Tip & How-To about Mitsubishi WS-55613 55" Rear Projection HDTV
Turns off by it's self
The set needs a software update. Mine came from a repairman. It is on a memory card and is inserted in the card reader. It comes with instructions.
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
what does insert update card mean? how do I fix it?
You download onto PC the upgrade from Janome.
Copy this to the card for reader on your machine.
switch machine on and go to section on screen for card reader
Insert card into reader. instructions should appear for downloading onto machine.
Hope this helps and is not too late
Sep 06, 2013 | Janome Memory Craft 9500 Computerized...
nokia 3110 not gets connected to pc via usb,or in bluetooth.It shows some execution files missing.plzz help me.
The software on your mobile is corrupted, may be due to virus. Remove the memory card & scan for viruses by using card reader connected to PC. Then update the software straight to your phone, with no need for a PC. The software updates keeps your phone at its best. To update software without using PC - Select Menu - Settings - Phone - Phone Updates. - Select the update which you want to install.
- For downloading follow the instruction on the screen You can take the help of user guide for software update.After updating & restarting the phone should work.Tip: Always remember to scan your memory card for any viruses. Such problems occur due to downloading applications, data from unreliable sources especially GAMES.
Aug 12, 2011 | Nokia 3110 Cellular Phone
how do i get a software upgrade for my tv
You will need a USB port or SD Card reader on the TV set in order to update the TV's Firmware. (note: some TV manufactures specify what types of memory are compatible with their TV sets i.e. magic gate, etc.)
Use the appropriate storage device for your TV set and go to:
http://www.support.philips.com/support/downloads.jsp?userLanguage=en&userCountry=us
Enter the model number in the search box. It will search for available software/firmware for your TV set. Download it and save it to your storage device.
Insert the storage device into the TV set. If the software/firmware update screen does not come up automatically, select update software/firmware from the TV's menu.
I hope this helps.
Feb 12, 2010 | Philips Televison & Video
I can't save images from my Fuji S5700 to my
Try removing the memory card and reading it through a card reader inserted into a USB port. Have you installed the program that came with the camera? I never used mine because I have other high end graphics programs and I always use a card reader instead of the cable. You WILL need the program if you want to do a firmware/BIOS update in the S700, and also the cable. The S700/5700 will only accept up to a 2gig memory card. If you want to use a 4 gig card, the camera (and also your computer) won't recognize the card until you do the update to the firmware. Available with instructions from FujifilmUSA website.
Jun 09, 2009 | Fuji FinePix S700 Digital Camera
679 people viewed this tip
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
