Tip & How-To about Computers & Internet
How to troubleshoot a system that will not boot to the hard drive.
  1. Ensure that there is no diskette in the A: drive if system is equipped with a 1.44 Floppy Diskette Drive. If a disk in the drive, remove it and reboot.
  2. Boot to the BIOS, reset defaults, reboot
  3. If system still will not boot to the hard drive, power off, disconnect all peripheral items (Printer, scanner, external drives and USB drives) reboot.
  4. At this point, boot to Diagnostics partition, or CD (F12 menu on some systems, Some HP systems have Hard drive diags in BIOS, Fn+Power for Dell Portables, CTRL+ALT+D for some Dell Desktops) If the hard drive fails diagnostics, replace the hard drive. If the drive passes diagnostics, it is not a guarantee the drive is good, just no fault was detected.
  5. If the drive passes diags, then see if you can boot to a Windows CD/DVD. If you can't, either remove, turn off in BIOS or disconnect the hard drive, and see if you can boot to the Windows Media. If you can with the HDD disabled/removed/disconnected, again, replace the HDD.
  6. If you can boot to the Windows Media, then go to Recovery Console in XP and run CHKDSK /R (Vista or Windows 7, run the repair my computer option off the menu, this may take multiple passes to fix) If this fails to resolve, then boot back to recovery console and run BOOTCFG /REBUILD (This is already done in Vista/7 in the repair tool)
  7. If that fails, you will most likely be reinstalling Windows. If the Windows install crashes during a file copy, try RAM modules one at a time (Windows install is still the best RAM test we have) If the Windows install still crashes, replace the Hard Drive.
Computers & Internet Logo
3.5 MAC disk from 1996 needing to be read in 2014
You'll have to locate / borrow a Mac with a diskette drive, or an external diskette drive that you can plug into your current Mac.
Possibly a Mac support/repair location will have such a drive. Or look to purchase such a diskette drive in the used equipment market.
Mar 03, 2014 | Sony 1996 Micro Floppy Disk Mac Formatted...
i have an acer aspire 5536 G, it had windows vista on it. Now everytime i try to turn it on it says that there is no operating system found. what can i do to restore it?
An error of no operating system found, is often an indication of a failed hard disk drive (HDD) in the system (The hard disk drive is where all data including Windows is stored)
  1. If the system is equipped with a floppy diskette drive, remove the diskette from the floppy drive and reboot.
  2. Re-seat the hard disk drive. (From time to time due to expansion and contraction the HDD may lose contact and is no longer detected)
  3. Once re-seated, reset the BIOS defaults (normally F2 at boot) then there is normally a setting to reload defaults. Resetting default settings forces the BIOS to re-detect all peripherals connected to the system.
  4. If you still get that error at boot, then it is very likely the drive no longer is functional and will need to be replaced.
Aug 05, 2011 | Computers & Internet
AL INICIAR MI COMPUTADORA DEL INSPIRION 530 APARECE EN EL MONITOR UN AVISO ASI: REMOVE DISKS OR TOHER MEDIA PRESS ANY KEY TO RESTART. QUE PUEDO HACER?
The computer is indicating that something is preventing it from booting to the hard disk drive. Ensure that if the system has a floppy diskette drive, there is no diskette in the drive as the system may be trying to boot to it and failing.
If no floppy or no other Media (DVD/CD) in any drive then the Hard Disk Drive may be having problems and need repair.
(La computadora est? indicando que algo est? evitando que pateara a la impulsi?n de disco duro. Aseg?rese de que si el sistema tiene una disquetera floja, no haya diskette en la impulsi?n pues el sistema puede intentar patear a ?l y a fallar. Si ningu?n disco blando o ningunos otros medios (DVD/CD) en cualquier impulsi?n entonces la impulsi?n de disco duro puede tener problemas y necesitar la reparaci?n.)
more info here:
http://www.fixya.com/support/r3728860-troubleshoot_system_will_not_boot_hard
Jul 24, 2011 | Dell Inspiron 530 Desktop Computer
Yea sorry, forgot that tid-bit of info. It,s the W3118 eMachine / Gateway FIC K8MC51G
This issue can be caused by any of the below reasons.
-Corrupt boot files on the computer.
-Settings for hard disk drive are not correct.
-Floppy diskette or CD in computer causing issue.
-Boot devices not set properly.
-BIOS corrupt or misc. setting not set properly.
-Connections loose or disconnected.
-Bad Hard disk drive or other bad hardware.
Solution:
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
Once at the A:\> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:\> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue attempt to reset the BIOS / CMOS settings to the factory or default settings.
If the computer has been recently moved or new hardware has been installed in the computer it is possible that a connection may be loose or even disconnected. Verify that the hard disk drive, floppy and CD-ROM cables are properly connected.
Bad hard disk drive or other bad hardware
If you computer continues to freeze at the DMI message after attempting all of the above recommendations it is possible that the computer may be freezing because of a bad hard disk drive or other bad hardware in the computer.
Before replacing any hardware we first recommend you attempt to erase everything on the hard drive and start over.
If you're unable to get to the point of re-installing the operating system it's likely your computer has a hardware issue and it's suggested that the hard drive be replaced. If that doesn't resolve the issue then have the motherboard replaced.
Oct 20, 2009 | E-Machines eMachines Desktop PC
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
1,889 people viewed this tip
David Payne
David Payne
