Tip & How-To about Computers & Internet
Hide Drives on computer/ laptop
You can hide the drive icon by following some simple steps. Go to run type cmd you will get command propt. In this type "diskpart" and enter After this type "list volume" and enter. This will list the volumes that you are having in your hard disk.Drives will be displayed as volumes . Suppose you want to hide D drive, See which volume is there corresponding to D drive . If volume 2 is there for d drive type "select volume 2" and enter.It will select the particular volume After that type "remove letter D" and enter. to hide d drive. . then see in your my computer that drive will be hidden. if you want to assign it back type "assign letter D". and see the changes....Like this you can hide any drives in your computer by selecting corresponding volume for that drive .. You can check out by doing this to all drives...
Computers & Internet Logo
I had Windows 8.1 istalled in my Pc but it showed problem now i want to install windows 7. I have windows 7 bootable USB and want clean instalation. i booted from USB and opened stup and formatted my
Simply formatting the hard drive does not remove all residual traces of the previous installation. When you get to the step for formatting, go to the advanced button and delete the partition that contained windows 8. Then create a new partition in the space, format, and install windows 7.
Aug 05, 2014 | Computers & Internet
unknown capacity usb
Run CMD.EXE as administrator
Type following commands and hit ENTER key after each command.
· DISKPART starts the DiskPart program
· LIST DISK shows numeral assigned to disks
note the numeral assigned to your usb stick
The numeral 2 will be used in this example
· SELECT DISK 2
· DETAIL DISK the info shown will confirm the correctness of your selection
· CLEAN ALL the entire usb stick will be overwritten with zeros
· CREATE PARTITION PRIMARY create a primary partition on the USB stick
· FORMAT FS=NTFS format the partition
· ACTIVE the partition can contain operating system startup files
· ASSIGN the next available letter is assigned to the USB stick
· EXIT exit from the DISKPART program
· EXIT exit from the command shell
Nov 08, 2013 | SanDisk Electronics - Others
i erased all the files on my memory card and when i put it in my camera it says the card is still full
Solution overview: You need to "clean" the SD card by using the clean command in Diskpart and then format the card in Disk Management. This solution will show you how to accomplish this.
1. Plug the SD Card into the computer.
2. Press Win+R to open the Run command.
3. Type "cmd" into the dialog box and press enter to open a command prompt.
4. Type "Diskpart" into the command line of the command prompt to start Diskpart. Wait for Diskpart to load.
5. Type "List Disk" and press enter.
6. Take note of the number of the disk that's associated with your SD card.
7. Type "Select Disk X" where X = the number of the disk that's associated with your SD card and press enter. Make sure the command prompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and press enter. Clean will be faster but might not solve your problem. If using the clean command doesn't solve your problem, then repeat steps 1-8 and type "Clean all".
9. Wait for Diskpart to complete the cleaning operation - this may take some time so wait until it's completed!
10. Close command prompt.
11. Press Win+R to open the Run command.
12. Type "DISKMGMT.MSC" into the dialog box and press enter. Wait for Disk Manager to load.
13. In Disk Manager, scroll down and select the SD Card.
14. Right click and select "New Simple Volume".
15. Select Next, Assign Drive Letter, and select "Next" again.
16. Select "FAT32" for File System and "Default" for Allocation Unit Size. Fill in whatever you want for the Volume Label. Make sure "Perform quick format" is checked and click OK.
17. Wait for formatting to complete and remove SD card from computer.
18. Plug SD card into camera to see if the problem is solved.
Good luck and thanks for using FixYa. Post back if you have any questions or problems.
Mar 23, 2011 | PNY 4GB microSD High Capacity Mobile Media...
I have been using my PNY OPTIMA HC 4gb memory card to upload pics for months and all of a sudden it will not read or allow me to upload
Solution overview: You need to "clean" theSD card by using the clean command in Diskpart and then format the card in DiskManagement. This solution will show you how to accomplish this.
3. Type "cmd" into the dialog box and press enter to open acommand prompt.
4. Type "Diskpart" into the command line of the command promptto start Diskpart. Wait for Diskpart to load.
7. Type "Select Disk X" where X = the number of the diskthat's associated with your SD card and press enter. Make sure the commandprompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and pressenter. Clean will be faster but might not solve your problem. If using theclean command doesn't solve your problem, then repeat steps 1-8 and type "Cleanall".
9. Wait for Diskpart to complete the cleaning operation - this may take sometime so wait until it's completed!
12. Type "DISKMGMT.MSC" into the dialog box and press enter.Wait for Disk Manager to load.
16. Select "FAT32" for File System and "Default"for Allocation Unit Size. Fill in whatever you want for the Volume Label. Makesure "Perform quick format" is checked and click OK.
Good luck and thanks for using FixYa. Post back if you have any questions orproblems.
Mar 15, 2011 | PNY 4GB Secure Digital High Capacity...
154 people viewed this tip
David Payne
David Payne
