Tip & How-To about Computers & Internet
Yahoo Messeger,no ad's
I went into the system registry and found out that Yahoo! moved the ' banner url ' key to a slightly different location. Than what it used in version 5.5!
Yahoo! IM no longer uses 'Yurl', but uses 'view' instead. You gotta click on each key inside of 'view' and edit the 'banner url' string to anything you want... I simply cleared mine out completely and it works flawlessly!
Here is what you gotta do:
Run regedit
Goto HKEY_CURRENT_USER -> Software -> Yahoo -> Pager -> View
Inside the 'View' key there are a several other keys... go through each one and edit the 'banner url' string to your liking. It even works if the string is left blank (this causes it to look as if ads were never even implemented)!
Restart Yahoo! IM for the effect to take hold.
This is great for Yahoo! IM who don't want to be bothered with ads.
Computers & Internet Logo
my dell 510 only show DELL on tv nothing else from my laptop
What Operating System and version are you using (i.e. Windows XP, Windows 7, etc)?
If Windows, you will ultimately have to go to Control Panel > Display > and choose to extend your laptop screen to the connected device. These options are in slightly different places across different OS versions so it may take some digging around to locate the option to extend display.
Feb 13, 2013 | Dell Latitude D510 Notebook
W32.trojan.4492
Download SmitfraudFix:
Use this URL to download the latest version (the file contains both English and French versions):
http://siri.geekstogo.com/SmitfraudFix.exe
  • Search:
    • Double-click SmitfraudFix.exe
    • Select 1 and hit Enter to create a report of the infected files. The report can be found at the root of the system drive, usually at C:\rapport.txt
  • Clean:
    • Reboot your computer in Safe Mode (before the Windows icon appears, tap the F8 key continually)
    • Select 2 and hit Enter to delete infect files.
    • You will be prompted: Do you want to clean the registry ? answer Y (yes) and hit Enter in order to remove the Desktop background and clean registry keys associated with the infection.
    • The tool will now check if wininet.dll is infected. You may be prompted to replace the infected file (if found): Replace infected file ? answer Y (yes) and hit Enter to restore a clean file.
    • A reboot may be needed to finish the cleaning process. The report can be found at the root of the system drive, usually at C:\rapport.txt
  • Optional:
    • To restore Trusted and Restricted site zone, select 3 and hit Enter.
    • You will be prompted: Restore Trusted Zone ? answer Y (yes) and hit Enter to delete trusted zone.
Note:
process.exe is detected by some antivirus programs (AntiVir, Dr.Web, Kaspersky) as a "RiskTool". It is not a virus, but a program used to stop system processes. Antivirus programs cannot distinguish between "good" and "malicious" use of such programs, therefore they may alert the user.
http://www.beyondlogic.org/consulting/proc...processutil.htm
May 02, 2011 | Microsoft Windows XP Professional
my yahoo messenger won't show any messages on the IM window. I can see what i am typing but not when i've sent it already. I can't also see the messages sent for me. I've already reinstall different versions of yahoo messenger and have followed the instructions to troubleshoot it but it still doesn't work.
Try this solution.
Open RUN. Type REGEDIT then ENTER.
Look for this registry KEY.
HKEY_CURRENT_USER > Software > Microsoft > Windows > CurrentVersion > Internet Settings > Zones >
You will see folders numbered 0 1 2 3 4 etc...before that 0 foldder, if you see with a box type character. Delete that folder.
Close and restart your PC.
If not try uninstalling messenger and reinstalling.
Source(s):
HELP
Please let me know if this work.
Thanks & Regards,
Mar 22, 2011 | Yahoo Messenger
every time I log in to my yahoo messanger it stays on until I click on the person that want to talk to then it log off how do I fix this problem
uninstall yahoo messenger and download latest version, clean registry keys for it using registry cleaner reg in out, check preferences of yahoo messenger
Sep 14, 2010 | Microsoft Windows XP Home Edition
Code 41
You have a Registry error, which often happens with XP.
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software.
Restart you compute
Feb 13, 2008 | Dell Dimension 4700 PC Desktop
147 people viewed this tip
David Payne
David Payne
