Tip & How-To about Computers & Internet
Freeing up extra hard drive space
Are you out of hard drive space but can't find anything you'd like to remove from your computer?
Maybe you should try doing a Disk Cleanup.
Disk Cleanup will remove unnecessary files from your hard drive and if it hasn't been done on your system previously, free up a lot of space in the process.
To do a Disk Cleanup:
1) Go to My Computer.
2) Right click on your C drive.
3) Click Properties.
4) Click the "Disk Cleanup" button next to the visual representation of your hard drive space.
Disk Cleanup will calculate how much space you can free up and
what should be removed.
5) Under "Files to delete" select any files you don't want or need.
Generally all of the tabs can be selected and none of the files are
needed by your system. Below on "Description" you can view what
the files listed under each tab are for.
6) Once you have selected all of the files you want to remove click OK.
7) Disk Cleanup will remove the files from your system.
Disk Cleanup is complete.
Computers & Internet Logo
hp mini no memory to do anything
Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Apr 20, 2013 | HP Mini 1000 Netbook
usb speed 900kbps
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Mar 12, 2013 | Computers & Internet
my dell inspiron 1525 laptop is running slow because it is saying the memory is nearly full when it isnt, how do i solve this
HARD DISK MAINTENANCE
Harddisk maintenance should be carried once a month to make your computer runefficiently.Thisremoves redundant and temporary files, recovers disk space and speed up harddisk access.Disk Cleanup should be donefirst - Click My Computer - then right click on the C drive then click Properties,then click Disk Cleanup - let it examine the C drive then it will calculate theamount of disk space it will recover, tick all the boxes to recover themaximum disk space and then Click OK and then Yes to perform theseactions. If you have a D drive then repeat these steps on this drive too.Next the C drive needs tobe Defrag. This process converts fragmented filesinto continuous files and this speeds up disk access and makes the hard disknot work as hard. Click on Start - All Programs - Accessories - SystemTools - Disk Defragmenter - click to highlight the Cdrive and click Analyse - then click Defragment.When this is completedrepeat these steps for the D Drive if you have a D drive.Disk Cleanup and Defrag can take a long time to complete, especially ifthese tasks have not been for a long time.
May 09, 2012 | Dell Inspiron 1525 Notebook
my pc is slow run
TRY THIS :-
Free up disk space. A hard drive that is close to being full will drastically slow down your computer. You can clear up space by deleting temporary internet files, empty your recycle bin, remove programs that you do not use, put important files on an external hard drive.
Another way to free up disk space is to use "Disk Cleanup" on your Windows PC. To do this, click "start" and go to "Accessories", go to "System Tools", and click "Disk Cleanup".
Scan for Viruses, Adware, and Spyware. These nasty programs can slow down your computer worse than anything. I would recommend purchasing software that can remove all three of these common problems.
Don't automatically start up programs when you turn your computer on. Close any programs that you do not use that open when you start up your computer. These programs will run in the background and steal RAM (Random Access Memory).
http://www.supportdock.com/
Mar 18, 2010 | Samsung S860 Digital Camera
Less available Hard Drive Space than advertised
try to flash a newer bios to system:
http://support.acer-euro.com/drivers/notebook/as_5315.html
Also look at your hard drive - >
right click on "My computer" -> manage -> disk management. There you should see all info about your hard drive. Maybe it's splitted in two partitions
Apr 14, 2009 | Acer Aspire 5315 Notebook
247 people viewed this tip
David Payne
David Payne
