Tip & How-To about Computers & Internet
Significantly Speed up computer boot-up
There are many ways to speed up your boot on your computer. I will show you the best ways that will get you the best possible difference. NOTICE: Some tips will work on XP only. A few will work for vista, but not recommended you try it unless you know what you're doing.
1) Process idle tasks
Perhaps the most significant way to speed up your boot and overall computer speed is process idle tasks. On your computer, click start, then run (Or windows key and R), Then paste this command into the box:
rundll32.exe advapi32.dll, ProcessIdleTasks
Let it run, sometimes it takes 10 seconds, other times it takes 10 min. It varies on computer.
2) Disable startup programs
Programs start on boot-up by default, some you may not even want, and it will bog down the computer. Heres how you disable the ones you don't want.
go to the Start -> Run
Type msconfig and press Enter.
Under the Startup tab you will see all the programs that load on boot. If you are unsure what to disable, leave a comment with the question.
3) Disable unnecessary visual effects
Click Start, right click my computer, properties, then advanced tab
Under the section labelled "Performance", click the Settings button to open the Performance Options window. In the "Visual Effects" tab, uncheck everything but the last 3 boxes.
With these 3 major tips, you will see that XP will be much faster and more responsive. For more tips, feel free to drop a comment.
Computers & Internet Logo
HOW TO IMPROVE THE SPEED IN WIN7
The best way to speed up W7 is to install an SSD (Solid State Drive), such as one of these drives:
http://www.compusa.com/applications/category/category_tlc.asp?CatId=5298&name=Internal-Solid-State-Hard-Drives&
While they are expensive, you will_not_ regret the investment. To save $, you don't need to purchase a large SSD drive. Put W7 on a small capacity SSD (commonly referred too as a boot drive) and then use a regular hard drive (your old one) for mass storage. For example, on my computer, I use a 40GB SSD for W7 (C:) and a regular 500GB hard drive (D:) for music, videos, large downloads, pics, etc.
There are also a plethora of websites that will show you how to speed up W7. Here is one:
http://www.computingunleashed.com/speed-up-windows-7-ultimate-guide-to.html
Another way to speed up W7 is to install more memory, but you won't get near the noticeable performance increase as an SSD. In fact, after installing an SSD, if you try to enable ready boost on a flash drive W7 will tell you that it is not neccessary because you already have an SSD that is faster.
Feb 06, 2011 | Computers & Internet
corrupted user32.dll. boots to a blue screen,
You can try to do a system restore using the system recovery.
There are different ways for doing a system recovery on XP computers and on Vista or Windows 7 computer.
Assuming you are using Windows Vista
On boot press the F11 key repeatedly, When you reach the Recovery manager screen select Advance options.
Select the option do restore the computer to an earlier time.
It will show you the restore points
Select the best restore point and try to do a restore
If system restore does not work then you will have to follow the same steps to perform a system recovery by selecting the option to restore the computer to its original factory condition.
Jul 21, 2010 | HP Compaq nc6220 Notebook
320gb sata11 is not seen by bios
I have you tired using a different SATA connector or even SATA power connector, try and see if this helps...
Jun 12, 2009 | Computers & Internet
during slow, steady acceleration, car feels like it is hesitating
That was just a generic answer I do not know your particular car. Back in the day we put oil around the intake gaskets and if the engine  speed increased or steaded we knew that we had found it. I also could be other things.  Have you tried Carb/injector cleaner in with the gasoline? A vacuum leak could be too small to show on a vacuum gage but a person could look for or at least confirm a leak with the gage. Sorry I can not be of more help.
Jan 10, 2009 | 2006 BMW 545i
158 people viewed this tip
David Payne
David Payne
