Tip & How-To about Ovens
Thermadore 301/302 wall oven repair manual
All of my tips have been tampered with. I deeply regret I must remove the content from these tips. I will not write another tip for fear of further tampering of my literature. If you have any questions I am on facebook.
JW Webster
Ovens Logo
Need a manual
J Evans google search your make,model #,manual. or Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://outlet.whirlpool.com/digitalassets/CWE5800ACS/Use%20and%20Care_EN.pdf
oven manual Google Search
Owner Manual Installation Instructions
http://www.sears.ca/content/free-standing-stoves
Apr 18, 2016 | Ovens
Burner heads on my oven constantly spark. Think I need to replace electronic spark module in oven. No one can tell me how to get to this oart and what I have to remove to find it. All I get is copies of manual. PLEASE HELP. waiting your reply
It is not the spark module and the part you need is usually found right behind the burner knobs...
here is a tip that I wrote that will explain this further...
Gas Range RepairBurners Keep on Clicking
heatman101
Oct 02, 2010 | Maytag Ovens
F7 error
I am assuming you have two sections to the ribbon cable and a plastic touch panel. Try cleaning the area between ribbons in the area of the slot in the touch panel. Use alcohol and a Q tip. Let it dry. Try forcing the business card further down into between the ribbon cables. If you have a metal touch panel, you need to apply insulation between the ribbon cable and the edge of the slot. Refer to my instructions at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
If this doesn't help, you have a short in the touchpanel at some other location and my fix can't reach it. You will need a need touchpanel.
Jul 05, 2008 | GE Profile JTP18 Electric Single Oven
2,635 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
