Tip & How-To about Computers & Internet
7 tips we've learned in setting up and using our team Web site.
In this article, I'm going to give you 7 tips we've learned in setting up and using our team Web site. These tips can help you get up and running productively as quickly as possible with your site.
Note: Windows SharePoint Services is a great, and underused, tool for managing teams and team projects. You can use it to create a team Web site to track objectives and projects, as well as have a central location for storing and collaborating on documents.
Example of a team Web site created with Windows SharePoint Services.
1. Create folder names that are clear and consistent
Organize site folders by whatever makes the most sense for your team. The key is to be clear and, above all, consistent. For example you could choose to organize:
* By department
* By objective
* Alphabetically
* By clients
* By project
We also create a new Document Library folder in SharePoint for each project. We can store all of our files related to a project in a Document Library. This not only helps keep our files organized, but makes it easier if a project is reassigned for the new owner to take ownership of all the associated materials.
2. Develop standards for naming files
Decide as a team how you want to name your files. For example, you can insist that a date be attached to each file, or that the person who created the file put their initials in the file name. Also, you can take advantage of the fact that you can use long file names for files and SharePoint folders. Be sure to publish your naming structure so that everyone on the team knows what it is. Above all, be consistent in reinforcing and using this naming convention. This is critical. We’ve found that if you don’t, your team won’t know how find files and therefore won’t use the site effectively.
3. Keep only the latest versions of files
Develop an archive folder system for keeping previous versions of files for historical or version control needs. We keep only one current version in our “active” folders. This clears up any possible confusion over which version of a document should be used, particularly when your team members download files to their computer to work on while they're traveling or working out of their office.
If your team members do copy files onto their computers, you need to take extra precautions to ensure you only have the most current versions of their files on the team Web site. If team members keep versions of files on their computer, they should change the file name. That way, if they upload the file at a later date, they will not overwrite something on the team Web site that might have been edited in the meantime.
4. Give clear ownership of each section of the team Web site
Give each folder a single owner who can add files to it. We find that this ensures the integrity of naming and file structures within each section of the team Web site. Multiple people may edit documents in various folders, but we make sure no one else uploads new documents or creates new folders inside a folder owned by someone else.
5. Check out and check in files
You will probably have a number of files (like sales data) that are accessed and edited by several team members. While SharePoint won’t allow multiple people to save an open file, it is possible for a person to open a file while someone else is editing it. Unless the file is checked out, you run the risk of more than one person working on the same file. One or more people may end up doing work that can't be properly saved. And if a user doesn’t check the file back in, then others can’t access it. Learn how to:
Make sure you check out files on your team Web site before working on them.
6. Clearly describe folder contents
As people on the team change, they will need to know what they can expect to find in different Document Library folders. Because we include a clear description of each folder, the new team member knows what's in each folder and can find the documents they need to get up to speed a lot faster. This has been really useful to us when an account grows large enough that we add another consultant to the team. We also modify the descriptions when we complete a project. We designate the library as containing archive information rather than active information.
Clearly describe each folder in your Document Library.
To put in a detailed description of a Document Library:
1. Click on the Document Library you want to edit.
2. In the Document Library you want to edit, in the left navigation, click Modify Settings and Columns.
3. On the Customize page, in the General Settings section, click Change General Settings.
4. This takes you to the Document Library Settings page, In the Name and Description section, type in the description of the folder. Click OK.
7. Link to files in SharePoint folders
When you're working on a project, it’s easy to just insert a file from the team Web site into an e-mail. By sending out different versions of the same file, however, you could end up with multiple versions of the same document. It's far more reliable to just insert a link to the document in your e-mail. You can also put links to SharePoint documents into a task in Microsoft Office Outlook, or into an appointment on your calendar.
If you store multiple copies of a file on your team Web site, it's also easy for one copy of the file to get modified and leave the others out of date. Instead, we make sure we only have one version of a document and link to it from other places when necessary.
To put a link to file on your team Web site into any Microsoft Office document:
1. Locate the document you want to create a link for. Put your cursor over the document name until the file name turns red.
2. Right-click on the red file name and in the drop-down menu and click Copy Shortcut.
3. With your mouse cursor in the body of your task, appointment, contact, documents folder, or in another file, right-click and click Paste. This will paste the link. When you click on the link, it will open the actual document.
Put links to documents on your team Web site rather then putting different versions in multiple locations.
To put a link to file on your team Web site into another part of the Web site:
3. Navigate to the folder you want to include the link in. Click New Document. SharePoint will open a new document called "template.htm" in Microsoft Word.
4. Paste the shortcut into the new document. Select all of the text and right click on it.
5. Click Hyperlink... and type in the text you want in the Text to display box (for example, "Click here to see the final version of this presentation.") Click OK.
6. Save the file. When anyone opens this file, clicking the link will take them to the current version of the referenced file.
I hope sharing some of the lessons we’ve learned will help you get a head start on your own team Web site.
Computers & Internet Logo
Can anyone give me any tips for learning to use a bodyboard?
Livestrong has a really good article with some basic tips for learning to use a body board. Good Luck - it looks hard but a lot of fun.
http://www.livestrong.com/article/472791-bodyboard-like-pro/
Feb 28, 2013 | Toys
How To Keep Kids Safe On The Web 19 June 2007 (updated) This article features advice for helping kids stay safe while they browse the Web. Advice for Kids - simple tips - interesting web sites to try Advice for Parents - safety web sites - monitoring software - Limited user accounts Related Tips Ask a Question The World Wide Web provides a wonderful resource for entertaining and educating children. However, dangers do exist and it is important for kids and parents to be aware of these dangers and to know how to stay safe online. This article features practical advice for both kids and parents. Advice for Kids The Internet is full of interesting web sites and is a great way to meet new friends across the world who share your interests. Unfortunately, not everyone you meet on the World Wide Web is friendly and some people even pretend to be someone they're not. To make sure you have a safe time while you're surfing the Web, remember these tips: - Avoid giving out your e-mail address to people you don't know - Never give out your full name, telephone number, home address or the name of your school - Don't open e-mails or attachments from people you don't know - If you visit a web site or receive an e-mail that makes you feel uncomfortable, tell your parent or whoever looks after you - Don't tell other people your Internet passwords - Never agree to meet up with someone you have met on the Internet - Try to avoid staring at the screen for too long without a break Some interesting web sites for you to try: www.kidscom.com - fun and games www.bbc.co.uk/cbeebies - games and fun things to do http://kids.yahoo.com - Yahoo! kids search engine www.bbc.co.uk/schools - BBC Schools www.channel4.com/learning - homework help
Sep 17, 2010 | Computers & Internet
What values do kids learn from pretend play?
Take a look at this good article from the Better Kid Care site.
http://www.betterkidcare.psu.edu/TIPS/TIPS46.pdf
it even gives some good tips for using basic household items to help promote pretend play.
Feb 18, 2013 | Toys
The words on the screen are blurry
if you are using windows vista/7, right click, go to personalize, display, change display settings, resolution - try the different settings there to find out which one fits better your monitor. Hope it helps
Feb 05, 2011 | LG L1520B 15" LCD Monitor
183 people viewed this tip
David Payne
David Payne
