Tip & How-To about Cell Phones
Mail for Exchange (Nokia Series 60 Symbian) Set Up
"Mail for Exchange synchronizes your business’s Microsoft Exchange service so employees can use their Microsoft Exchange inbox, calendar and contacts on their Nokia mobile devices. It is available for about 50 different Nokia device models.
  • Provides a cost-effective and easy-to-deploy solution leveraging the existing Microsoft messaging infrastructure.
  • Increases work efficiency by providing tools to more quickly respond to customers, colleagues, and partners.
  • Optimized for a wide range of Nokia devices, providing a mobile email solution on a handset that can meet any individual's needs and preferences."
If MfE (Mail for Exchange) is not installed on the phone you will have to download and install it via Nokia PC Suite.
Nokia PC Suite 7.1 Latest Version
Nokia Mail for Exchange 2.7
To Install MfE
  1. Assuming that Nokia PC is installed, download the latest version of MfE to your desktop
  2. Connect the phone to your PC using the USB cable
  3. Double click on the MfE file on your desktop
  4. Nokia Application Installer should pop-up asking 'Do you want to install the application to the phone' Press the green tick
  5. The Phone will now ask 'Install Mail for Exchange' Press 'Yes'. Press Continue on the next three pop-ups.
  6. A new pop-up will ask if you would like to create a MfE profile, press 'Yes'
MfE Setup
You will need the following details before you continue:
  • email address
  • domain
  • username
  • password
  • exchange server address
  1. In the setup screen enter e-mail address, username, password, domain
  2. The phone will then try to find the exchange details, it should automatically configure the service for some servers. If it fails the next screen will prompt you to enter the server address.
  3. After you have checked all the details are correct press options>save. The phone will then try sycning
  4. If the server uses a certificate it will ask you to accept this, select the option to accept everytime
  5. Once you have completed these steps the phone should then automatically sync. If not simply press options>sync
There are various settings that you can change depending on how you want the phone to function, these can be found in Options>edit profile.
Cell Phones Logo
how to use out look on i pad
The answer is yes, You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
  • If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
  • Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
  • Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
  • Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
  • Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
  • Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
  • A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
Jul 29, 2010 | Apple iPad 32 GB WiFi Tablet PC
Aloha! i just got a new ipad and would like to
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
Jun 19, 2010 | Apple iPad 32 GB WiFi Tablet PC
how can i connect my htc s20 with my pc
You will need active sync
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx
To install and set up ActiveSync on the computer
1. Install ActiveSync on your PC, as described on the Windows Mobile®
Getting Started Disc.
2. After Setup completes, the Synchronization Setup Wizard
automatically starts when you connect your phone to the PC. The
wizard will guide you to create a synchronization
3.Select the information types to synchronize between your phone and
computer.
If you will synchronize your phone with both your computer and
Exchange Server, do the following:
• For the Contacts, Calendar, E-mail, and Tasks items, choose whether
to synchronize them with the computer or with the Exchange
Server. These items cannot be synchronized to both.
• Select the check boxes of the other information types if you want
to synchronize them with your computer.
4.Click Next.
5. Click Finish.
When you finish the wizard, Active Sync synchronizes your phone
automatically. Once synchronization completes, you can disconnect your
phone from your PC.
After that if you setup the program correctly every time you will connect your phone with computer will be automatic synchronized
Jan 08, 2010 | HTC S620 Smartphone
how do I synch outlook 2003 with iphone
You didn't say whether you're trying to sync everything (mail, calendars, contacts) or just some things or one thing (like contacts only). I don't know if you're using an Exchange server or even if you have the info you'll need to sync with an Exchange server.
I have a Windows mobile device (AT&T Tilt) running Outlook 2007 and everything is sync'd. We also started purchasing the iphone for our employees and sync their email, calendar and contacts to their phone.
I could probably give you step-by-step information (based on how I do this for my users at work) if I knew whether you'll use iTunes to do this or Exchange Active Sync and what you want to sync between your phone and outlook. One method (iTunes) will only update your data between Otulook and the phone when you connect it to the computer with Outlook configured on it but, the way we do it at work, they receive email, data, changes, etc in real time.
Try using this link http://www.apple.com/support/iphone/mail/
What you will find here is support topics and instructions for Exchange Active Sync, setting up email accounts, troubleshooting for contact and calendar syncing.
You can also search support on Apple's Web site. Entering the keywords: iphone outlook 2003 will bring up a lot of support info.
You can use iTunes or MobileMe for synchronization. If using iTunes then try this:
You can configure which items are synchronized during a one time set up process. After initial set up, each time you connect the iphone to your computer, the changes made on your computer or device are synchronized.
  1. Connect your iPhone to your computer. iTunes should open automatically.
  2. In iTunes, in the source list, under Devices, click the entry for your iPhone.
  3. Click the Info tab.
  4. Select which items you would like to sync. For example to sync only calendars, under Calendars, you would click Sync calendars from, and then click Outlook.
  5. Do one of the following:
  • To synch all calendars, click All Calendars.
  • To limit the calendars that are synched, click Selected calendars and then click the calendars you want to sync.
6. Click Apply.
Hope this helps!
Thanks for using Fixya and you can let me know how helpful I've been by rating this solution.
Apr 03, 2009 | Apple iPhone Smartphone
Could not read the next message from the desktop mail system's inbox
PocketMirror does not control mail synch. It's a common misconception that Chapura PocketMirror synchronizes email. It only synchs Contacts, Calendar, Tasks and Notes from Outlook. The Mail or VersaMail conduit from palmOne is responsible for email synch. It sounds to me like you have a bad record or two in your inbox. You could try moving all your current inbox messages to a temporary folder to see if this breaks the log jam. Then you can start to hunt for the bad one by replacing them in portions and re-synching.
Sep 11, 2005 | Palm Vx Handheld
257 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
