Tip & How-To about Computers & Internet
Force Eject CD/DVD From a Macintosh Computer
Have you got a CD or DVD That won't eject from a Macbook or Mac desktop?There are many ways of getting a disk to eject. 1) Log Out: then try by pushing eject on the login screen. 2)Login: If that doesn't work login and push eject. 3)Restart: Restart the computer and repeat steps 1 and 2. 4) Force Eject: To force eject hold down the mouse or trackpad button when the computer is starting up, if you have a non-apple mouse hold down the left click. 5) If All Else Fails: Your disk drive could be broken you should call Apple or take it to the shop you purchased it form with your applecare box and number (if you have one).
Computers & Internet Logo
how to eject a cd
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVDicon1.png drives in all macs are a bit suspect and if your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge. Hope this helps.
Apr 30, 2013 | Apple MacBook Pro Laptop Computer with...
cd stuck in mac laptop
2) if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
imac to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVD drives in all macs are a bit suspect and if
Feb 18, 2013 | Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz...
how to force spit CD from drive
1) restart mac and press down the mouse button after you hear the startup noise
4) Finally what to do is try pick up your imac tilt the
your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they will replace it free off charge.
If it is out of warranty there is one other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE (Use it at your own risk), so only use it as a last resort. Get a thin piece of plastic (or credit card) and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the DVD out.
Hope this helps.
Dec 10, 2012 | Apple 2.16GHz iMac Intel Core 2 Duo...
I put a CD into the CD drive and it can't be ejected
restart mac and press down the trackpad after you hear the startup noise
Finally what to do is try pick up your macbook tilt the macbook to the one side and ise the eject key and hopefully the effect of gravity will allow the DVD to fall out.
One other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE, so only use it as a last resort. Get a thin piece of plastic and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the dvd out.
Hope this helps.
Aug 29, 2011 | Apple iBook G4 Mac Notebook
The disc will not eject from my apple mac? why?????? The eject symbol comes up but the cd stays inside? HELP?
Hope this helps.
Mar 23, 2011 | Apple Customized 15" MacBook Pro Laptop...
155 people viewed this tip
David Payne
David Payne
