Tip & How-To about Kitchen Ranges
Replacing the Control on a Kitchen Range
This advice is for GAS or ELECTRIC ranges equipped with a rear panel display. The electronic control board on these ranges not only display the clock and timer functions, but also control all the oven features. If the board fails, you will experience a loss of some, or all of the oven features. Due to the safety design of new generation appliances, the board needs to replaced to restore the oven features.
The control board is commonly referred to as the Electronic Range Control (ERC) or Electronic Oven Control (EOC). Both terms are often used interchangeably.
Replacing an ERC/EOC is not a difficult repair and can easily be accomplished by the average do-it-yourselfer. To avoid retail mark-up, parts can generally be ordered on line at discounted prices. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC/EOC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC/EOC and the assembly will come out.
NOTE: Most replacement ERC/EOC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Some of these overlays are not cheap, so replacement is not always necessary. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC/EOC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid causing Electro-Static damage to the board.
NOTE: This is static electricity that can build up in the human body. There is enough voltage in most static charges that can easily damage sensitive components on circuit boards. Handle the edges of the circuit board and avoid touching the surface area when possible.
If you have any questions about this repair, or if you need recommendations on where to purchase replacement parts, please let me know. I hope this information is found to be helpful.
Kitchen Ranges Logo
Function error F7 d6
CONTACT GE and ask for their assistance .
Dec 07, 2017 | GE JGS905SEKSS Stainless Steel Gas Kitchen...
oven fault codes
icon1.gif imported post "The best that I can determine from the fault codes is that the *ribbon* on the range electronic control----is not tight enough. Turn off curcuit.
If you unplug the range and remove the rear panel behind the electronic control.
There should be a tape-like ribbon that goes to the circuit board.
This ribbon is problably not snug enough at the connection.
I've read about servicers tearing off the cover of a pack of matches and inserting it into the connector to improve the fit. This can only be done by pulling the ribbon out and looking at it to see which side is bare metal (basically flat wire) and which side is insulated or non-exposed wires. Obviously the matchbook cover must not be pressed into the side of the ribbon that connects with the pc board wiring.
John" I followed John's advice and it worked. I, a 33 yo female, removed the back panel of the stove, found the ribbon (along the back/side of the display looped and connected to the panel), detatched it, cleaned it with an eraser (suggestion from another blogger), and reattached the ribbon snugly (locked in by a plastic thing). I don't know if it was just loose or needed cleaning but it was easy to do. Sears would not even tell me what the code meant and they were going to charge me $65 for a technician to come out. We do have an electric stove instead of gas, so I am not sure if it will be any different. Good luck. Dana
Apr 11, 2008 | Kitchen Ranges
Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
May 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
3,956 people viewed this tip
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
