Tip & How-To about Washing Machines
How to manually unlock a Whirlpool duet washer
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼” or until a click is heard.
6. The door may now be opened.
Washing Machines Logo
i have a bosch front load washer and i am getting a code e 13
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To manually unlock the door lock system, perform the following steps:
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
May 08, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
e04 error - machine won't restart and door remains locked
Pl give me a ‘very helpful’ rating for the free help, thanks!
May 07, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
E13 error- can't unlock the door
Apr 08, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
door locked
To manually unlock the door lock system, perform the following steps. Power off the mains.
Mar 19, 2009 | GE Washing Machines
unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
432 people viewed this tip
Top Washing Machines Experts
