Tip & How-To about Office Equipment & Supplies
Blocked heads on an Epson inkjet
If after cleaning the heads on your Epson printer, if you still have that stubborn blocked nozzle, do another head clean, then do NOTHING with the printer - nozzle check etc - leave the power on to the printer and leave it overnight. The head will have been set into the head cleaning park position and will soak overnight in a bath of ink. This can loosen and soften the ink in the blocked nozzle. Now do another head clean and most reluctant blockages will be cleared.
i have an epson stylus 515 i print something and i comes out blank what would you think it could be
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 18, 2012 | Epson Stylus NX515 All-In-One InkJet...
my epson black ink wont print??
Oct 10, 2012 | Epson Stylus Sx235w Inkjet Copy Print Scan...
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink cartridge?
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson RX650 with a G5 Mac. Printing beautifully,now pgs are blank
It definately sounds like blocked print heads, try head cleaning 4 or 5 times, leave overnight and try another 4 or 5 times the next day. This usually works, if not you will need to try something a little bit stronger. Try this link:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Blocked print heads are more far more common if you are using non-genuine Epson inks. Please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
611 people viewed this tip
k24674
jasbo
jasbo
