Tip & How-To about Computers & Internet
Computer or laptop turn off automatically after sometimes
This reason comes due to over heat of processor.
solution-
1. check the heat sink fan is running or not
2. chech is there paste between heatsink and processor.
after solving these problem if your problem exists.
then it may be due to slowly of the fan speed and the heat sink goes over heat.
so, open the stiker over fan then put 1 or 2 drops of oil in the hole. then run your fan by manually your hands if the fan goes ok then re install it.
now your problem is finished.
Computers & Internet Logo
COMPUTER SHUTS OFF
There are several reasons for Auto shutdown of the PC, it can shutdown due to CPU processor overheating, Hardware conflict, SMPS voltage supply issue. what ever may be the reason, if you have knowledge of assembling then you can try below steps
1. Open the cpu cabinet and remove the heatsink then clean it.
2. clean the CPU Fan (use some spray like WD40)
3. Remove the old heat sink paste from the processor and apply heatsink paste and refix all the hardware.
4. check the voltage supply of the SMPS (power supply unit)
otherwise you can call computer hardware engineer and get the problem fixed.
Apr 18, 2014 | ASUS M11AA-US002S Multimedia Desktop PC
Just on normally but of 1,3,4,5 min automatic of
check the processors heat sink. if it is too hot then it is overheating.
buy a small amount of thermal paste. remove the heatsink together with fan from the processor. remove the gray or white color like grease. clean it then dry. put the thermal evenly unto heat sink and top of processor. put back heat sink and fan. then test run.
Aug 23, 2013 | MSI Computers & Internet
Dark speck on processor
It may be the temperature problem. If the heatsink and the fan does not sit tight on processor the heat from the processor will not be dissipated properly and the heat rises up and the processor shuts off as soon as it starts working. So please see that the heat sink and the fan on the mother board sits tight. Also apply heatsink paste on the surface of the processor which comes in to contact with the heatsink. It comes filled in Syringe and retails around Rs.10-20 only. I think it will solve your shotdown problem.
May 10, 2013 | Intel Computers & Internet
How to overcome overheating issue in my desktop?
Depends on what's overheating. If it's you processor you have to replace the thermal paste between the heat sink and the processor, if it's the ram you need to make sure it has proper ventilation, if it's the hard-drives the same etc. You need to be more specific.
Oct 19, 2011 | Computers & Internet
amd athlon heatsink
If you don't install the heat sink and fan carefully you could blow out your processor. Make sure you clean all the old heat sink paste from the processor and the heat sink. Then apply a thin layer of paste like "arctic silver" on the heat sink so that it makes full contact with the processor. I think you have a socket A processor...so do a google search for "installing a socket A processor" and you should have all the info you need. Good Luck...Hank
Jan 12, 2010 | EPoX EP-8KRA2+ Motherboard
146 people viewed this tip
David Payne
David Payne
