Tip & How-To about Heating & Cooling
Hot Water Steam Efficiency Plus Comfort
Steam heat is a great warm, wonderful, and absolutely fabulous way to heat your house. Steam heat is almost always created from water in a boiler fueled by gas, oil or electricity. It then passes through pipes and radiators or convectors to heat your home. A steam heating system uses steam that is generated from a boiler. When the water boils, the steam rises through the pipes and into the radiators to heat them. The hot radiators then heat your home.
Steam is a great heat distribution medium because it moves easily through your system and it has an extremely high heat-holding capacity. The heat-holding capacity of steam is much greater than that of water. Steam heating systems often operate at very low pressures and usually under 220°F. Steam heat is usually distributed by either one or two pipe systems. In a case of a one-pipe steam heating system, a single main serves the dual purpose of supplying steam to the heat exchanger and allowing condensate to run back from the radiators also. A two-pipe system has two connections from each heat exchanger or radiator. In this system, steam and condensate flow in separate piping from each other. With a steam system all pipes must be well insulated and you must use pipe insulation rated for steam piping. If the insulation is removed the system will no longer work as designed. Noise and all sorts of problems will come from uninsulated piping.
When you have radiators on upper floors or radiators that are further from the boiler they should be adjusted to release more air to compensate for the increased air volume in the piping due to the distance from the boiler. If you have a valve that is clogged with mineral deposits or stuck shut, no air will be able to get out of the piping. Because of this no steam can enter the radiator, so it doesn't heat up. This will block the movement of steam into the radiator, or cause a very noisy hammering as pressurized steam tries to get through this water "dam".
Steam radiators need to have a valve that allows air to escape at a controlled rate so that the radiator can heat up. Steam heating systems will also lose a little bit of water all the time, so there has to be water makeup so that you do not run your boiler dry. Steam heating systems without an automatic water feeder are not safe. You will risk serious boiler damage should boiler water be lost. If the boiler runs dry it could also explode if water is placed into it while it is hot. There should always be a low water cutoff installed on every steam system. Therefore on a steam boiler the automatic water feeder serves as a safety device also.
It is very important that you find someone that is very familiar with steam heating systems when repairing or installing steam heating. Incorrectly designed, installed, steam systems and condensate piping is a huge problem in today's buildings and facilities. There are not many qualified to design and install properly operating steam heating systems. Incorrect steam piping will always cause costly premature failure of steam equipment such as steam coils, heat exchangers, and control valves. Not to mention the higher cost of operating a system that is not working efficiently.
http://www.fixya.com/support/r3904286-steam_system_steam_radiator_air
http://www.fixya.com/support/r4008078-differences_between_steam_hot_water
Heating & Cooling Logo
It's that danged power outage. Creates havoc every time and I can't always figure out how I get it to heat back up. Unplugging, plugging in, starting with the steam valve open for no less than 10 seconds does not seem to work. Any better ideas? Thanks.
Hi Any time you turn on your machine, always open the steam knob and make sure that you have a full boiler by having water come out of the wand when you turn on the pump switch. Until you have water coming out your boiler is not full. If its not full maybe the heating element has nothing to heat. This is how heating elements get damaged. They will heat until they blow, then you will never have heat. Make sure that you have water in the boiler, please. If it still doesn't heat, your thermostat may have tripped or your thermal fuse might have blown, or your board is shot. Now if your talking about the GFCI in the wall, there is a reset button on the GFCI that controls the outlet your machine is plugged into, or should be. Make sure that you have power to your outlet.
Jun 11, 2011 | FrancisFrancis! X1 - Stainless Steel...
amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
233 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
