Tip & How-To about Washing Machines
Simple Tips to Make Your Washing Machine Last Longer
  1. DON’T OVERLOAD: Overloading not only is damaging to your clothes but also puts unnecessary stress on vital components. Compare overloading your washer to pulling a loaded trailer behind your family car all the time. Extra strain on the motor, transmission and suspension will most certainly shorten the life of your car. Oh, did I say your washer also has a motor, transmission and suspension?...How does overloading damage my clothes? Rubbing together of cottons causes linting. The more rubbing together the more linting and the shorter the life of the garment.
  2. DRAIN HOSE HEIGHT: Be sure to follow manufactures directions regarding proper installation. Washers have small pumps, either self powered or driven by belt off main motor. Ideally, the drain hose should hook into a drain pipe directly behind the console of your washer. If your hose is too high the pump takes longer to evacuate the water from the tub putting stress on your washer and possibly reducing cleaning effectiveness. Too low a drain hose and your water could siphon out of the unit during the wash cycle. I have been on calls where the customer said there washer would wash, stop, fill, wash, stop, fill etc. Water was siphoning from the tub.
  3. RUSTING: Clean surfaces frequently to avoid rusting, especially clean around the bleach dispenser as bleach is corrosive and will cause severe rusting if not kept clean and dry. If rusting has already appeared go to your hardware store and pick up a bottle of rust converter (not rust remover). Follow directions on bottle. This works very well on rust. It can also be painted over after 24 to 48 hours.
  4. SOAP SCUM : To reduce the build up of scum fill your washer with warm water, add a pint of vinegar and let it run through a full cycle.Follow this procedure once a month.
  5. BUY OEM PARTS: When replacing parts on your washer, be sure to buy genuine Whirlpool parts, Frigidaire parts, Kenmore parts, Maytag parts, or parts for whichever brand washer you have. This will guarantee you are using the most reliable replacement parts available.
Washing Machines Logo
Why does my dryer make a load bang mid cycle?
You are overloading your machine, and in mid-cycle, the clothes are becoming out of balance. Try running the dryer with smaller loads. You will find that the clothes will come out of the dryer with fewer wrinkles, and that your items will be less likely to be damp after a drying cycle. If you continue to overload your machine, you risk breaking of belts or otherwise damaging your machine. You also may decrease the life of the clothes you dry since overloading is also hard on seams and fabrics.
May 11, 2014 | Audio Players & Recorders
freezer works great but the refrigerator don't work. any ideal
Remove any things that will hindrance or block to the flow of cold air inside the refrigerator. Often the fan is block with food stuff or bottles, cans of drinks. Rearrange it correctly and also clean the fins of fans. Pullout unnecessary things and clean the inside. Put some allowances to the things inside. Overloading of food stuff really make it hard for the refrigerator to cold it. It takes longer for a overload food stuff to eliminate heat outside and cool then cold it.
It's a pleasure to help you.
Jul 03, 2011 | Dometic RM2852 Refrigerator
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Sep 01, 2009 | Maytag Washing Machines
Turn off ALARM - Whirlpool washer
This sounds like the imbalanced load alarm. This can occur with large heavy loads like blankets, bedding, lots of diapers (cloth), jeans etc. The best solution is to wash lighter loads and not overload the machine. If overloading continues, the machine could be damaged.
Apr 11, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
kenmore washer model # 110.24086200
The C1 code indicates the "instantaneous current limit" trip. This signifies problems with the drive motor, thermal protector, motor controller. Overloading the machine will cause high amps and trip the unit. Instantaneous current trip occurs if there is a current spike of 26 amps instantly at the motor windings in which the motor overload trips. check bearings for lubrication - or as stated above overloading the washer.
Sep 06, 2007 | Kenmore Elite 45986 Front Load Washer
539 people viewed this tip
Top Washing Machines Experts
