Tip & How-To about Cell Phones
Apple iPhone Battery Saving Guide The Apple iPhone doesn't have the best battery life in the world but if you follow this simple guide it should provide you with a longer battery life. 1. Turn down the brightness: You can reduce the battery consumption by turning down the brightness of the screen. Select Settings, Brightness, and then drag the slider to around the 25 percent mark, or as low as you can stand. 2. Turn Wi-Fi and Bluetooth off: From the main menu, tap Settings, Wi-Fiand select the "Off" switch. Same goes with Bluetooth; if you're notusing a Bluetooth headset, make sure the Bluetooth radio is deactivated(Settings, General, Bluetooth). 3. Check e-mail less frequently: If you are using Pop Mail then you can save battery by checking it less frequently. Select Settings, Mail, Auto-Check, and pick either the "every 30 minutes" or (better still) "every hour" options. 4. Sync less frequently: If you sync with an Exchange server either turn it to manual or set it only to check periodically 5. Make sure "Auto-Lock" is on: TheiPhone will keep its bright screen burning unless you manually pressthe lock/sleep control. If you haven't already, make sure the iPhone's"Auto-Lock" feature is on: tap Settings, General, Auto-Lock, and then pick a time interval (the shorter the better). 6. Turn off the equalizer: Apple has always suggested turning off the iPhone?s built-in equalizer to conserve battery life. Tap Settings, iPod, Equalizer, then spin the roulette wheel up to Off.
Cell Phones Logo
how do i open the battery of iPhone 5c
If you mean, replace the battery, its fairly simple. but you must have special screwdrivers to remove the screws, you can get these, as well as a replacement battery very cheap on ebay. here is a guide to disassembly and replacing the battery on an iphone 5c :)
http://www.imore.com/how-replace-battery-iphone-5c
Feb 22, 2015 | Apple iPhone 5c
iphone jailbreak
Hi, there. If you are willing to perform iPhone 4 jailbreak in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
You may unlock any iPhone including 4 and 4S models. This includes both the older and latest versions under 5.1.1. Enjoy more freedom with your iPhone!
Regards,
Vince
May 08, 2012 | Apple iPhone4 4G iPhone 4
free jailbreak iphone 3g 4.2.1
The guides are all here in FixYa. Jailbreak using the followin tools:
  1. redsnow - CLICK HERE to read the step-by-step guide
  2. sn0wbreeze - CLICK HERE to read the step-by-step guide
  3. greenpois0n - CLICK HERE to read the step-by-step guide
For more tips and tricks for iPhone, iPad and iPod touch, CLICK HERE.
Jun 17, 2011 | Apple iPhone 3G
Jailbreak iPhone 4.2.1
it is possible to do a untethered jailbreak, but i wont recommend it. Heres an article. Read it carefully: http://www.redmondpie.com/jailbreak-ios-4.2.1-untethered-with-redsn0w-0.9.7b1-how-to-guide/
Jan 10, 2011 | Apple iPhone Smartphone
The Battery on my Apple Iphone 3G
u better put ur mobile brightness low
Jan 09, 2009 | Apple iPhone 3G
169 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
