Tip & How-To about Computers & Internet
Bsnl Broadband speed trick
Tip
1: One of the major problems with BSNL Dataone Broadband connection is the DNS servers they provide by default. Most of the timethey are very slow and sometimes they fail to respond. I noticed that Iam starting to spend a significant amount of time in DNS resolutionwith Dataone connection, often it is larger than the time it takes toactually get the reponse. Here is a simple solution to significantly speed up your DNS resolution.
Open up the network connectionprofile and
edit TCP/IP settings. In the DNS server address fields,specify the following
DNS server addresses: 208.67.222.222 and208.67.220.220
Disconnect the connection and then connect again. You are done.
This specifies third party DNS servers which are significantly faster than BSNL Dataone’s DNS servers.
Tip 2: Firefox users can use FlashBlock extension to preventdownloading of Flash content by default, thereby significantly speedingup browsing experience. You can click on the placeholder icon todisplay the original Flash content any time. This is more of a passivetip in that reduces data usage to improve your overall experience.
Tip 3: You can try to increase your broadband bandwidth tweaking theTCP/IP parameters. The process is simplified by using TCPOptimizer, afree tool. It helped me, your mileage may vary.
Computers & Internet Logo
How to cofigure my Dlink 502T modem for BSNL connection at chennai
If you want to connect and disconnect at your ease, the following steps will guide you through setting up a internet connection in windows using username and password whenever you connect.
Have a good time...
Step 1: Initial LAN Configuration First connect all the equipments to your PC. Details about this is probably given on the manual
Now on windows go to control panel -> Network Connections
Select “Local Area Connection” and right click it . . . Select Properties
Select TCP/IP in that box ->properties
Enter the details as follows
Set IP Address As 192.168.1.29 Subnet Mask As 255.255.255.0 Default Gateway As 192.168.1.1 Preferred DNS 208.67.222.222 Alternate DNS 208.67.222.220
Save settings and restart the computer.
Step 2: Settings for Modem Make sure the Power LED, Link LED and USB/LAN LED are on/blinking Open your browser (preferably Internet Explorer ) and goto http://192.168.1.1/ Input as follows USERNAME : admin PASSOWRD : admin
Now goto Setup Tab then click on new connection (left side navigation frame/panel)
Now fill the details as follows Name : BSNL
Type : bridge
Sharing : disable
VLAN ID : 0
Priority Bits : 0 Encapsulation : LLC Select LAN : LAN GROUP 1 PVC : new VPI : 0 VCI : 35 Leave all others at default values Then click apply The go to TOOLS tab Click “system command” (left hand side) Click “save all”
Apply and restart the modem.
Step 3: Setting up Internet Connection Dailer in windows Now goto Control Panel->Network Connections Create New connection (and a wizard will pop up)
Click Next
Connect to Internet(Select the radio button and click next)
Setup My connection Manually(select it and click next)
Connect using a broadband connection that requires a user name and password (select it and click next)
ISP name (type something, anything and click next)
Type in the User name and password given to you from BSNL in the specified columns (and click next)
If you want to add a shortcut of connection to desktop, check that square box and click finish.
Double Click the Icon in the desktop to connect to the BSNL Dataone broadband connection, and either double click the same icon or right click the system tray icon to disconnect from BSNL Dataone broadband connection.
Hope this will help you.
Feb 11, 2010 | D-Link Computers & Internet
My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
Jul 08, 2009 | Computers & Internet
Internet Bandwidth problem
try and get install polipo
it may solve ur promblem
Jun 17, 2008 | Computers & Internet
how to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
125 people viewed this tip
David Payne
David Payne
