Tip & How-To about Heating & Cooling
Home Electric Heat Heating and Electric
Electric heat can come in many different forms. Some of these methods are resistance heating, electric arc heating, induction heating, and dielectric heating. The most common of these is the resistance heating. With the resistance heating of electric baseboard heating, water heating and kitchen ranges, you don't have to worry about carbon monoxide or unvented gases. However, direct with electric is really not considered ecologically sound because most electricity uses fossil fuels. This is because about two-thirds of the energy of the fuel is lost within the power stations, and in transmission line losses.
Some of the most popular choices for electric heating systems are thermal storage systems, electric radiant heating, hydronic electric heating and even convective heating. You can also install an off-peak system that can save money and also give you the convenience of electric heat. An example of an off-peak electric heating system that is very common today is an electric plenum heater. Another newer form of heating is a convective electric heating system. Both use electric heaters to heat the air that is then circulated with blowers throughout your home.
Electric heating has several unique advantages. It can be precisely controlled to allow a uniformity of temperature within very narrow limits, it is cleaner than many other methods of heating. It does not involve any combustion and it is considered very safe because it is protected from overloading by automatic breakers. It is quick to use easy to adjust and it is relatively quiet. The main disadvantages of electric heating in industry are the higher cost of electrical energy compared to direct use of fuel, and the capital cost of both the electric heating unit itself and the electrical wiring required to deliver large quantities of electrical energy to the point of use.
Electric heat does have a place. One place where it does shine is in a seasonal cottage that will only be used a few times a year. It is very easy to shut down the heat and turn it back on when you get back there. There is also very little that can go wrong or go bad from the long periods of non-use. For this situation electric is a very good choice. This is really the only situation in which I recommend electric heating.
As you can easily see, electric heating has some advantages and some disadvantages. The cost of electricity has continued to rise and will be skyrocketing even higher in the future. Many states have or will be deregulated electric or are going to do so in the very near future. With the future uncertainty of the cost of electric and the great amount of waste in the transmission system of electric, many owners of electric heating systems are debating whether or not to convert to hydronic baseboard heating. With the super high efficiency of today's gas and oil boilers, they are quickly becoming much more attractive to many homeowners. Combining a high efficiency gas or oil boiler with hot water baseboard or radiant heating gives you great comfort and will give you low utility costs for many years to come.
Heating & Cooling Logo
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
WHAT IS RESISTANCE WELDING?
Electric resistance welding (ERW) refers to a group of welding processes such as spot and seam welding that produce coalescence of faying surfaces where heat to form the weld is generated by the electical reistance of material vs the time and the force used to hold the materials together during welding. Some factors influencing heat or welding temperatures are the proportions of the workpieces, the coating or the lack of coating, the electrode materials, electrode geometry, electrode pressing force, weld current and weld time. Small pools of molten metal are formed at the point of most electrical resistance (the connecting surfaces) as a high current (100-100,000 A) is passed through the metal. In general, resistance welding methods are efficient and cause little pollution, but their applications are limited to relatively thin materials and the equipment cost can be high. although in production situations the cost per weld may be as low as $.04 usd per weld depending on application and manufacturing rate.
Feb 02, 2011 | Computers & Internet
trying to check if the heater coil is bad. Is there a resistance across the coils?
Yes you should get resistance across the coil...it will vary from coil to coil....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
my headlight do not work i put in new light but it did not work
there is a box with many resistances( litle plastics with a methal thing inside to protect the system in case of over heat that mealt if there is a overheat) it might be located under the hood in a plastic box protected with a cover. is electric dash, these resistances are litle pastic sometimes they differ form color form each other.
look the one that have melted and replace them.
Jul 30, 2010 | 2005 Chevrolet Impala
the heater plug melted
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Jan 31, 2009 | Dimplex Compact Electric Flame Stove...
916 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
