Tip & How-To about Computers & Internet
Quad-Core and Eight-Core Mac Pros (2009 editions)
New Mac tower boosts performance despite speed drop
by Milind.S.Shetti
Though you wouldn’t know by looking at it, Apple’s new tower, the Mac Pro, has just received a major overhaul. The two tower models pack a brand-new processor and video system, and feature a reorganized internal design. However, they have lower clock speeds than their predecessors.
Product:
Mac Pro Quad-Core/2.66GHz
Rating (Scale) 5 - Superior
4 - Very Good
3 - Good
2 - Fair
1 - Poor
Pros
New Nehalem microprocessor; easier to upgrade internal components; lower price.
Cons
None significant.
Company
Apple
Price as rated $2,499
Best current price $2,388.00
Product:
Mac Pro Eight-Core/2.26GHz
4 - Very Good
3 - Good
2 - Fair
1 - Poor
Pros
Cons
Most routine apps perform better with fewer, faster processors.
Company
Apple
Price as rated $3,299
People who read this also read:
Last year’s standard Mac Pro () featured a 2.8GHz eight-core Intel Xeon processor based on the Harpertown/Penryn architecture. This year, there are two models: a quad-core system with a 2.66GHz Nehalem Xeon processor, and an eight-core model running two quad-core Xeon processors at 2.26GHz. Also new to the Mac Pros are Nvidia GeForce GT 120 graphics cards and a revamped interior designed to ease user access for upgrading internal components.
Similar but different
Aside from the second optical-drive slot on the front, the Mac Pro continues to use the same big-handled, aluminum case as the Power Mac G5, introduced nearly five years ago. There are some minor changes to the exterior, though—specifically in the type and number of connections. First, the two FireWire 400 connectors from previous generations have been replaced with backward-compatible FireWire 800 ports, bringing the number of FireWire ports to four—two on the front and two on the back. The five USB 2.0 ports, two on the front and three on the back, remain. On the graphics card, one of the two dual-link DVI connectors at the rear of the system has been replaced with a Mini DisplayPort connector, which lets you connect either to Apple’s 24-inch LED Cinema Display () or, with adapters (not included), to a second DVI display.
The new Mac Pros have been remodeled on the inside to provide for easier access to components.
Upon opening the case, you immediately notice major changes in the layout of the components. The memory modules are no longer installed on two sliding trays—instead, the memory and processor all rest on a sled at the bottom of the case, which you remove by releasing two latches. The quad-core Mac Pro has four memory slots that ship with 3GB, 6GB, or 8GB of 1,066MHz DDR3 SDRAM modules; the eight-core Mac Pro has eight DIMM slots for a maximum of 32GB of RAM. The memory design no longer requires the large heat sinks.
The Mac Pro still has four internal cable-free hard-drive slots, using a sliding tray to attach the drives directly to the motherboard. Now, though, the large plastic piece holding the fan near the front of the Mac Pro is much smaller, giving your fingers more room to grip the hard-drive sleds. This is a small but welcome change. I can’t tell you how many times I’ve struggled over the years to remove that first drive. Another nice design change helps ease the removal of PCI cards from the four full-size PCI Express 2.0 card slots. In the past, to remove a card, you’d first need to turn two large thumbscrews that held a small plate keeping the cards in place. Then you had to feel around behind the card, searching for a little plastic tab mounted on the motherboard, which you needed to lift up in order to release the card. With the new Mac Pro, that second step is much easier. You now simply push a single thin bar that extends across all the PCI Express 2.0 slots to release any or all cards. Apple has also made installation of its add-on Apple RAID card much easier: you just put it into the clearly marked top slot, and you’re ready to go.
Installed in the first PCI Express 2.0 slot is the new Nvidia GeForce GT 120 graphics card with 512MB of video RAM; the last generation of Mac Pros came standard with an ATI Radeon HD 2600 XT graphics card with 256MB of memory.
Computers & Internet Logo
my speed drop down
Well, there are quite a lot of causes for your running slow or freezing MacBook computer, if you prefer a quicker yet easier way to fix the performance issues, see here: http://www.speedupmacbook.com/
Jun 14, 2010 | Apple MacBook Pro PC Notebook
Hello I got a problem with MacPro 3.0. I have changed motherboard for new one, put every cables and everything in the place. The only thing that's changed is motherboard. When I connect Pro on Apple cinema display there is no pic. I hear dong and everything starts up. Btw Display is working, Graphic card is working, motherboard is new... Does anybody have clue? Thanks in front anyway.
How do you know the graphic card is working if you can't get a picture?
Sorry to be basic about this, but you really need to go back and check your connections again.
Do you have another Mac? You can boot the Mac Pro into target disk mode, then boot the other Mac off its disk using a FireWire cable. Then you can set up Apple Remote Management and enable VNC logins on that machine; then shut everything down and reboot the Mac Pro of its own drive. From the other Mac, use Chicken of the VNC to remotely view the Mac Pro's "screen" (I assume existence of an ethernet network here). Now you can run any tool on that Mac from the other Mac -- visit the Displays panel, look at System Profiler, etc., just as you would if the hardware display were working.
May 04, 2009 | Intel Mac Pro Tower Desktop
Mac Book Pro slow despite a clean install
Well, there might be a variety of reasons that can consequently cause the issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. Best regards!
Feb 25, 2008 | Apple MacBook Pro Laptop Computer with...
244 people viewed this tip
David Payne
David Payne
