Tip & How-To about Video Game Consoles & Games
Playing PS2 Games on a PS3 - Check Backwards Compatibility
Not all PS3 consoles have the capability to play PS2 games. Sony have removed PS2 compatibility altogether from the new PS3 slim and the later version PS3s only have limited capability to play PS One games.
This Tip is written to help you determine if your console is backward compatible for PS2 games.
First locate the model number of your PlayStation 3 system by finding the bar code sticker at the back of the console. Underneath the bar code you will see the 11-digit serial number followed by the model number which begins with "CECH".
Models that have PS2 game compatibility are first generation consoles and the versions are 80GB, 60GB and 20GB. These PS2 compatible consoles will all have 4 USB ports which is another useful identifier.
See below for a breakdown of the model numbers that are compatible with running PS2 games;
1) Model No: CECHE01 - These are 80 GB models with 4 USB ports. (Please note 80GB models with 2 USB ports are not compatible).
2) Model No: CECHA01 60 GB models
3) Model No: CECHB01 20 GB models
Another important factor here is the PS2 games themselves.
Even if you have one of these consoles, a PS2 game may run fine on one version say the 60GB but may not work on the 80GB.
If you have identified that you have one of these consoles and want to check if a particular game is compatible with it use the link below. You can enter the exact console you are using - then enter the PS2 game you want to play;
http://www.us.playstation.com/Support/CompatibleStatus
This will give a definitive answer on compatibility between a particular PS2 game you want to play and the actual console you have.
I do hope this Tip has clarified the issues for you.
Please help by registering your vote using the buttons below and many thanks for using FixYa.
Video Game Consoles & Games Logo
i thought playstations are all formated to play any made of equal or lesser p.s. value such as p.s.3. should play p.s.2. games
I believe you're asking about backwards compatibility. While I agree a PS3 should be able to play PS2 games, it's sadly not always the case. While they all can play PS1 games, not every PS3 can play PS2 games. PS2 compatibility depends on the model.
Backwards compatibility with PS2 games has slowly been phased out. The original PS3's had hardware emulation (quite literally there is a PS2 inside of your PS3). The later revisions had software emulation only (PS3 processor pretends to be the PS2 processor), and then none at all. No slim PS3 has backwards compatibility.
Hardware emulation:
20 GB PS3 Fat/Original - Model CECHB01
60 GB PS3 Fat/Original - Model CECHA01
Software emulation:
80 GB PS3 Fat/Original - Model CECHE01
In my personal experience, there's no real difference between software and hardware emulation in terms of actual game play. Software emulation has a few hang-ups on some older games, but overall it works pretty well. And it's infinitely better than not having any ability to play PS2 games at all.
Links!
Wikipedia
Hardcoreware.net - Comparison Table
Sony - check compatibility of games with PS3
Hope that helps!
Sep 30, 2011 | Sony Playstation 3 (PS3) Console
how to play play ps2 games on your ps3
You can only play PS2 games on your PS3 if it is backwords compatible, and the easy way to find out is to see how many USB Ports are in front of the console. If you have 2 USB Ports, no go. If you have 4 USB Ports in front, it is backwords compatiable. Another easy way to find out is if you own a fat PS3 with 4USB Ports you are good to go, just pop the CD in and it will play. If you own a slim PS3, you are out of luck, when Sony intoduced the slim ps3, to save money, they removed the backwords compatible chip from the hardware inside.
Aug 20, 2011 | Sony PlayStation 3 (120 GB) Black Console
Have a ps3 120 slim. is there any way to play ps2 games?
Yes of course, thats what tops the ps3 i believe, go to game, memory card utility (ps/ps2), create new internal memory card, choose ps2, name it, ok, then put in ps2 game and it will act like a ps2! Regards
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
can ps2 games be played on ps3
on the first ps3s but not now......im not sure bout the slim......mine plays ps1 2 3
Nov 11, 2009 | Sony PlayStation® 3 (60 GB) Console
can you play PS2 games on a PS3?
If you bought the original PS3 when it first came out and purchased the expensive one with the larger hard drive, it will be able to play *some* PS2 games. If you bought the cheaper one with the smaller hard drive or purchased your PS3 once the prices started dropping, it will have no capabilities of playing PS2 games, as Sony has decided to not continue making the system semi-backwards-compatible.
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
3,807 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
