Tip & How-To about Computers & Internet
See file path(s) On OSX 10.5
GO to terminal and type: defaults write com.apple.finder _FXShowPosixPathInTitle -bool YES
This shows the file path of the folder on windows instead of the name.
To revert type in terminal: defaults write com.apple.finder _FXShowPosixPathInTitle -bool NO
Computers & Internet Logo
Unlock volume control
you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
May 20, 2010 | Apple iPod nano
how to unlock factory volume lock,i dont have the code
why dont you try this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Dec 25, 2009 | Apple iPod nano
How to unlock volume limit
that is not a problem follow the steps below and if it doesnt work let me know i will assist you from there. unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Nov 28, 2009 | Apple iPod nano
I Can't unlock my Apple Ipod (black)
On MAC :
  1. Enable hidden folders.
    killall Finder
    killall Finder
  2. Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
On Windowsç
    In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
  2. Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
Sep 18, 2008 | Apple iPod MP3 Player
SD card full in spite of all files deleted - what do do?
OK, so if you want to delete the photos off your s.d. card, Simply open the 'terminal' application located in the utilities folder.
Then enter this into the box:
killall Finder
That will then make the .Trashes folder of the sd card show up!
Open it, go through the '501' folder, and there you go! Delete everything!
This happens because the card has it's own hidden trash.
Oh, and if you want to hide all the hidden files and folders again, simply open terminal, and enter THIS text:
killall Finder
Cheers,
Tristan
Jun 17, 2008 | Edirol R-09 Digital Voice Recorder
112 people viewed this tip
David Payne
David Payne
