Tip & How-To about Heating & Cooling
Heating Circulating Water Pump Problems
Changing your circulator pump is not always an easy process.
I will attempt to explain some of the possibilities for changing out a circulator pump. First of all I would recommend that if you are reading this and you do not have an extra circulating pump in the basement beside the boiler. That you stop by your local heating and air conditioning supply house and buy one. For under one hundred dollars it will be cheap insurance.
The very first thing you need to know is the water temperature in the boiler. If the water is hot, 140F or above than the problem is not the boiler. It is heating the water. The next thing will be to see if there is power coming to the circulator pump. Either take the electrical cover off of the circulator pump motor, or check for voltage at the source of the wire going to the circulator pump. If there is no voltage, usually 110 volts for the US, then you have to look at why the motor is not getting power. I will do another article on that issue at another time.
So now we have established that you have power coming to the motor. There is hot water in the boiler however the pipes going to the radiation are cold. The next thing to look for, are zone valves. They are little motorized valves that open and shut to direct the flow of heat to different parts of the house or building. It is possible that one of them could fail and the circulator pump is running and moving no water. Usually the circulator pump will be making a noise and often be very hot if this is the case. Of course then you need to check the zone valve. That, we will also cover later.
The first thing you need to do to change the circulator pump is to make sure that the electricity to the circulator pump motor is turned off. Verify that the power is off before touching the wires. The wires then need to be disconnected at the pump motor. Then the 4 bolts that hold the circulator pump in place need to be removed. Save these bolts, they may be needed to install the new pump. Carefully remove the pump from the flanges. A pry bar or screw driver may be needed to break the pump lose from the old flanges. Be careful of the motor, depending on the type of failure, the motor can be very hot.
If you had a responsible installer do your heating system, then you will have a valve in the piping on either side of the circulator pump. These valves will isolate the circulator pump from the rest of the heating system and changing the circulator pump will be fairly painless. If you do not have valves closed to the pump, then you will need to find the valves that will be the closest to either side of the pump and close them. For some older installs there may not be any valves and you will have to drain most of the water out of the system to change the pump.
This can get very complicated and professional help may be needed. The hardest part may be refilling the system and getting the air purged back out of the piping.
To install the new pump, clean the old gasket material from the flanges and install the new gaskets on the new pump. Carefully insert the new pump with gaskets into the flanges. Be careful not to damage the gaskets. Then install the 4bolts that hold the circulator pump in place. Tighten the bolts just so they are snug and not too tight. If they leak a bit you can always make them a bit tighter to stop the leak. Too tight may damage the gaskets. Hook up the wires to the pump motor again. Open the valves back up and check for leaks. Adjust bolts as needed. Apply power to the system and start the motor to check the operation of the circulator pump.
http://www.fixya.com/support/r3696173-expansion_water_tank_boiler_expansion
http://www.fixya.com/support/r3695967-valve_pressure_reducing_or_pressure
http://www.fixya.com/support/r3584200-boiler_leaking_water__the_boiler_leak_ma
Heating & Cooling Logo
What would cause a circulator failure?
I am going to assume the circulator pump is on a hot water circulation loop. Turning the water back on could have stirred up the sediment that has collected in the bottom of the water heater. This could clog up and possibly ruin the impeller. Running for an extended period without circulating water can overheat and damage the pump also. It is a good idea to hook a hose to the water heater drain and flush out the sediment periodically. Hope this helps.
Jan 18, 2014 | Bell & Gossett 103252LF NBF-22 Circulator...
brakes will not hold pressure after bleeding them 4 times
I have never bleed brakes more than one time per repair, in 49 years
of doing so & had no issues,so explain the bleeding process
You didn't bleed 4 times, as you have no pedal pressure.
Old fluid out-- new in ,pretty easy ,no pumping ,just a helper
& open the bleeder valve
Nov 25, 2012 | Cars & Trucks
define the term psychology
Psychology is the science and art[1][2][3] of explaining and changing mental processes and behaviors.[4] Its immediate goal is to understand humanity by both discovering general principles and exploring specific cases,and its ultimate aim is to benefit society.In this field, a professional practitioner or researcher is called a psychologist, and is classified as a social or behavioral scientist. Psychologists attempt to understand the role of mental functions in individual and social behavior, while also exploring the physiological and neurological processes that underlie certain functions and behaviors.
Oct 21, 2010 | Acer Computers & Internet
Changing a belt is it a major job or as easy as taking the back cover off and replacing the belt? Whirlpool model #GHW9100LW1
For the model you have listed, changing a belt cannot be accomplshed by removing the back of the dryer. The following link explains step-by-step how to replace the belt on your dryer:
http://www.fixya.com/support/r3059469-install_dryer_belt_kenmore_elite
This can be a tedious process, but isn't difficult if you follow the steps provided. If you have any questions along the way, please let me know. I hope this helps you.
Oct 26, 2009 | Whirlpool GHW9100L Front Load Washer
Changing the circulation fan in freezer
Just becareful you do not cut yourself on the evaporation fins. Let the unit thaw out before attempting the repair is at all possible. It is pretty simple and easy. Do not let the fan blade bind up against the shroud or the motor. If it is a condenser motor use the new screws that come with the motor. Clean out the coils before you replace the motor while you have the old motor out. Pay attention to how the wire connect in case you get side tracked by a diversion. Write down how it all connected so you will not have to guess in the event you get an unexpected phone call or other distraction. As alway have the power shut down when doing any repairs on electrical equipment.
Apr 09, 2009 | Refrigerators
9,067 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
