Tip & How-To about Heating & Cooling
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
Heating & Cooling Logo
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
My friends to open a cosplay party, which role should i cosplay for?
Illustrating Aisaka Taiga! ! Super cute playfully sister (Sailor Costumes),
The humanoid computer Angel Heart grumble is also good (Gorgeous Dress)!
Jan 29, 2013 | Video Game Consoles & Games
how many types of barbie is in the international markets?what are they?
Barbie is made by Mattel and they keep a close watch on the patents here is a list of family and friends for you and the years made. Best of luck
Barbie's family
Siblings
* Skipper (1964–2003)
* Tutti (1966–71)
* Todd (1966–68, 1991–94, 2007)
* Stacie (1992–)
* Kelly (1995–)
* Krissy (1999–2001)
Cousins
* Francie (1966–1976)
* Jazzie (1989–1996)
Friends
* Ken (boyfriend, 1961–1967, 1969–2004, 2006–)
* Midge (1963–65, 1989–)
* Christie (1968–)
* Stacey (1968–70)
* P.J. (1969–85)
* Jamie (1970–72)
* Steffie (1972–73)
* Kelley (1973–76)
* Cara (1975–78)
* Tracy (1983)
* Dana (bandmate, Barbie and the Rockers, 1986–87)
* Dee Dee (bandmate, Barbie and the Rockers, 1986–87)
* Diva (bandmate, Barbie and the Rockers, 1986–87)
* Derek (bandmate, Barbie and the Rockers, 1986–87)
* Miko (1986–88)
* Whitney (1987–89)
* Bopsy (bandmate, Barbie and the Sensations, 1988)
* Belinda (bandmate, Barbie and the Sensations, 1988)
* Becky (bandmate, Barbie and the Sensations, 1988)
* Teresa (1988–)
* Nikki (1989)
* Kayla (1989)
* Devon (1989)
* Kira (1990–2000)
* Nia (1990)
* Tara Lynn (1993)
* Shani (1993, 1996)
* Kayla (1994)
* Marina (1996)
* Becky (1997)
* Lea (1999–2003)
* Ana Suarez (Generation Girl, 1999)
* Chelsie Peterson (Generation Girl, 1999)
* Lara Morelli-Strauss (Generation Girl, 1999)
* Nichelle Williams (Generation Girl, 1999)
* Tori Burns (Generation Girl, 1999)
* Mari Nakano (Generation Girl, 2000)
* Blaine Gordon (Generation Girl, 2000)
* Drew (Mystery Squad, 2001)
* Kenzie (Mystery Squad, 2001)
* Shawnee (Mystery Squad, 2001)
* Kayla (2002)
* Madison (My Scene, 2002)
* Chelsea (My Scene, 2002)
* Nolee (My Scene, 2003)
* Bryant (My Scene, 2003)
* Hudson (My Scene, 2003)
* Ellis (My Scene, 2003)
* River (My Scene, 2003)
* Sutton (My Scene, 2003)
* Delancey (Chelsea's cousin, My Scene, 2003)
* Jai (My Scene, 2003)
* Tyson (My Scene, 2003)
* Kenzie (My Scene, 2004)
* Ryan (My Scene, 2005)
* Simone (1 Modern Circle, 2003)
* Blaine (2004–06)
* Summer (Blaine's sister, 2004)
* Tori (American Idol, 2005)
* Simone (American Idol, 2005)
* Drew (Fashion Fever, 2004)
* Courtney (Fashion Fever, 2005)
* Gillian (Fashion Fever, 2005)
* Kurt (Fashion Fever, 2005)
* Desiree (Fashion Fever, 2005)
* Shannen (Fashion Fever, 2005)
* Tia (Fashion Fever, 2005)
* Kira (Fashion Fever, 2005)
* Kennedy (My Scene, 2006)
* Tia (Barbie Diaries, 2006)
* Courtney (Barbie Diaries, 2006)
* Raquelle (Barbie Diaries, 2006)
* Nikki (2006)
Other family members' friends
Skipper
* Ricky (1963–67)
* Skooter (1965–67)
* Fluff (1971–72)
* Tiff (1972–73)
* Ginger (1976)
* Scott (boyfriend, 1979)
* Courtney (1989–2005)
* Kevin (boyfriend, 1990)
* Nikki (1997)
Tutti
* Chris (1967–68, 1976–77)
* Carla (European release only, 1976)
Stacie
* Kelly (1991)
* Janet (1994)
* Whitney (1994)
* Lila (2004–05)
Kelly
* Becky (1996)
* Chelsie (1996)
* Melody (1996)
* Jenny (1997)
* Deidre (1997)
* Marisa (1997)
* Keeya (1998)
* Maria (1999)
* Tamika (1999)
* Nia (1999)
* Kayla (1999)
* Lorena (2000)
* Liana (2000)
* Desiree (2000)
* Belinda (2000)
* Nikki (2001)
* Kerstie (2003)
* Gia (2006)
* Tori (2007)
* Kenzie (2007)
* Miranda (2007)
Francie
* Casey (1967–70)
* Becky (2009)
Jazzie
* Dude (1989)
* Chelsie (1989)
* Stacie (1989)
Ken's family and friends
Family
* Tommy (brother, 1997)
Friends
* Alan Sherwood (boyfriend/husband of Midge, 1964 and 1991, 2002–present)
* Brad (boyfriend of Christie, 1970)
* Curtis (boyfriend of Cara, 1975)
* Todd (fiancé of Tracy, 1983)
* Derek (Barbie and the Rockers, 1986)
* Steven (boyfriend of Christie, 1988–. Linked with Barbie's friend Nikki since 2007)
* Melody (1 Modern Circle, 2003)
Midge's family
* Ryan Sherwood (Midge and Alan's son, 2002)
* Nikki Sherwood (Midge and Alan's daughter, 2003)
* Newborn Baby Sherwood (Midge and Alan's daughter, 2004)
* Grandma Hadley (Midge's mother, 2003)
* Grandpa Hadley (Midge's father, 2003)
The Heart family
* Dad Heart (1985)
* Mom Heart (1985)
* Megan Heart (baby daughter, 1985)
* Baby Boy Heart (Megan's twin brother, 1985)
* New Arrival Heart (1986)
* Grandma Heart (1987)
* Grandpa Heart (1987)
Cousins
* Kenny (1988)
* Kevin (1988)
* Honey (1988)
* Janet (1988)
* Melody (1988)
* Ne
May 08, 2010 | Barbie As Sleeping Beauty for Windows,...
WILL BE BUYING LCD TV IN NEAR FUTURE, BUT NEED TO MOUNT IN ON WALL WITH FIREPLACE, SEVERAL FEET ABOVE EYE LEVEL. CAN DO?
Absolutly, I have wall mounted a few dozen above fireplaces in the past 5 years; I can even send you over some pictures and suggestions come time for the install.
What is the wall material? Brick mantel or drywall with wood studs?
Although a TV looks attractive about a fireplace you have to consider that it is fatiguing to watch from such a high height. The optimal average height for a TV is 45" to centre (depending on furniture). If you exceed that by a few feet watching a lot of TV is awkward.
The advantage is it combines the focal point of the room, and instead of having a picture about a fire place, your TV becomes the work of art and can be used as a digital picture frame.
Jan 01, 2010 | Samsung LN52A850 52 in. LCD HDTV
1,094 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
