Tip & How-To about Optics
You Just Bought an EQUATORIAL Telescope Mount!
Even though we warned you not to do this, you bought one anyway! Beginners should never buy an EQ telescope mount as their first telescope. It's too late now; so I guess we will need to teach you how to use it!
Equatorial mounts move in a way that seems not to very intuitive. Unlike the easy Alt AZ mount which moves up and down and left and right, the EQ mounted telescope seems to move in TWO dissimilar directions at the same time.
Additionally you must first polar align the mount on the North star Polaris before you can use it. SEE! we told you not to buy it!
Here are the steps to roughly polar align the telescope so you can use it. If it is motorized the single Right Ascension motor will keep the sky object inside the eyepiece for long periods of time. If you do not have a Right Ascension motor, the slow motion RA knob can be slowly turned to keep the sky object centered in the eyepiece.
Begin by leveling the mount and tripod. Move the entire mount and tripod so it is pointing roughly to North, as close as possible using the steps below or a compass. Don't forget to adjust for your magnetic deviation. My location's compass reading is about 5 degrees away from true North. This is called magnetic deviation. You can find your location's deviation on the internet. Then proceed with the steps below.
First, adjust the Declination to the latitude for your observing site. Declination is the angle that the scope is pointing UP, and it's the same as your latitude. For example Dallas, Texas is about 32 degrees North latitude, adjust the scope so the small indicator reads 32 degrees. By the way, the North star in Dallas, TX is about 32 degrees above the horizon. Your latitude matches the elevation of Polaris (the North star) above the horizon.
Second, either look through the polar alignment scope buried in the axis of the telescope mount, or look along side the axis, and get the star Polaris lined up in the cross-hair of the polar alignment scope, or as best you can by looking along the side of the mount axis, or lining it up using your compass.. This will put the scope to within about 3/4 of 1 degree of the TRUE North celestial sphere. This is good enough for VISUAL observation, but NOT good enough to do astro-photography..
Adjust the DECLINATION up or down, and move the entire mount left or right until you can see Polaris as indicated above, or it is lined up as close as possible.
Now you are roughly polar aligned. Now you can move the tube around by loosening the Right Ascension lock, and or the Declination lock until your sky object appears in the small finder scope mounted on top of the main telescope tube.(DO NOT MOVE THE MOUNT, and the counter weight should never be higher than the telescope tube) Lock down the scope in both axis and use the fine adjustment RA and DEC knobs to center the target. Again, DO NOT move the mount or tripod. The mount should still be pointing at Polaris.
This web site illustrates this procedure:
http://www.astronomy.net/articles/4/polaralign.html
also this web site
http://www.telescopes.com/telescopes/polaralignmentarticle.cfm
You should be able to keep an object within the field of view of the eyepiece by slowing turning the Right Ascension slow motion control knob-------- IF you are actually accurately polar aligned. Small adjustments may also be needed with the DEC slow motion knob since you are not exactly polar aligned using this rough alignment technique.
However it can be used successfully for visual observation. Your scope will now track the motion of the stars as they move across the sky.
Hope that helps you!
Clear Skies!
TelescopeMan
www.telescopeman.tumblr.com
Optics Logo
how do i set up a tasco telescope
Here is the manual:
http://www.tasco.com/products/manuals/46060675_TML-722.pdf
This is a very small refractor on an equatorial mount. The mount must be POLAR aligned before you can use it. We NEVER recommend this to a beginner.
However you bought one anyway! SO--- go to my profile page and read my TIPS on polar aligning an EQ mount. Several of the other TIPS will help you.
Also read this:
http://www.texasastro.org/telescope.php
and this about polar aligning an EQ mount-
http://www.astro-tom.com/tips_and_advice/precision_polar_alignment.htm
Aug 21, 2010 | Tasco Astronomical 302675 Telescope
302003 tasco manual needed
Yes, there is already a link posted on Fixya-
Here:
http://www.flickr.com/photos/7788977@N08/sets/72157610357951752/
This appears to be a small 60mm refractor style telescope on an equatorial mount. The mount must be polar aligned in order to use it properly. Beginners should never buy an EQ mounted telescope as their first telescope.
However I have instructions on aligning the mount on the star Polaris on my profile page in the TIPS section. Read those instructions, and find a local Astronomy club. The members can help you with that telescope.
Jun 26, 2010 | Tasco Astronomical 302675 Telescope
How do I use the Celestron powerseeker 80eq 21048?
If you will go to my profile page I have a TIP and instructions for using an equatorial mount.
This mount must be polar aligned before you can use it. That's why we never recommend an EQ mount for beginners. EQ mounts are very good for astro-photography however the low cost ones are too shaky to use. Normally you need to spend at least $500-$1500 to buy a usable EQ mount that can be used to take pictures of the sky.
Read my EQ Tip on my profile page, and read the link below:
http://www.texasastro.org/mounts.php
Apr 11, 2010 | Celestron PowerSeeker 80EQ Refractor...
no images
Put the eyepiece with the largest number written on it into the telescope. Do not use the 2x barlow if you have one. Practice focusing on a distant object during the day time. At night the moon show be your first target.
Sky objects are very small, many are also very dim. The scope has to be pointed directly at them to see anything.
The end with the eyepiece is POINTED UP by the way. The mirror is in the bottom of the tube. Read my TIPS on my profile page for additional help. Also this is an EQ mounted telescope. It must be polar aligned in order to work properly.
We never recommend EQ mounted telescopes to beginners.
Jan 11, 2010 | Celestron PowerSeeker 114 EQ Telescope
541 people viewed this tip
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
