Tip & How-To about Computers & Internet
Install Windows From Usb Drive
Windows 7 can run on machines with lower specs than required for Windows Vista, and many users are actually finding it runs better than Windows XP on lower spec machines. It’s also ideal to run on newer netbook machines, but unfortunately many of these do not include a DVD drive so how do you install windows 7 on a machine without a DVD drive?
I spent yesterday researching this exact problem and I managed to install Windows 7 on my LG X110 netbook in around 20 minutes using a 4GB USB Drive. Setting up the USB drive to install Windows 7 was fairly easy in the end, and the installation was quicker than a DVD drive, so this method is perfect if you want to install Windows 7 quickly on several machines.
How To Install Windows 7 From A USB Drive
  1. Find a standard 4GB USB Drive and plug it into your machine
  2. Click Start in your enter ‘cmd’ in the run field. Once cmd is open type in ‘diskpart’ and a new window will open
  3. In the new diskpart window type:
  • ‘list disk’ : This lists all the disk drives attached to your machine
  • Look for your USB drive and note the number and then type: ’select disk #’, where ‘#’ is your USB disk number
  • then type ‘clean’
  • then type ‘create partition primary’
  • then ’select partition 1′
  • then ‘active’
  • then ‘format fs=fat32 quick’
Once you’ve finished these steps you then need to copy your Windows 7 files to the USB. To do this you have to mount your Windows 7 ISO as a virtual DVD. Doing this is easy:
  1. Install MagicDisk (free)
  2. once installed, right-click on MagicDisk in your system tray click on ‘Virtual CD/DVD-Rom’, select your DVD drive
  3. then ‘Mount’ and in the dialog window that opens up, select your Windows 7 ISO
  4. Now in windows Explorer, click on your DVD drive and you should see all the Windows 7 Files. All you have to do now is copy and paste all the files to your USB key and you have a Windows 7 USB Installation Stick!
  5. Install the stick in the PC you want to install Windows 7 on and boot up. Remember to change your bios to allow booting from USB
If you follow the steps above then you should have no problems installing Windows 7 from a USB key
Computers & Internet Logo
My embroidery (Singer Quantum XL6000) requires the Windows XP and lower on a computer to acquire additional patterns, will it work with Windows 7?
Mine works with Vista. :)
Just install the XP patch (futura-support.com/downloads/patch.htm) and tell Windows 7 to run the software in XP mode.
Oct 07, 2011 | Singer CE-200 Quantum Futura Computerized...
Running ubuntu on (old!) hp e-pc 42; need Windows. Would it be worthwhile installing Vista? How about 7? Thanks.
Based on the specs of your computer I don't recommend that you upgrade to either one of those. You would not want to use Vista because it would run really slow on your computer, and Vista itself is not very good. And if you can't run Vista, you most likely can't run Windows 7 because it requires even more than Vista.
I recommend that you use Windows XP, not only because aside from Windows 7 and Snow Leopard it is my favorite Operating System, it is also the OS that was originally shipped with that specific model computer.
Short answer: Go with Windows XP
Hope this helps!
Mar 19, 2011 | HP e-PC 42 PC Desktop
I have a Gateway Performance 500 PC using Windows 98 operating system. Can I update or do I need to replace this computer?
I would expect it would be much easier...and probably cheaper in the long run...to replace the computer. This machine does not meet minimum specs for Windows 7, and XP is no longer supported. Vista is an option, but requires as much in system resources as 7 and 7 is a much better (IMHO) system. This machine uses a Pentium III CPU and won't manage sufficient RAM to do a decent job with a modern OS. Windows 7 has an extensive driver library built in.
Hope that's helpful.
Dec 31, 2010 | Gateway Performance 500 Deluxe PC Desktop
can i upgrade to windows 7 ( I will increase memory to 1gb)
Windows 7 advisor is available for download from microsoft.com website.
Windows 7 requires less hardware specs. than Vista did and if the computer ran XP, then it is likely it will run Windows 7 effectively.
Oct 23, 2010 | Computers & Internet
COREL x4 running very slow & spooler problem
System Requirements:
Processor:
# Pentium III, 800MHz or AMD Athlon XP
Operating System:
# Windows XP with Service Pack 2 or later
# Windows Vista (32-bit or 64-bit editions)
Hard Disk:
# 430 MB
Memory:
# 512 MB RAM
Optical Drive:
# DVD-ROM
Other:
# 1,024 × 768 or better monitor resolution
# Mouse or tablet
Where these are the minimum specs I would recommend at least 1+gb memory and a good graphics card and a P4 or AMD processor running at 1.8ghz or better, and that would depend on how in depth you get into the program
Mar 10, 2008 | Computers & Internet
174 people viewed this tip
David Payne
David Payne
