Tip & How-To about Computers & Internet
Help for removing motherboard from laptop
Removing a motherboard from a laptop can be quite intimidating but it seems alot harder than it actually is.
The first time I attempted to do this I gave up after about10 screws I never even reached the internals. I needed to remove my motherboard so my friend could re-solder the power adapter. My adapter still work as long as I clamped the cord against my laptop but eventually that stopped working and I had to do the deed.
The second time I went in I drew a diagram actually I drew three of them and it was a life saver I highly recommend you do the same. Here's how:
Of course you will start at the bottom of your laptop draw a diagram of everything you see, make note of every screw (I drew circles with a sharpie) you see, draw the lines just as they appear even draw the label it will help. As you remove each screw tape the screw to the diagram that way you will know where every screw belongs. After you have removed all the outer screws make another diagram that indicates all the inner screws and tape them as you remove them. Only diagram and remove screws that are attaching the case to the mother board do not make note or remove the screws on the motherboard such as the screws on the fan or cpu etc.
You will now flip your laptop over and start on the keyboard. Every laptop is different you may have to remove a component around the hinges consult the manufactures website before hand. When you are ready to remove the keyboard do so the make another diagram indicating where the screws are then remove them and tape the as well.
When the time comes to reassemble you will have no trouble doing so.
Good Luck.
Computers & Internet Logo
how to replace door seal on fisher paykel front loader ?
ill start off by saying this is one of the hardest things you can do on a front loader alot harder than it looks alot of the time you need to remove the entire front half of the washer to get in there properly even then its still difficult with the right tools, if you still wish to attempt this i will need the model number so i can instruct you step by step
Sep 06, 2014 | Fisher and Paykel Washing Machines
smashed display
It is a little harder than removing a motherboard from a laptop. Since you have to go through 90% of the steps it takes to remove a motherboard but you also have to remove the screen. Look at a laptop screen and you will see various rubber posts beneath those are the screws you will have to remove.
If you have never removed a motherboard from a laptop I suggest you click on my user name and view a tip I wrote for removing a motherboard from a laptop.
Jan 06, 2010 | Acer Extensa 5620 Notebook PC
ibm t61 turns on but all I get is a blank black screen.
This sounds rather bad. You're not even getting a "thinkpad" screen?
Try unplugging the power and removing the battery for a minute and attempt to power up again.
If it's still not starting, try removing the memory modules (if there are two, remove one and try powering up, then try to remove the other one). Although I seem to remember that newer thinkpads will still show thinkpad logo and attempt to POST even with bad memory (then throw an error), it's always worth a try.
If the above don't make any difference then I'm afraid most probably your motherboard has failed. In theory you could also try swapping the cpu-I've seen a cpu go bad ONCE in my several years of tinkering with laptops.
T61 is a current model-wouldn't it still be under warranty from lenovo? Might be worth checking the serial on their website. Otherwise it's time to search for T61 donor laptops on ebay - ordering a new motherboard from lenovo parts suppliers will most probably be far too expensive.
Good luck, hope you get it working again!
Raf
Nov 09, 2009 | Lenovo ThinkPad T61 Notebook
Hi! thank you so much for the answer master vinodgill07 but unfortunately i already tried to removed the battery of the bios and even tried to ground it but still it wont work. my bios batt is actually not inserted and still before you can do anything you have to provide the password first...as in you cant do anything on my laptop. again my laptop is Toshiba satellite pro 4600
AH there you have it in a word its a TOSH these quite often require you to make a special plug that goes into the printer port You can buy the plugs at lots of places but you also need some soldering skills or a friend that can.
Here is the exact information you need
another source of information is here
between those you should be up and running in no time
If you found this information useful please click below
Aug 17, 2009 | Computers & Internet
can't get pass the blackscreen password
That is the BIOS password
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop. Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time. Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system
Aug 15, 2008 | Computers & Internet
207 people viewed this tip
David Payne
David Payne
