Tip & How-To about Computers & Internet
Questions you should ask yourself before upgrading your desktop PC
1) Is there a good reason to upgrade my PC? Is my PC working well with relatively few problems considering my personal computing needs?
2) Have I received good value from my current configuration? Is it becoming problematic to do the things I now need to do on my PC?
3) Have my computing needs changed? If so, in what area? Do I require more raw computing power or perhaps just some new software applications that will work well with my current PC configuration and operating system?
4) Do I really need the latest operating system available? If I upgrade my OS, will my current hardware devices function properly? Will they even be supported?
5) If I upgrade to a new hardware device, will I be able to support it with my current operating system and PC configuration? Is there a software program, routine or driver that I can use that is compatible with my current OS to install the device properly?
If you do not have the answers to most of these questions, perhaps you should consult with someone who does. There are many self-proclaimed experts out there, but in the end you should be able to find a professional who can suggest the best and most sensible upgrade solution for your personal computing needs.
Generally speaking, the people who have the fewest problems with desktop PC upgrades have used their system for many years practically trouble free and then have chosen to upgrade both the hardware and software at the same time. Having realized the importance of these two aspects of PC computing working well together, they are no doubt on the road to many more years of happy computing!
Computers & Internet Logo
i want to upgrade my memory on Acer Aspire 7551
why do you need more memory your machine wont work better
Jan 03, 2018 | Acer Aspire One PC Notebook
my computer freezes
You will need to find out what really is happening because there are many reasons that can make a computer free, please elaborate more. when does it freeze? is it when watching a movie or just after startup, is it when you are playing a game or what? Many instances are Memory related issues as many back ground services may be running that means you will need to find out how much RAM you have, You can do this by Right clicking on the My Computer Icon then view the information listed this will tell you much about what your computer can do and what may be happening to it during freeze because if all are basically good the problem might be software related or virus related. Please give more details on when, how, after clicking on a program or just at startup? when does your computer freeze. 1= Might be caused by over heating meaning the processor doesn't get enough air may need to add a fun or just make possibility for your computer to be cool such as opening the housing. 2= If the problem is with the RAM (Random Access Memory) You may need to stop background services before launching a large application o game or you may just need to buy another slot and upgrade.
Mar 24, 2011 | Microsoft Windows XP Professional for PC
Windows 7 upgrade, Belkin wireless router. Sa...
I RECOMMEND YOU TO UPDATE THE FIRMWARE OF YOUR ROUTER. Download the firmware from belking support site.
May 20, 2010 | Belkin F5D8236-4 Router
router problems when using xbox live
This sounds like a problem i ran into a few years back with a ps2.
This is not a machine related problem this is a signal strength problem. Most likely you have too much cord in between the router and the X box try shortening that cord as much as possible.
If this doesnt work try calling 1-800-4MY-XBOX
they will run a few tests with you and confirm my diagnosis.
you might be forced to run Xbox lve directly off your modem in an extremem situation or consider upgrading your internet signal or router
GL
Comment for further help
Please rate advice as it will help me out
Apr 08, 2009 | Microsoft Video Game Consoles & Games
dead laptop
Look at it from the point of view of the manufacturer. Having made thousands if not hundreds of thousand from the same mold/die, it would be more economically reasonable for them to replace the entire board rather than repair. The problem to the consumer is soon as warranty is over, the problem drops to your lap. Your conclusion of a manufacturing defect indicates that you have made a research and therefore would also have known the exact section/component causing this. Additional corrective measure other than replacing the board would be to "beef" up/upgrade/enhance that section/component, but this of course would require extensive knowledge of the electronics involved. If it were heat related, improve/increase forced air ventilation, if it were BIOS related, upgrade/downgrade to a more stable version, if it were performance related, set settings to default or in general downgrade usage but upgrade specs. Say originally Vista, back down to XP, use a docking station with additional blowers, add think heatsink on chipsets, and a few other "make do".
Since you have not posted the exact model/version the above of course would be generic.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 27, 2008 | Compaq Presario Notebook
132 people viewed this tip
David Payne
David Payne
