Tip & How-To about Computers & Internet
How to Add RAM to Your Desktop Because we all hear news of computer technology getting faster and faster, we expect a lot when we purchase a new desktop. We figure from the moment we start up the system, everything will be fast and easy. Running applications and switching between several programs will take no time at all, and the act of opening your Web browser will take place in a flash. In the beginning, it may be very much like this. But as time passes and you add new applications and acquire a lot more data on your hard drive, chances are your computer will react a lot slower. After a while, starting up your computer might take several minutes, an eternity compared to the day when you first switched the machine on. But it's no surprise that your computer's growing slower. Just think about all of the things you use your computer for. Are you one of those people who like to edit and organize digital photos? If so, you're probably filling your hard drive with a seemingly endless number of pictures from memory cards. Or perhaps you like to capture home movies on digital video, which can take up even more storage and processing power. And, like many others, you may store large libraries of MP3 files on your desktop, too. Your computer has to manage the software that you use to work with these files. If you think about your computer having to run all of these programs at the same time, you start to understand how much pressure we place on desktops. So, do you have to accept an abysmally slow desktop, or can you actually take action? Fortunately, there's an easy and inexpensive way to adjust if you want to keep up with a digital world that never seems to slow down. Simply adding to or upgrading your existing random access memory (RAM), can make a noticeable difference in your desktop's processing performance Choosing RAM for Your Desktop Whenever we run an application or tell the computer to perform a certain function, the information from that command is loaded onto memory. With that memory on hand, your desktop can run more efficiently. But when your computer has too many tasks to perform and not enough means with which to do everything, you're putting strain on your desktop's processing. It's sort of like asking a person who's spent a couple of weeks training for a 5K race to run an entire marathon -- the runner wouldn't have the strength to run such a long distance in a reasonable amount of time since he or she would be woefully unprepared. So if your desktop is suffering from too much workload, how much RAM do you actually need? Before you go out to find the RAM module on the shelf, you need to ask yourself what kind of work you normally do on your desktop. If you use your desktop for just your bare-bones basics like e-mail and word processing, your computer won't need too much RAM. Somewhere between 384 to 512 MB of RAM should be sufficient. But you should keep in mind that even if your desktop computer is relatively new, some systems don't come with enough memory to operate even the most basic tasks. The more processing you require your computer to perform, however, the more RAM you'll need. If you use your desktop for work in a home office and you often use several different types of programs simultaneously, including e-mail, Web surfing, word processing, spreadsheets and software for presentations and illustrations, you desktop will probably require the upper end, maybe even as much as 1 GB of RAM. Serious gamers who use up a lot of graphics power need between 1 and 2 GB of RAM, while professionals who use a lot of 3-D modeling software should probably have 2 GB or more. If you're not entirely sure what kind of RAM your desktop you'll need, there are Web sites like Crucial.com that are dedicated entirely to memory performance and allow you to select the type of desktop you own and search for the most compatible type of RAM for your system. Adding RAM to Your Desktop ­Once you've chosen the right kind of RAM, it's time to install your RAM module