Tip & How-To about Heating & Cooling
Burner Ignites and goes out - Gas Furnace Problem
If you have a gas furnace and have seen it lighting and going out time after time before it finally locks out, then you know the frustrations of wondering what the problem could be.
Heat is there, it is in your sight, you can feel it for a few seconds and then, puff, it goes out and all you know is that the house is getting colder by the minute!
What are some of the problems that can cause this to happen…
  1. There is a problem with the venting of the furnace.
    1. Water in the flue pipe.
    2. Bee’s nests, rodents and other critters getting stuck in the flue pipe.
    3. Objects getting sucked into the intake pipe such as plastic bags, dandelion, and yes children hiding Easter eggs…
  2. The flame sensor is dirty or moved so that it does not touch the flame.
  3. The pressure switch has just plain gone wacko…does not close anymore.
  4. Circuit board failure, the flame is lighting, sensing, but the control board still thinks not and shuts the gas valve off.
Now how do you know what is the problem with YOUR furnace? The process of elimination in most cases is the best method to determine what is going on.
  1. Check both the intake (if you have one) and exhaust pipes carefully! Believe me this can be challenging sometimes! Finding problems can be very time consuming. Listen for water in the pipes. Take each one off at the furnace for a short time and see if it runs with them off. Do NOT leave the exhaust off for more than a short period of time!! Carbon Monoxide will kill you!
  2. Remove the flame sensor and clean gently with a bit of cloth or scrub lightly with steel wool. Do not use rough abrasives or sand paper.
  3. Checking the pressure switch can be tricky. If you do not find any other problems you can jumper the wires of the pressure switch AFTER the vent motor has started and then see if the furnace stays burning. You can not leave them jumper because the circuit to the wires needs to be opened after each cycle of the furnace for it to retry for ignition again.
  4. If all else fails it may be the circuit board. They can and do go bad, but make SURE that you are positive that it is the problem before getting another one. They are a bit pricey and they are YOURS after you purchase it. They are not returnable in most cases.
This will give you guidelines that will get you going in most cases, if you have flame for a bit and then it goes out. If you are experiencing no flame at all it still could be some of these possibilities. There may also be some other possibilities that will take a trained professional to figure out.
http://www.fixya.com/support/r4015846-furnace_ignitor_care_home_furnace
http://www.fixya.com/support/r3583678-hot_air_furnace__how_to_troubleshoot_the
http://www.fixya.com/support/r4016017-find_air_conditioning_heating_furnace
http://www.fixya.com/support/r3583636-home_heating_furnace_repair___how_do_you
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
Heating & Cooling Logo
Hot air furnace doesn't start gas burning.
ive seen this plenty of times , the sensor that tells gas valve that igniter is hot and ready to light the flame is bad , the parts places call them thermocouples , although I doubt they still are this
Sep 27, 2016 | Heating & Cooling
York Diamond 90 furnace blows cold air
There maybe a few issues. They have multiple safeties on furnaces. With this in mind this process to find the problem would take a Technician to check these safeties. It could be a flame sensor or thermocoupler each senses a flame or heat to keep the gas going. Also the damper for the flue must open for the gas to stay on. There may be more safeties on this and each safety sends a 24 volt current back to control module in order for the gas valve to stay open. If these aren't being met it will try around three times and go into a lock out mode which will keep gas shut off entirely.
Feb 21, 2012 | Heating & Cooling
HSI ignitor is glowing red but furnace isn't lighting every time
most likely the gas vavle only buy honeywell valve the rest are junk
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
York high effenciency furnace not firing all the time
has anyone worked on this furnace because the error would indicate that the positive 120 volt and the neg 120 volt is swapped , these units will also do this when the ground wire to the furnace or gas valve or furnace or @ the panel is lose , corroded , or missing , the gnd must be present to open valve , I am aware that ac is is not usually polarity sensitive but in this case it most certainly is ...have seen many time and know it to be true
Dec 27, 2008 | York Yankees Bedding MLB Comforter
dayton gas furnace
try cleaning the flame sensor and the burner , check out the pressure switch might be blocked in the tubes
Dec 07, 2008 | Dayton Gas Furnace Heater
7,212 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
