Tip & How-To about Computers & Internet
Have a screen saver as your background
It's really easy just open terminal and type or paste in the following: /System/Library/Frameworks/ScreenSaver.framework/Resources/ScreenSaverEngine.app/Contents/MacOS/ScreenSaverEngine -background &
Make sure you leave terminal open, if you don't want to download SavX 1.1 By LFK Computers (osx 10.5 and up)
Computers & Internet Logo
HP Deskjet 1000 use with Linux operating systems
Question is old, but just in case:
installing HP printers in Ubuntu is very easy:
https://sites.google.com/site/tipsandtricksforubuntu/printer-info/hplip-driver
I am copying instructions here just in case site would go down:
  • open a terminal (Applications > Accessoiries > Terminal)
  • type the following command: sudo add-apt-repository ppa:hplip-isv/ppa
  • press Enter and if needed, type the required password
  • type the following command: sudo apt-get update
  • then type the following command: sudo apt-get install hplip
HPLIP is mentioned on official HP support pages as solution how to get HP printers working on linux.
Jan 19, 2012 | Office Equipment & Supplies
how do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
I have had an Optus 3G wireless connection working up to 6 weeks ago, however am now getting "Failed to initialise the modem (dialuppppclientservice.cpp.896). Have made no changes to eeepc during this period. Have deleted and created new network connection but still having same error
What interface does the card use, is it USB? Have you gotten the card working on this computer in the past?
First we need to check to see if the device is recognized. When the card is plugged in, do the lights flash? Please open up a terminal and type lshw -c network and paste the output here.
It is my hunch that the PPP connection is not configured properly.
If you use network manager, you may want to try updating to wicd. It is not necessary, but wicd is updated more frequently and is more likely to support your 3g card. You can update by opening a terminal and typing 'sudo apt-get install wicd'. Whether you are in network-manager or wicd make sure you select PPP as the connection type.
If that does not work, follow the instructions here. Create the file and script as you see here http://freshfoo.com/articles/using_optus3g_with_linux.html
I apologize if I don't respond in a timely manner, as it is getting late here in California. I assume you live in the UK. Perhaps another guide can take over in the mean time.
Good luck.
Mar 29, 2010 | ASUS Eee PC 701SD
Entourage frozen/blocked
If your running OSX you can kill Entourage from the command line which is much more powerful way of killing a task that won't shut down.
Another way to kill applications is to open a terminal window using the Terminal application. In the window type top -u, making sure that all the characters are lowercase and a space is present between top and -u. A list of the top processes will appear in the window. Identify which process you wish to kill and note the PID or Process ID for that process and then type q. Then type kill -9 followed by a space and the PID. This will almost always kill the process. If the system says you do not have sufficient priviledges, then type sudo kill -9 followed by a space and the PID. SUDO enables you to type in system command and it will prompt you for the system administrator password before executing the command. Type in your password and the system will kill the process.
Oct 03, 2009 | Apple iMac 24" Desktop
HOW TO INSTALL YAHOO MESSENGER IN UBUNTU LINUX OS?
open terminal
sign in as root by typing: su
enter password when asked
write
apt-get install libssl0.9.6
now download ymessenger
http://download.yahoo.com/dl/unix/ymessenger_1.0.4_1_i386.deb
save it to a easy to find location
go back to terminal
write: dpkg -i /write the full path where you downloaded the file here/ymessenger_1.0.4_1_i386.deb
Run /usr/bin/ymessenger (or just ymessenger) and follow the few simple instructions for setting up Yahoo! Messenger. An icon will be placed on your desktop.
May 14, 2009 | Yahoo Messenger
145 people viewed this tip
David Payne
David Payne
