Tip & How-To about Cameras
If your camera will not read or transfer internal images on to memory card
When your camera will not transfer images onto memory card this is often because the image storage has been set to 'Auto'. You need to set it back to internal memory temporarily to allow you to copy the images over to the card. Once you have done this you can set the camera back to 'Auto' and this will reset the system and you will now have access to all of the images on the card.
This particular procedure works with all cameras but the steps outlined here are for Kodak in particular.
Please follow these steps;
1) Insert the card
2) Turn the camera to Auto
3) Press review - "reading memory card"
4) Press menu and scroll down to image storage and press ok
5) Select Internal Memory and press OK
6) Scroll down to Copy - Copy Pictures to memory card
7) Scroll down to ALL and press OK - you should see "Copying" displayed
8) When the screen goes back to the main menu - Scroll to Image storage again and select Auto - OK - "Reading memory card"
You should now be able to see the pictures from your internal memory saved onto your memory card and your camera is once again ready to use.
Hope this helps. Please do register your vote using the Yes/No buttons below to reflect the helpfulness of this Tip.
Cameras Logo
how can i transfer built in memory card to memory card if built in already full
Hi bacayemilita,
I think you meant that you need to transfer your images from your camera's built in storage to your external memory card.
Please follow the below steps :-
  1. Connect you camera to your computer via the USB cable and then switch your camera on.
  2. Once you switch the camera on you will find an option for mass storage mode , please select that option.
  3. Remember to remove the memory card from your camera while you do the above step.
  4. Once you select the mass storage mode , you will find a removable drive being displayed in my computer , in this drive you will find all your images, so all you need to do is copy them all to your hard disk drive.
  5. Now if you want to copy these images to your memory card , you can either do it via connecting your memory card to a card reader and copy the images from your hard disk onto it Or you can connect the camera while keeping the memory card in , and you will find another removable drive for memory card , when you select mass storage mode.
  6. When you find the drive , just simply copy the contents from your hard disk to your memory card's removable drive.
Hope this helps ..:) Your feed back would be greatly appreciated.
Jun 26, 2011 | Pentax Optio S4i Digital Camera
how to transfer images to the memory card
Insert a card and set the camera's image storage location to internal memory. Press the Review button, then the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
To change the camera's image storage location, press the Menu button. Press up/down to highlight Image Storage. Make sure you change it back to Auto if you want to use a memory card for subsequent pictures.
Dec 03, 2010 | Kodak EasyShare C653 Digital Camera
kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    how do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    I have pics saved on internal memory and need to transfer to memory card. how do I do this?
    -Turn On camera
    -press Menu and go to setup
    -Under setup look for Choose image storage and switch to internal Memory
    -Now if your image storage set into Internal memory, Press menu again to exit menu settings
    -Press review button for you to able to see picture from internal Memory
    -now Press menu again while viewing the slected picture that you want to transffer
    -It will provide option PICTURE/ALL/EXIT
    -If you want to transffer all the picture select all
    -If you want to trnasffer selected picture select picture.
    Note: You need to set your Image storage into AUTO so you can use your memory card to take and view picture
    Nov 09, 2009 | Kodak EasyShare DX4330 Digital Camera
    709 people viewed this tip
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