into the insides of your desktop. Before you get started, make sure your desktop has been turned off and unplugged from any outlets. Opening up your computer while there's a power source connected to it is dangerous, so to avoid any electrical accidents it's a good idea to make sure you handle everything carefully. You should also ground yourself by touching a metal surface or wearing an antistatic wrist strap. This prevents electrostatic discharge, something many of us have experienced by dragging our feet over a rug, touching a doorknob (or another person) and creating a spark. This happens when two objects touch or rub together and exchange electrons -- one becomes positively charged, the other negatively charged. When one object touches another that has an opposite charge, electrons shoot out to balance the charges. Static charges may give us a harmless shock when we touch a doorknob, but they can damage computer equipment, so grounding yourself will protect sensitive components. Desktop computers are designed many different ways, but most have either side doors or tops that can be removed with the help of a screwdriver. The RAM slots are located on the computer's motherboard. There are usually two slots, though there may be more. If all slots are filled up with existing RAM modules, you can replace a smaller RAM chip with a larger one. Just release the tabs that hold the module down, remove the old module and insert the new, larger one. If there's a slot open, you simply can slide the new module in place and gently snap it into position. Once you've installed the RAM, and after you've closed up your desktop safely and properly, you can start up your computer. The system should recognize the new RAM automatically. Now your desktop will boot up faster, run applications more efficiently and switch between programs with noticeable ease. Sources Sources Crucial.com. "How much memory do you need?" (Jan. 26, 2009) http://www.crucial.com/uk/support/howmuch.aspxCrucial.com. "How to improve the performance of your desktop computer with an easy, affordable desktop memory upgrade." (Jan. 26, 2009) http://www.crucial.com/uk/support/guides/desktop/The Memory Suppliers. "How to install memory - installing desktop and laptop memory RAM." (Jan. 26, 2009) http://www.memorysuppliers.com/howtoinallty.htmlMiastkowski, Stan. "Avoid static damage to your PC." PC World. Jan. 31, 2002. (Jan. 26, 2009) http://www.pcworld.com/article/82184/avoid_static_damage_to_your_pc.html
Computers & Internet Logo
hi guys, im using a intel dq35mp motherboard with a q6600 2.4ghz core 2 quad processor , with 8gb ddr2 ram (4x 2gb) and 4x 500gb hdd + 1x 1Tb hdd. im using a 5050watts power supply. i want to overclock my system for it to run much more faster, is that possible. i also want to boost up my boot up speed. ive done a bios update and dat stil doesnt help.pls assist ,so i can get the best out of my system . pls reply to julianpadayachee@gmail.com
All other Brand Memory-- Desktop Memory --Abit Desktop MemoryAcer Desktop MemoryAdastra Systems Desktop MemoryAdvantech Desktop MemoryAlbatron Desktop MemoryAlienware Desktop MemoryALR Desktop MemoryAmptron Desktop MemoryAOpen Components Desktop MemoryApple Desktop MemoryAPS Desktop MemoryARM Desktop MemoryAST Desktop MemoryASUS Desktop MemoryAT&T/NCR Desktop MemoryAxil Computer Desktop MemoryBiostar Desktop MemoryBroadax Systems Desktop MemoryCanon Desktop MemoryChemUSA Desktop MemoryClevo Desktop MemoryCompaq Desktop MemoryCompuadd Desktop MemoryCTX Desktop MemoryData General Desktop MemoryDell Desktop MemoryDigital Desktop MemoryECS Elitegroup Computer Desktop MemoryeMachines Desktop MemoryEpox Desktop MemoryEpson Desktop MemoryErgo Desktop MemoryEverex Desktop MemoryFIC Desktop MemoryFoxconn Desktop MemoryFujitsu Desktop MemoryGateway Desktop MemoryGigabyte Technology Desktop MemoryHAL Desktop MemoryHewlett-Packard Desktop MemoryHitachi Desktop MemoryIBM Desktop MemoryIntel Desktop MemoryIntergraph Desktop MemoryIwill Desktop MemoryJetway Desktop MemoryMAXDATA Desktop MemoryMicron