Tip & How-To about Cell Phones
Windows Mobile Activesync Setup
Configuring ActiveSync on a Windows Mobile Device
Before you start make sure the date and time are correct on the device.
  1. On phone 'Start' > 'Activesync'
  2. Click ‘menu’> 'Add Exchange server source'
  3. Enter your exchange server details
  4. Either untick or tick SSL depending on whether your server uses a secure certificate
  5. Click 'Next'
  6. Enter username
  7. Enter password
  8. Enter domain
  9. Click 'Next'
  10. Click 'Finish'
  11. Click 'Sync'
If the Exchange server requires the phone to have a certificate installed follow the steps below
You will need to have Activesync installed on your machine to complete this task. This can be downloaded from http://www.microsoft.com/windowsmobile/en-us/downloads/eulas/eula_activesync45_1033.mspx?ProductID=76
  1. Connect the phone to your PC using the data cable. A window will pop-up asking if you want to setup a partnership between your phone and your PC. Click CANCEL on this.
  2. Go to the location of the cetificate file & cut the file
  3. Open Microsoft ActiveSync on your computer and click Explore
  4. A new window should popup called "Mobile Device" or the name of your phone
  5. Copy the certificate into this window
  6. Disconnect your phone from the computer
  7. On your phone click start>programs>file explorer
  8. You should be able to see the certificate file>click on this file>after a few seconds a popup should say "One or more certificates were installed
  9. Try syncing your device again
Cell Phones Logo
My LG mobile keeps saying maximum number of applications reached each time i try and send a text HELP
That means there isn't much memory left. You will have to delete some applications:
The uninstall processes on LG Incite mobile phone are not complicated, three ways you can choose below according to situation/setup. LG Phone Problem and solution
1. Uninstall Apps Using ActiveSync LG-Incite info
For Windows XP and below users will want to use the ActiveSync program. You can download ActiveSync 4.5 here.
Once downloaded and installed on your desktop ActiveSync uninstalls are one of the easiest ways to remove unwanted programs, simply follow the directions below:
  1. Connect your LG Incite to ActiveSync
  2. Click on the "Tools" option
  3. Click Add/Remove Programs
  4. At this point you'll see a screen that lists all of your devices programs, each program will have a checkbox to the left of the programs name and all of your programs will have a checkmark located next to their names.
  5. Take out the checkmark in each program box you'd like to uninstall.
  6. Click "OK"
It's really that simple, your LG Incite will take a moment to uninstall the unwanted Windows Mobile Apps you chose and then you're done.
2. Uninstall Apps Using Windows Mobile Device Center
If you're a Windows Vista desktop user there's no reason to download ActiveSync, partly because it won't work, but more importantly because Windows Vista comes standard with the Windows Mobile Device Center, a device to desktop sync application that functions in much the same way as ActiveSync 4.5.
Uninstalling Apps with Windows Mobile Device Center is a simple process if you follow the quick steps below:
  1. Connect your LG Incite via USB to your desktop to launch the application.
  2. Click on the "Programs And Services" option
  3. Click the "More" option, You will now see a program box similar to the one found with ActiveSync 4.5.
  4. Each program will have a box with a checkmark, find the programs you'd like to uninstall and uncheck that box.
  5. Click "OK"
The unchecked programs will now uninstall from your device, its really that simple.
3. Uninstall Programs Directly From Your Windows Mobile Device.
You don't have to use a computer to delete programs from your LG Incite, if you're on the go uninstalling apps directly from your system once again involves only a few quick steps.
  1. Go to your "Start" button
  2. Go to "Settings"
  3. You'll see a "System" tab, click on that tab.
  4. Then go to "Remove Programs"
  5. Choose the Application you want to remove and highlight it.
  6. Click "Remove"
Your LG Incite will now remove the highlighted application.
Personally I usually use my computer for deleting apps just in case anything goes wrong during the uninstall process, however i've rarely heard of people running into Windows Mobile uninstall issues when doing so from their devices.
Conclusion
The 3 uninstall options listed above are the easiest ways to uninstall apps from your Windows Mobile based Pocket PC and Smartphone devices.
If these steps don't work your best bet may be to use the "Clear Storage" option on your Windows Mobile device and start your device with the standard fresh install, but hopefully it doesn't come to that."
Feb 28, 2011 | Cell Phones
How do I transfer files or applications from pc to the htc snap?
You need to install on your computer ActiveSync/Windows Mobile Device Center. To install this, insert the "Getting Started" CD into your computer and follow the setup steps. If you don't have the CD anymore, you can download the ActiveSync from this link.
Once ActiveSync/Windows Mobile Device Center is installed you connect the HTC Snap to your PC using the USB cable supplied with your HTC Snap, then you will be presented a configuration Wizard that will take you through the set up process.
You can connect the device to your computer using USB either as an External Drive or through Microsoft ActiveSync. If using Windows Vista, you will use Windows Mobile Device Center (WMDC) rather than ActiveSync. Simply plug the device in and choose an option on the screen of the device.
If you will use it as an External Device, you can copy data on it as you would copy on a USB flash drive, with copy and paste.
Another option is to use the bluetooth to transfer files, if you have a notebook which has bluetooth capabilities or you have a dongle.
Dec 20, 2010 | HTC Snap S521 Cell Phone
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
how i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
201 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
