Tip & How-To about Computers & Internet
Dell Portable Battery LED flashes Orange 4 times then Green once
This LED flash pattern, Orange, Orange, Orange, Orange, Green (Repeats) indicates a internal failure of the Battery. Pressing the charge indicator button on the battery (If equipped) will give a 1 3 5 LED on indication which also indicates a failure in the battery.
The battery may still function, but at less than optimal performance and will have a progressively shorter functional life until it dies.
The only way to resolve the issue is to replace the battery.
Computers & Internet Logo
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
May 25, 2012 | Dell Inspiron Mini 10v Netbook Computer
dell latitude d810 battery light flashes 4 orange and one green
This indicates an internal failure in the battery. While the battery may hold a charge and function, the system has determined an internal failure (Cell with low or no voltage etc) and the only way to resolve the failure is to replace the battery
Dec 19, 2009 | Dell Latitude D810 Notebook
battery light 4 times is red and one time green in all the time
the battery LED is indicating an internal battery failure. While the battery may still work, the LED indication will not change until you replace the failing battery. It can be an indication of a Failed Cell, low voltage etc. Something in the battery is no longer meeting specification and that triggers the LED indication.
ONLY RESOLVE, NEW BATTERY
Apr 11, 2009 | Dell Latitude D610 Notebook
latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
Jan 31, 2009 | Computers & Internet
2,966 people viewed this tip
David Payne
David Payne