Desktop MemoryMicrostar Int. Desktop MemoryMitsubishi Desktop MemoryMonorail Desktop MemoryMotorola Desktop MemoryNCD Desktop MemoryNEC Desktop MemoryOlivetti Desktop MemoryPackard Bell Desktop MemoryPolywell Desktop MemoryPower Computing Desktop MemoryRadius Desktop MemoryShuttle Desktop MemorySiemens Nixdorf Desktop MemorySilicon Graphics Desktop MemorySoltek Desktop MemorySonBook Desktop MemorySony Desktop MemorySoyo Desktop MemorySun Desktop MemorySuperMicro Desktop MemoryTatung Desktop MemoryTektronix Desktop MemoryTiny Computers Desktop MemoryToshiba Desktop MemoryTyan Desktop MemoryUMAX Desktop MemoryUnisys Desktop MemoryVPR Matrix Desktop MemoryWinBook Desktop MemoryZenith Desktop Memory-- Laptop Memory --Acer Laptop MemoryA-Com Laptop MemoryAlienware Laptop MemoryAltima Laptop MemoryAMS Tech Laptop MemoryAOpen Components Laptop MemoryApple Laptop MemoryAqcess Technologies Laptop MemoryAquiline Laptop MemoryARM Laptop MemoryAspen Laptop MemoryAST Laptop MemoryASUS Laptop MemoryAT&T/NCR Laptop MemoryAustin Laptop MemoryAveratec Laptop MemoryBroadax Systems Laptop MemoryCanon Laptop MemoryChaintech Laptop MemoryChaplet Laptop MemoryChemUSA LaptopsMemoryChicony Laptop MemoryClevo Laptop MemoryCommax LaptopsMemorydeCompaq Laptop MemoryCompuadd Laptop MemoryCTX Laptop MemoryDaewoo Laptop MemoryDell Laptop MemoryDigital Laptop MemoryECS Elitegroup Computer Laptop MemoryeMachines Laptop MemoryEPS Laptop MemoryEpson Laptop MemoryErgo Laptop MemoryEverex Laptop MemoryFIC Laptop MemoryFOSA Laptop MemoryFujitsu Laptop MemoryGateway Laptop MemoryGigabyte Technology Laptop MemoryGRiD Laptop MemoryHewlett-Packard Laptop MemoryHitachi Laptop MemoryHyperData LaptopsMemoryy UpgradeHyundai Laptop MemoryIBM Laptop MemoryItronix Laptop MemoryJetta Laptop MemoryJVC Laptop MemoryKapok Laptop MemoryKDS Laptop MemoryKeyData Laptop MemoryKiwi Laptop MemoryMAG Laptop MemoryMagitronic Laptop MemoryMAXDATA Laptop MemoryMaxtech Laptop MemoryMicron Laptop MemoryMicrostar Int. Laptop MemoryMitac Laptop MemoryMPC Laptop MemoryNEC Laptop MemoryOlivetti Laptop MemoryPackard Bell Laptop MemoryPanasonic Laptop MemoryPolywell Laptop MemoryPower Computing Laptop MemoryProStar Laptop MemorySager Midern Laptop MemorySamsung Laptop MemorySceptre Laptop MemorySharp Laptop MemorySiemens Nixdorf Laptop MemorySony Laptop MemorySotec Laptop MemorySwan Laptop MemoryTadpole Laptop MemoryTechmedia Laptop MemoryTexas Instruments Laptop MemoryTiny Computers Laptop MemoryToshiba Laptop MemoryTwinhead Laptop MemoryUMAX Laptop MemoryUnisys Laptop MemoryViewsonic Laptop MemoryVPR Matrix Laptop MemoryWedge Laptop MemoryWinBook Laptop MemoryZenith Laptop MemoryZeos Laptop Memory-- MotherBoard Memory --Abit Motherboard MemoryAdastra Systems Motherboard MemoryAdvantech Motherboard MemoryAlbatron Motherboard MemoryAMI Motherboard MemoryAmptron Motherboard MemoryAntec Motherboard MemoryAOpen Components Motherboard MemoryASRock Motherboard MemoryASUS Motherboard MemoryBiostar Motherboard MemoryChaintech Motherboard MemoryDFI Motherboard MemoryDigital Motherboard MemoryECS Elitegroup Computer Motherboard MemoryEpox Motherboard MemoryFIC Motherboard MemoryFoxconn Motherboard MemoryFujitsu Motherboard MemoryGigabyte Technology Motherboard MemoryIntel Motherboard MemoryITOX Motherboard MemoryIwill Motherboard MemoryJetway Motherboard MemoryLanner Motherboard MemoryLegend QDI Motherboard MemoryMatsonic Motherboard MemoryMicrostar Int. Motherboard MemoryMitac Motherboard MemoryPC Chips Motherboard MemoryPCWare Int'l Motherboard MemoryPine Technology Motherboard MemoryQDI Motherboard MemorySceptre Motherboard MemoryShuttle Motherboard MemorySoltek Motherboard MemorySoyo Motherboard MemorySun Motherboard MemorySuperMicro Motherboard MemoryTyan Motherboard MemoryVia Technologies Motherboard MemoryXFX Motherboard Memory
RAM Upgrade for Intel DQ35MP Motherboards
DQ35MP RAM Specifications
Standard Memory
0 MB (removable)
Maximum Memory
8.0 GB
Memory Expansion
4 sockets
Memory Comments
PC2-5300/6400 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2.
