Tip & How-To about Heating & Cooling
How to make your heat pump more efficent
  • you should first change your filter ,this type of unit relies on good air flow
  • Find a HVAC supply house in your area (they all say there not open to the public but they are )
  • ask salesperson for outdoor coil cleaner this should be priced around $15
  • Mix according to manufacturers instructions into pump sprayer
  • Make sure unit is off @ thermostat not just temp satisfied
  • Remove enugh of outdoor units grill and fan to give you access to coil from inside spray coil with cleaner from outside wait about 5 minuit- and hose off cleaner from inside out( foaming should be normal)
  • Rinse thuroly and repeat as nessasary
Heating & Cooling Logo
my window unit is not blowing cold air
Hello, usually when a air conditioner does not ool it falls into two categories, airflow or low refrigerant charge. The first thing is check the air filter and make sure it is clean, if it is not was the filter with soap and water and let it dry. Tjen check the evaporator and clean it with some coil cleaner, ypu can purchase coil cleaner at a hvac supply house, and then spray it on the coil and let it dry. If this does not help then the unit is low on refrigerant and must be fixed by a hvac technician.
Apr 20, 2011 | Frigidaire Heating & Cooling
how to change air filter on a 2009 hyundai sonata
Hi there, here are a few steps to help you out:
  • Turn the Sonata off to eliminate the risk of engine backfires while changing the air filter. Leave the car off until the filter has been replaced or there is risk of injury.
  • Lift the hood of the Sonata. Locate the air filter housing unit on the passenger side of the car, in the front corner. Look for a black, plastic cylinder that has an accordion-type hose attached to it that leads to the engine.
  • Remove the air intake hose and air duct from the housing unit. Disconnect the connector for the air-flow sensor from the filter cover. Unclip the clip on the filter cover. Lift the cover off the housing unit.
  • Take out the old filter from the housing unit. Remove any remaining debris out of the air filter unit. Wipe the inner and outer surfaces of the housing unit with a damp cloth.
  • Place the new air filter in the housing unit. Use a K&N air filter, part number 33-2346.
  • Replace the cover on the housing unit and clip it in place. Reattach the air-flow sensor. Put the air intake hose and air duct back in place on the housing unit.
Best of luck....
Jan 13, 2011 | 2009 Hyundai Sonata
changing cab filter in 200 ford f150
If you are talking about the cabin air filter, this filters the outside air for the HVAC.
Hastings Filter (#AF1057) shows one for the 97-03 MY trucks.
Remove the screws that hold the horizontal filter housing cover from behind the glove box (no need to open the glove box);
Pull the cabin filter straight down (sits vertical behind the glove box inside the housing).
Install replacement and reattach the cover.
Sep 18, 2010 | 2000 Ford F150 Flareside SuperCab
where i can found the ac filter, bacause i want to replace. tnks
AIR FILTER
DESCRIPTION
A dust and odor air filter is standard equipment on
models equipped with the three zone temperature
control systems. The filter element is the
same size as the front air conditioner evaporator to
ensure ample filtering capacity. A removable door on
the bottom of the front HVAC housing below the
glove box provides easy access to the filter element
for replacement. The filter should be checked and
replaced at least once every 24,000 km (15,000 miles)
and checked if heater-A/C system performance seems
lower than expected.
REMOVAL
(1) Locate the air filter door on the bottom of the
lower HVAC housing just outboard of the passenger
side of the instrument panel center stack.
(2) Slide the air filter door latch toward the rear of
the vehicle until it engages the opened stop on the
door.
(3) Pull the air filter door straight downward to
disengage it from the air filter opening of the lower
HVAC housing.
(4) Use your fingers to reach through the air filter
opening of the lower HVAC housing far enough to
grasp the air filter.
(5) Pull the air filter straight down and out of the
HVAC housing.
INSTALLATION
(1) Note the “Airflow” directional arrow imprinted
on the foam seal around the frame of the air filter.
This arrow should always be oriented towards the
center of the vehicle.
(2) With the air filter “Airflow” arrow properly oriented,
carefully slide the filter fully upward into the
HVAC housing through the air filter opening.
(3) With the latch still positioned against its
opened stop, reinstall the air filter door onto the
lower HVAC housing air filter opening.
(4) Slide the air filter door latch toward the front
of the vehicle until it hits the closed stop on the door.
Good luck
Dec 22, 2009 | 2004 Dodge Caravan
Copeland A/C compressor Phase monator
Are you good with wiring?? you can use replacement monitors is there a supply house in your area? just purchase replacement ones they have instructions on wiring them up. if you need any more help with the units just email me at hvac.tech7872pr@gmail.com
May 04, 2008 | Heating & Cooling
117 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
