Tip & How-To about Computers & Internet
How to Backup and restore the registry
In case you go and modify the registry manually and you want to back it up in case something goes wrong and you want to restore it, this is perfect for you.
Backup:
1.) Go into the start menu and click "Run".
2.) Type "cmd" and click OK
3.) type in the window "copy c:\windows\system.dat c:\windows\system.000" and press enter.
4.) Once Complete type "copy :\windows\user.dat c:\windows\user.000" and press enter.
You have now created a backup of the registry.
Restore:
1.) Go into the run menu again and type cmd.
2.) Type in the 2 commands that was shown in the backup section except in each command swap the twon directores.
(e.g.) "copy c:\windows\system.dat c:\windows\system.000" will become "copy c:\windows\system.000 c:\windows\system.dat"
Whatever was backed up when you created the backup file will be restored to the windows registry.
Computers & Internet Logo
How do I remove write protect from my CMB USB 2.0 USB device?
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>.
    2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
    3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled).
    4.Close the registry editor and restart Windows.
    5.After Windows starts, test writing to your USB drive.
    Important Note:
    Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored.
    For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
Mar 04, 2014 | Electronics - Others
remove write protected usb 8gb
    Important Note:
Jan 25, 2014 | Transcend Electronics - Others
error 28000 cisco vpn win xp
I suggest that you follow the below article that will give you information on How to Uninstall Manually and Upgrade the Cisco VPN Client that I found on the Cisco Support website: http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a0080094b7f.shtml Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up annd restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756 ) How to back up and restore the registry in Windows Thanks, Irfan H, Microsoft Answers Support Engineer
Aug 06, 2012 | Cisco Computers & Internet
128 people viewed this tip
David Payne
David Payne
