Tip & How-To about Computers & Internet
Windows 7 Upgrade Considerations
Depending on the version of Windows you're currently running, installing Windows 7 on your PC may be a lengthy process. Run Windows 7 Upgrade Advisor to make sure your PC can run Windows 7, and then review the information below prior to buying or installing Windows 7 on your PC.
Use this chart to determine whether you should do an upgrade or custom (clean) installation.
http://www.microsoft.com/windows/windows-7/get/upgrade-considerations.aspx
Computers & Internet Logo
i want to upgrade winxp to vista online how can i do that?
Hi ,
Unfortunately , there are no secure sources where you could upgrade from , not even at Microsoft's .
You need to buy the install disc in an officially recognized shop .
best regards .
Feb 12, 2011 | Computers & Internet
How to install windows 7?
Insert the cd boot from cd and follow the given instructions
Jul 26, 2010 | Acer Aspire One PC Notebook
I installed Windows 7 on a laptop (HP DV2000) now the it give problems to come on, I tried over and over finaly i got Windows Vista 32bit on it, but it still giving the same problem, what can i do or how can the problem be corrected
Windows 7 is designed for latest hardware and the Laptop you are using is quite an old. We will face compatibility issues.
I suggest you to run a Compatibility Advisor to know which Windows 7 version is compatible for your Notebook.
Advisor Tool
http://www.microsoft.com/windows/windows-7/upgrade-advisor.aspx
Install the suggested version using an upgrade Disk. If you use retail version, you will face the driver compatibility issues.
All windows 7 driver will not available. But, you can use Vista driver for Windows 7 if it is installed using an upgrade disk
Jul 24, 2010 | HP Pavilion dv2000t Notebook
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
windows 7
go to microsoft .com and do a compadibility check
Nov 24, 2009 | E-Machines eMachines Desktop PC
285 people viewed this tip
David Payne
David Payne
