or reset any account password without any problem.
3. Use NTFS DOS tool to restore
Difficulty:Difficult .
So if you are a computer newbie, it is better for you to choose other methods. Windows XP password First of all, downloads a "NTFS DOS" tool via which to create a bootable disk that can operate NTFS partition under DOS. After the DOS is started, switch to system directory, e.g. “C: Windows\System 32”. Change the name “Logon.scr” with “Logon.scr.bak”. Get a copy of “Command.com”, and rename it with “Logon.scr”, then reboot the computer. When the screensaver is activated, you will see that the screen is shown in command-line mode with administrator permission, with which to reset the password or create new administrator account. After you log onto Windows XP, rename the “Logon.scr.bak” back to “Logon.scr” will be OK. This method is applicable to the Windows XP installed on NTFS partition.
4. Try some recovery tools.
If you are not a computer technician, or not familiar with computer system operations, you may feel the above methods are scary and still can’t figure out what I am saying. Then you may try to use the software programs which may suit you.
The existing windows password recovery software are many. You can also refer to How to Recover and Reset Password in VistaXP/2003/2K/NT For Free.
Computers & Internet Logo
don't remember password
At one time , I had the experience with forgetting Windows password.
Finally I use Windows Password Reset.The program is easy to use.
Here I just list the simple steps:
Step 1: Download Windows Password Reset from http://www.windowspasswordreset.net
Step 2: Burn bootable CD/DVD or USB flash drive
Step 3: BIOS setting
Step 4: Reset Windows password
It's worth a try! Good luck~
Jul 18, 2012 | Dell Computers & Internet
Why Do You Need a Windows Password Recovery Tool?
another windows password recovery tool is recommended because of its simple manipulation and high quality. It would reset the lost password in any Windows system quickly. In my eyes, It's worth a try!
To remove Windows Passwords with Windows Password Recovery 6.0 only needs 3 steps!
Step 1 . Download and install Windows Password Recovery 6.0
Step 2 . Burn windows password recovery 6.0 to CD/DVD or USB Flash Drive
Step 3 . Reset your Windows password
Nov 10, 2010 | Computers & Internet
my son forgot his password in his acer aspire netbook how do we reset his password? we tried the reset bar and that didn't work. help
The experience forgot admin windows password happened to me few days ago. And I searched in the Internet to find the solution. Then I found a windows password reset tool called Windows Password Reset have a good evaluation.
I tried it as the steps:
Step1:Download and install Windows Password Reset
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in my newly created CD and remove my Windows Password.
It really great help to me reset windows admin password.
Hope it help your son too.
Nov 03, 2010 | Acer Aspire 5050-3242 Notebook
I need to know what my password is for quicken 99
Have You Lost Your Windows Admin Password?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Jan 29, 2009 | Intuit Quicken Deluxe 99 for Windows...
291 people viewed this tip
David Payne
David Payne