CPU Type
Intel Celeron D or Intel Pentium 4 or Intel Pentium D or Intel Core 2 Duo or Intel Core 2 Quad
Model Comments
800/1066/1333MHz FSB, Intel Q35 Express Chipset, microATX Form Factor
Upgrading RAM on your Intel DQ35MP Motherboards is easy, we carry compatible RAM Upgrade for Intel DQ35MP Motherboards, the Intel DQ35MP Motherboards takes the PC2-5300/6400 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your Intel DQ35MP Motherboards to up to a maximum of 8.0 GB RAM, the Motherboards has 4 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for Intel DQ35MP Motherboards.
Memory Size
Chip Description
Part Number
Price
OEM Part #
512MB Module
512MB-667MHz DDR2-667 PC2-5300, 240p DIMM, 1.8v
726ms-726
$14.95
In Stock
1GB Module
1024MB-667MHz DDR2-667 PC2-5300, 240p DIMM, 1.8v
727ms-727
$24.95
In Stock
2GB Module
2048MB-667MHz DDR2-667 PC2-5300, 240p DIMM, 1.8v
728ms-728
$39.95
In Stock
512MB Module
512MB-800MHz DDR2-800 PC2-6400, 240p DIMM, 1.8v
763ms-763
$24.95
In Stock
1GB Module
1024MB-800MHz DDR2-800 PC2-6400, 240p DIMM, 1.8v
764ms-764
$24.95
In Stock
2GB Module
2048MB-800MHz DDR2-800 PC2-6400, 240p DIMM, 1.8v
765ms-765
$39.95
In Stock
Need further assistance? Please click...
MemoryStock Guarantee
Jun 30, 2012 | Computers & Internet
WHAT COMPUTER PART CAN I USE IN MY NEW COMPUTER?
If you are talking about a desktop, you may be able to add a USB card to it, which will give you USB functionality. But, if your computer is *this* old, you might be better off getting a new one anyways just for the huge performance increase. You are always able to add more RAM to it, upgrade hard drive, etc. Adding memory is the single most upgrade that helps a computer be faster.
Considering that your old computer doesn't have USB ports, there likely is very little that you will be able to use on the new one. Several leaps in technology have occured.
But, to answer your question, you can likely move the hard drive from old computer, as well as the optical drives (CD/DVD). If your graphics card is not part of the motherboard, that can be brought over as well. Add the keyboard and mouse, and that will be about it.
Jun 16, 2010 | HP Computers & Internet
i need to add space to my compaq presario desk top. i don't know how to on this computer. the model# SR5034X
If you want to increase cpu speed so you need to increase RAM memory.
You can fix it on motherbord of desktop cpu.
But if you have low space on disk storage partition so you can add space to desktop with 2 method.
(1) you can add harddisk to desktop cpu with sata or IDE .SATA harddisk is best if your motherbord support SATA.
You can add harddisk as you like for example 80 GB or 160 Gb.
(2) If you want to add RAM memory for speed reson you can purchase new RAm and fix it in memory module slot on motherbord.
There is 2 type on
RAM in currently.
DDR1 and DDR2
you can add RAM memory like 512 MB or 1GB or more.
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
How to upgrade a new compaq presario SR2150NX?
Add more RAM, 512MB ram will slow your computer down because when you run out of ram the computer uses the hard drive as vitrual ram. I have 4GB in my Vista machine and it is faster than XP.
Another suggestion is to turn off the hard drives indexing. Right click on your "C" drive and unhook the "index this drive for faster searching" box.
Jan 05, 2008 | HP Compaq Presario SR2150NX PC Desktop
261 people viewed this tip
David Payne
David Payne
