Tip & How-To about Kenmore 15899 Built-in Dishwasher
How to remove heating element from dishwasher.
1)      First of all, turn the circuit breaker off  to the dishwasher . The circuit breaker is located  inside  your    home's electrical panel.
2)      After the circuit breaker is turned off , open the dishwasher door and carefully pull the lower dish rack out of  the dishwasher.
3) Then look at the  dishwasher's heating element. The heating element is the very thin, circle shaped  tube  located at the base of your dishwasher.
 4)  Then locate the access panel to the dishwasher  which is directly below the door. Properly remove the screws that secure the access panel to the dishwasher with a proper  screwdriver. There are mostly   two screws at the top edge of the access panel. To remove the screws, you will need to open the dishwasher door and remove them from the access panel.
5) Then carefully pull the access panel out  from the dishwasher. You can use a flashlight to locate the wires that are connecting  to the heating element terminals( the two ends of the element).  One wire is connected on each of the terminal ends. The heating element terminals are located at  the rear of the dishwasher.
 6)Slowly pull the wires out  of the heating element terminals. Hold the wire at the metal leads where they connect to the terminals. If you hold  the wires anywhere else, the wire may get cut in between or wire may break out.
7)Then  you will have to remove the nut  located on each terminal .The nut  secures the heating element tight  to the dishwasher . You have to remove the nut. After the nut is removed , then pull the flat washers and the rubber washer from each terminal.
8)      Then carefully open the dishwasher door and  properly un-clip the heating element from the holding  clips in the bottom side of the dishwasher. Then hold  the ends of the heating element and without applying force on any other part slowly pull them straight out of the dishwasher bottom. You will see two rubber grommets. That should come up out with the terminal ends. If the grommets  does not come up with the terminals and remain stuck up in the bottom of the dishwasher, then pull them out of the holes with bit of force.
9)      Now the heating element is out. You can get new replacement element from local appliance part store. You can reinsert the new element in reverse instructions of how you removed the old element.
Good luck.
Kenmore 15899 Built-in Dishwasher Logo
12 kitchenaid DW, dashboard goes out. Turn off breaker, then on, DW works. 8 times in 90 days. Serviced after the first several times. Nothing found. Ideas?
I don't know what else is on the circuit with your Dishwasher, but it is possible that you have a defective circuit breaker, or corroded wiring at the circuit breaker or at the dishwasher. Maybe too many gadgets on he same circuit and you are tripping the breaker. The dishwasher may have an internal circuit breaker that needs replacing. some thing to think about.
Nov 02, 2017 | KitchenAid Dishwashers
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
dishwasher wont turn on
The dishwasher is generally on a separate circuit so if that circuit breaker kicks, or that fuse blows you won't see anything else turned off. Go to you panel and check to see.. If it is a blown fuse, replace it with a new one of the same amperage. If it is a kicked circuit breaker turn the breaker all the way off and then back on.
Apr 07, 2009 | GE GSD3800G - Multiple Color Built-in...
1,999 people viewed this tip
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
