Tip & How-To about Computers & Internet
How to speed up computer using windows xp
Windows xp was very effective because instead of using normal RAM placed on the motherboard as a solitary unit, they created virtual RAM. The Virtual Ram is depended on the size of the hard disk that windows is installed on from the default setting (It might take 20% of your space temp.).
In order to make your pc fast you'll need to be sure that the space will not be used so it can be reserved for RAM.
Steps:
1.) Right click on "My Computer" and go to Properties.
2.) Under the tabs at the top got to advanced.
3.) Under Performance got to settings.
4.) Once Again go to the advanced tab.
5.) Click on change under the virtual memory section.
6.) If its not already selected, go to custom size and choose the minimum and maximum size.
This will make you computer reasonably fast compared to before(You may assign RAM to additional drives aswell to speed it up if you have any.).
Please rate me good/bad!
Computers & Internet Logo
My favourite programme - Print Artist 4 which has worked with all my computers up to and including XP will not work with Windows 7 - what can I do?
It means that this application is not compatible with Vista or Windows 7. If you have Windows 7 Pro or Ultimate, all you have to do is run the app in XP mode, which is really running an XP virtual machine inside of Windows 7. Just look in Windows help for instructions on how to do it. If you have Home Premium or less, they do not have XP mode. Instead you can download Virtual PC 2007 SP1 from the Microsoft web site for free, install it, then create a virtual machine that uses XP. You will have to have a licensed copy of XP to install on the virtual machine. Then install PrintArtist on the virtual machine and you are ready to go. You can use the virtual machine and Windows 7 on the host system simultaneously and can even exchange data between the two.
Feb 11, 2010 | Computers & Internet
my hard drive never stops
Windows is probably constantly trying to create virtual memory using the hard drive's free space. Buy more RAM and/or create a larger virtual memory file. If it's Windows XP, try right-clicking on My Computer, Properties, Advanced, Performance, Advanced again, Change (under Virtual Memory), increase the Initial Size to AT LEAST what is "recommended" lower down on that screen but no more than 1 1/2 times the actual physical RAM, then click Set.
Jan 01, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
i need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
FREEZE
this happens if the rams are of different frequencies have a check with the both the ram frequency ...
if they are different then remove 1 ram ....
& try increasing the virtual memory in the OS ...
if you are using the windows xp .. then to increase the virtual memory just go to
control panel >system>advanced>advanced>virtual memory settings>increase the virtual memory for the drive in which the os is installed ....
increase nearly to the double of the ram memory you use ....
this solves your problem ..
any doubts you can reply me
i am always here to assist you
thank you
bye .....
dnt forget to rate the solution ...
Jun 22, 2008 | MSI KM4M-L Motherboard
Problem with Mercury PI845GVM motherboard
fine ur problem if very simple as u installed 512 mb RAM on ur pc if at possible try to connect on to the other slot and restart the computer and check ur RAM capacity in ur os if it shows as same 256mb then ur have to change ur virtual memory settings i.e memory allocated to the video so configure ur virtual memory as per requirement then free up RAM memory ..
Steps for virtual memory configuration.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Apr 12, 2008 | Intel Motherboard
232 people viewed this tip
David Payne
David Payne
