Tip & How-To about Garden
How do I get the pump off my pressure washer?
Removing the pump from a pressure washer can be easy, or it can be extremely hard. The first thing is knowing what you are going to remove and what you are not. Whether on an electric motor or a gas engine( the power source), a pressure washer pump consists of three parts; The manifold( the brass or aluminum part the water comes out of), the transmission( the oil side of the pump) and the flange( where it bolts to the motor or engine).
When removing the pump to replace it, you need to remove it at the flange. Normally after you take the three or four bolts mounting the flange to the power source, the pump will slide right off. Sometimes however, years of sitting out in the weather makes the pump stick on. There also might be a set screw holding the hollow shaft on to the shaft from the power source.
Make sure any set screws are loosened and try to pry the pump off by sticking a screwdriver between the power source and the pump and gently prying. If that doesn’t work try sticking the bolts back in the flange but very loose and starting the power source. The vibration from the motor or engine will break the pump loose most of the time. After that, if the pump is still firmly attached, you may need to either knock it off with a hammer (this will most likely damage the pump beyond repair) or use a torch and cut it off (this will damage the pump beyond repair and there is a chance you will damage the oil seal on the power source). If worse comes to worse you can take it to a qualified service center and have them remove the pump for you.
Garden Logo
will not pump above 3000psi?
probably has a relief valve in the pump head that prevents over pressure from damaging the pump
3000 psi is extreme for a pressure washer and will remove paint from a vehicle , blow out gaskets on engines , remove cement surface , peel timber surfaces
Sep 08, 2015 | Comet TW 5050 S - Pressure Washer...
srmw 2.2g26. Can the pump be rebuilt with a kit?
There are two options for this pump regarding rebuilding it. You can purchase all of the repair kits individually, or just buy the complete replacement pump head with all components already installed. This is the easiest/most reliable way to address the repair of the SRMW pump. It is also extremely easy to install, and can be done in less than a minute since you do not even need to remove the pump from the pressure washer (this is the complete pump head that can be found online:
http://www.ppe-pressure-washer-parts.com/product/1001.6677
Oct 03, 2013 | Briggs & Stratton Garden
how to change powerstering pump chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Dec 13, 2012 | 2008 Chevrolet Uplander
Loose change
the tub oo this machine just sits on apost, weight of the tub only thing holding down, you will needa putty knife adn insert it about 3 inches in from either side t o "pop" the top hold down clips, the main lid assy will the tip back wards, next remove the outer tub cover (10 or so clips holding around the outside of outer tub.) after that the inner basket should lift right up and out. reaasmble teh same way.. be carefull the outside if the inner basket is extremely sharp from all those holes
Mar 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
4,726 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
