Tip & How-To about Computers & Internet
Top 7 Tips for Windows 7 Maintenance
Want to keep your Windows 7 running as fast and stable as new? Updating hardware configuration and protecting your PC from being attacked by virus and spyware is indispensible, but, that’s not enough, even with the "impressive/promising" Windows 7.
Well, there is no rose without a thorn. For enjoying the non-compromised features of Windows 7 and keeping its freshness as long as possible, you can take the following top 9 tips for Windows 7 maintenance, and save your time, money as well as get full control of your PC!
Windows 7 Maintenance Tip 1: Cleanup hard disk
Windows temporary files, internet cache, cookies, invalid shortcuts and unused files and programs can take up much room on your hard disks. Even you have just upgraded to Windows 7, those junk files can soon accumulate and eat up hard disk space. So regular disk cleanup should be part of your Windows 7 maintenance routine.
Windows 7, as its predecessors, has a built-in Disk Cleanup program, you can find it in Start>Accessaries>System Tools>Disk Cleanup.
Windows 7 Maintenance Tip 2: Defrag hard disk
Your hard drive can be full of fragmentation with time, which dramatically slows down Windows running. Microsoft OS including Windows 7 provides the built-in Disk Defragmenter tool, which lets you remove empty patches, pack pieces of files together, and thus occupy contiguous storage locations, increase the speed of reading and writing files to/from hard disk.
Frequency: Disk defragmentation should be performed every two or three months, because frequent disk defragmentation can decrease the span of hard disk.
Windows 7 Maintenance Tip 3: Speed up Windows 7 boot
Open Run, input “msconfig”, then select “Boot”, you will see a list of programs in that auto-start folder. You can manage them there.
Windows 7 Maintenance Tip 4: Scan and repair registry
Registry is the central database of Windows which stores the necessary information and settings for software and hardware running smoothly. Even you have uninstalled a program, respective information is saved there. Windows registry can be full of errors that cause the main system crashes, error messages, freezes and slowdown. You will be amazed when you view how many errors exist in your registry.
Microsoft experts never suggest people to manually change their registry, since any improper operation to registry can cause serious damage. Instead of taking that risk, using a third-party safe Windows registry optimizer might be better. You may refer to this article and learn .
Windows 7 Maintenance Tip 5:Defragment registry
Just like hard drive needs defrag, registry needs too. Registry defrag is to remove fragmentations and creates a linear registry, which can speed up registry access and program response. Some defragger also compacts your registry to a smaller size, thus it can take up less memory and make room for other programs running fast. There is a free registry defrag software which can safely defrag registry in two minutes for most Windows systems.
Windows 7 Maintenance Tip 6:Uninstall unused programs
Uninstalling programs that you seldom use is better than just removing them from your hard drive., because simple deletion can cause Windows errors. Some programs have the built-in uninstall app while others don't. Then you can go to the control panel and uninstall them. For those malicious programs that don’t allow you to uninstall, you can make use of a third-party uninstall manager (known as built in Wondershare Registry Optimizer) to get rid of them.
Note: cleanup registry is necessary after the uninstallation. Detail is given in the following part.
Windows 7 Maintenance Tip 7: Boost performance by adjusting registry parameters
This step is to change registry parameters designed to boost Windows 7 system performance, such as automatically end hung applications, optimize internet connection, speed up loading web pages, speed up Windows shutdown, etc.
There are many online tips talking about how to manually revise registry settings for better system performance, but manual revisement fits more for computer expertsor than for beginners. Beginners has better use a system optimizing utility (known as built in Wondershare Registry Optimizer) to have this done in single 1 mouse click.
Computers & Internet Logo
my hp 530 is very slow and it freezes
The HP freezinng issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try http://www.speeduphp.com/hp-laptop-freezes.html to give a free & full scan of your slow HP PC to find & fix all possible issues.
Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance. But that won't be the most economical way, as you know you can't always afford to do that.
Nov 21, 2011 | HP 530 Notebook PC
PC keeps restarting as power button is pressed without booting
Hi
This type of symptom will appear when your system windows corrupt, the windows will corrupt of following reason.
  1. Virus attack and the your not using any Anti virus for protect the windows.
  2. The user delete the system file,
  3. Not select the correct boot device.
check the all reason. and sure if you are using correct boot driver after that you system keep restarting then you have to install new windows in your system.
For installing the new windows Visit the link"http://pacificbits.ucoz.com/news/install_the_new_windows/2011-04-01-8"
Cheer
Cheer
Jul 10, 2011 | HP Compaq dc5000 Microtower PC Desktop
I am trying to reboot the computer and it just goes to a black screen with the arrow
Hi there!
Try to access the Advance booting option by press F8 continuesly when start up boot and run the safe mode. Your computer will run on mini drivers loaded and low VGA graphic and uninstall software or hardware that corrupted your operating system or run virus scan if virus attacked your computer.
Try also to run system restore to bring back your old configuration but back up your files before doing this. Go to start menu, choose accessories, choose system tools, choose system restore and choose the date with with good configuration settings.
Effective way to repair your black screenis to put Windows installer CD or system back up disc into the CDROM drive and run the repair mode. This will fix the errors in your computer.
I hope it helps you.
Jan 27, 2011 | Toshiba Satellite A215-S4747 Notebook
146 people viewed this tip
David Payne
David Payne
