Tip & How-To about Computers & Internet
Burn a Bin without a CUE using NERO
You've downloaded a *. BIN file, but there was no *.CUE file associated and you still want to burn the *. BIN file using Nero.
Your options are:
1) Create yourself a *.CUE
2) Convert the *.BIN to an *.ISO
3) OR use Nero to burn without the *.CUE file! ! !
Yes, that`s possible...just follow these steps and you will be sorted. No need for *.CUE files anymore
ok, here we go...
1) Start Nero
2) File -> Burn Image
3) Browse to the *. BIN file that you want to burn and open it
4) A window saying "Foreign Image Settings" will open
5) Check the settings. They should be as followed:
* Type of image: leave it to Data Mode 1
* Select the Raw Data check box
Note->> The block size will change automatically from 2048 to 2352
* Leave Image Header and Image Trailer unchanged and set to 0
* Leave "Scrambled" and "Swapped" check boxes unchecked
6) Click on burn!
7) Enjoy
This tut was for Nero 5.x.x.x, I was told that "Burn Image" is under "recorder" in Nero 6.
The rest of the steps should be the same...xkalibur
Computers & Internet Logo
how open image ISO. files
.ISO files are archived filed ready for burning to a CD or DVD discs using burning programs like Nero. Thus, Nero software can open and burn this .iso files to discs. Also, Winrar can open and extract the files in a .iso file archive. Download Nero to burn or Winrar to open them
Sep 25, 2009 | Microsoft Windows Vista Home Premium with...
How do I get NERO to burn a (cd+g)?
Nero won't burn a cd+g file as the burner does not recognize the file type.
You need a program called mp3+gToolz its free, get it here>>>
http://www.activeaspsoftware.net/default.aspx?p=downloads
You need microsoft.NET framework from windows update withmp3+gtoolz you can convert your mp3 and cdg files into a bin file youthen need a program called cdrwin you get it from www.goldenhawk.comits not expensive but its free to copy at 1X speed you then have to runcdrwin select everything to cdg then load you bin files and record yourtracks you must have a cdg compatible burner but it will let you knowif you haven't.
Good luck.
Sep 10, 2009 | Ahead Software Nero 6 Ultra Edition...
I just installed an lg cd burner and windows
Did you install the drivers? (The CD that comes with the LG burner?)
Aug 25, 2009 | Computers & Internet
I have ps1 game in bin and cue files form.How can I burn it on disk properly and play it on my console?Help please.
Awesome, then you're all set. xD
Okay, first you need to get ImgBurn
Here is the site
ImgBurn
http://imgburn.com/
So download and install
Now, you need an iso image file in order to burn in on to the cd.
1. So find your bin file of the game.
2. Then right click and select rename.
3. Add ".iso" to the end without quotations.
Now run ImgBurn
1. First select burn image file to disc
2. Select browse for a file
3. Find the directory of your game and select it
4. Then burn it
Remember that burned games can't run if you burn at speeds of 4x or more so just leave it at 1x.
And if you're having trouble following the directions for ImgBurn here are some images of what is being done in that order
ImgBurn
1.http://i574.photobucket.com/albums/ss186/NytFantom/Using%20ImgBurn/ImgBurn1.png
2.http://i574.photobucket.com/albums/ss186/NytFantom/Using%20ImgBurn/ImgBurn2.png
3.http://i574.photobucket.com/albums/ss186/NytFantom/Using%20ImgBurn/ImgBurn3.png
4.http://i574.photobucket.com/albums/ss186/NytFantom/Using%20ImgBurn/ImgBurn4.png
Mar 05, 2009 | Vatical Entertainment SeaDoo HydroCross...
152 people viewed this tip
David Payne
David Payne
