Home | All Products | V803 Digital Camera | Tips
How to replace a defective LCD screen in a Kodak V803 Digital Camera
sharcnet
By Guru sharcnet
Rank: Guru
Rating: 92%, 1057 votes
posted on Jan 25, 2008
Very Helpful
This tip is for Kodak V803 cameras that will take pictures fine but you can only be able to see them if you download them onto a PC.
A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00.
To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector.
Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place.
Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard.
Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Comment by sharcnet, posted on Jan 28, 2008
Did I upset a Kodak tech? <grin>
Comment by sharcnet, posted on Feb 18, 2008
This procedure also works on the Kodak V603 (6 Megapixel) & V1003 (10 Megapixel) series cameras.
Was this helpful?
Yes
No
17 people thought this was helpful
Comment #1
posted on Sep 19, 2009
Patick Henry
By Apprentice Patick Henry
Rank: Apprentice
Rating: 0%, 0 votes
sharcnet,
You deserve the outstanding neighbor award.
I someone's selling the LCDs on ebay for $20.
Thanks again.
Comment #2
posted on Apr 25, 2009
rconway72
By Apprentice rconway72
Rank: Apprentice
Rating: 0%, 0 votes
Genious! I bought a Canon Powershot SX10 less than one month ago. It's got a swivel/articulating LCD screen and a co-worker closed the screen facing out instead of in and put it back in my purse. Needless to say, I was unaware and the screen got broken. I wasn't looking forward to paying a high repair bill for it, so I ordered the part from Canon. When I got the LCD apart and saw the orange cable and the motherboard connected to it, my heart sunk. Then I read this - same thing applied for my camera except you pull the black tab back instead of up.
You probably just saved me a bunch of money! Can't thank you enough! Yay!
Comment #3
posted on Dec 17, 2008
glrobins
By Apprentice glrobins
Rank: Apprentice
Rating: 0%, 0 votes
these screens can be bought on e bay for $29 with free shipping. one site offers to replace the screen for free if you send them the camera.
Comment #4
posted on Dec 09, 2008
Louiemacgoo
By Apprentice Louiemacgoo
Rank: Apprentice
Rating: 0%, 0 votes
Thank you X2! This is the second time I have had to replace the screen on my daughter's camera and this tip has saved me both times! And strangely enough Kodak ends up being the cheapest place to find the screen! Most places charge $49 plus shipping for this thing where as getting it from Kodak directly I can get it shipped to my home for $49 and some change. Wish I didn't have to replace the screen at all but since it's cheaper then buying a new camera and takes only about 15 minutes to replace this is surely the way to go! Thanks again!
Can you Help with these Digital Cameras problems?
camera v803 v1003 turns on ok, lens extends, but nothing...
I have had my Kodak EasyShare V803 camera for about a...
dropped camera when taking photo and the lens looked lob...
Lens cover wont close. Taking pictures then tried to...
My Kodak V803 LCD gives thermal&#160;like display...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
