Tip & How-To about Garden
The fastest way to desassembly an engine
Remove the:
engine cover
fuel tank
cooling shroud and recoil starter
carburetor and intake manifold
muffler
cylinder head
flywheel
ignition components
crankcase breather
oil sump and crankcase cover
crankshaft
camshaft
tappets
piston and connecting rod
valves
governor components
Garden Logo
how to replace head gasket on 4 cylander
2.6L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following:
    • Negative battery cable
    • Hood
    • Accessory drive belts
    • Accelerator cable
    • Positive Crankcase Ventilation (PCV) valve and hose
    • Air intake duct
    • Fuel pressure regulator vacuum line
    • Canister hose
    • Brake booster vacuum line
    • Engine wiring harness connectors at right wheel housing
    • Ground cable connector at the intake manifold, starter and firewall
    • Heated Oxygen (HO2S) sensor connector
    • Alternator wiring connectors
    • Oil pressure switch connector
    • Starter motor harness connectors
    • Ignition coil connector
    • Spark plug wires
    • Distributor
    • Exhaust front pipe
    • Exhaust Gas Recirculation (EGR) gas temperature sensor connector
    • Air pump
    • EGR pipe
    • Heat shield
    • Exhaust manifold
    • Throttle Position (TP) switch connector
    • Cooling fan
    • Water pump pulley
    • Power steering pump
    • Intake manifold
    • Crankshaft pulley
    • Front cover
    • Timing belt. Refer to the Timing Belt unit repair section.
    • Valve cover
    • Rocker arms
    • Camshaft
    • Cylinder head
Cylinder head bolt loosening sequence - 2.6L engine
  1. To install:
  2. NOTE: Refer to Section 1 of this manual for the cylinder head torque sequence illustration. The illustration is located after the Torque Specification Chart.
  3. NOTE: Lubricate the cylinder head bolts with clean engine oil for assembly.
  4. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows:
  5. Step 1: 58 ft. lbs. (75 Nm)
  6. Step 2: 72 ft. lbs. (98 Nm)
    1. Install or connect the following:
    2. Camshaft
    • Rocker arms
    • Valve cover
    • Timing belt
    • Front cover
    • Crankshaft pulley. Tighten the bolt to 87 ft. lbs. (128 Nm).
    • Intake manifold
    • Water pump pulley
    • Cooling fan
    • TP switch connector
    • Exhaust manifold
    • Heat shield
    • EGR pipe
    • Air pump
    • EGR gas temperature sensor connector
    • Distributor
    • Spark plug wires
    • HO2S sensor connector
    • Canister hose
    • Air intake duct
    • PCV valve and hose
    • Accelerator cable
    • Hood
    1. Fill the cooling system.
    2. Start the engine and check for leaks.
    Feb 05, 2011 | 1997 Isuzu Rodeo
    Is replacing a motor on a 1989 lincoln town car something I should even try doing? I can't even see the motor.. lol, Is it hard to replace?
    It can be complicated: 5.0L Engine
    1. Disconnect the negative, then the positive battery cable. Drain the crankcase and the cooling system into suitable containers.
    2. Drain and recycle the engine coolant.
    3. Properly relieve the fuel system pressure. NOTE: If your vehicle is equipped with air conditioning, refer to Section 1 for information regarding the implications of servicing your A/C system yourself. Only an MVAC-trained, EPA-certified, automotive technician should service the A/C system or its components. CAUTION
      Never open, service, or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. In addition, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
    4. Mark the position of the hood on the hinges and remove the hood. Disconnect the battery ground cables from the cylinder block.
    5. Remove the air intake duct and the air cleaner.
    6. Disconnect the upper radiator hose from the thermostat housing and the lower hose from the water pump. Disconnect the oil cooler lines from the radiator.
    7. Remove the bolts attaching the radiator fan shroud to the radiator. Remove the radiator. Remove the fan, belt pulley, and shroud.
    8. Remove the alternator bolts and position the alternator aside.
    9. Disconnect the oil pressure sending unit wire from the sending unit. Disconnect the fuel lines; refer to Section 5.
    10. Disconnect the accelerator cable from the throttle body. Disconnect the throttle valve rod/cable. Disconnect the cruise control cable, if equipped.
    11. Disconnect the throttle valve vacuum line from the intake manifold, if equipped. Disconnect the transmission filler tube bracket from the cylinder block.
    12. Disconnect the air conditioning lines and electrical connectors at the compressor; refer to Section 6. Plug the lines and the compressor fittings to prevent the entrance of dirt and moisture.
    13. Disconnect the power steering pump bracket from the cylinder head. Remove the drive belt. Position the power steering pump aside in a position that will prevent the fluid from leaking.
    14. Disconnect the power brake vacuum line from the intake manifold.
    15. Disconnect the heater hoses from the heater tubes. Disconnect the electrical connector from the coolant temperature-sending unit.
    16. Remove the transmission-to-engine upper bolts.
    17. Disconnect the wiring harness at the two 10-pin connectors.
    18. Raise and safely support the vehicle. Disconnect the starter cable from the starter and remove the starter.
    19. Disconnect the muffler inlet pipes from the exhaust manifolds. Disconnect the engine mounts from the chassis. Disconnect the downstream thermactor tubing and check valve from the right exhaust manifold stud, if equipped.
    20. Disconnect the transmission cooler lines from the retainer and remove the transmission inspection cover..
    21. Match mark the converter and flywheel with a dab of paint to ease installation. Disconnect the flywheel from the converter and secure the converter assembly in the transmission. Remove the remaining transmission-to-engine bolts.
    22. Lower the vehicle and then support the transmission. Attach suitable engine lifting equipment and hoist the engine.
    23. Raise the engine slightly and carefully pull it from the transmission. Carefully lift the engine out of the engine compartment. Avoid bending or damaging the rear cover plate or other components. Install the engine on a workstand. To install:
    24. Attach the engine lifting equipment and remove the engine from the workstand.
    25. Lower the engine carefully into the engine compartment. Make sure the exhaust manifolds are properly aligned with the muffler inlet pipes.
    26. Start the converter pilot into the crankshaft. Align the paint mark on the flywheel to the paint mark on the torque converter.
    27. Install the transmission upper bolts, making sure the dowels in the cylinder block engage the transmission.
    28. Install the engine mount-to-chassis attaching fasteners and remove the engine lifting equipment.
    29. Raise and safely support the vehicle. Connect both muffler inlet pipes to the exhaust manifolds. Install the starter and connect the starter cable.
    30. Remove the retainer holding the torque converter in the transmission. Attach the converter to the flywheel. Install the converter housing inspection cover and install the remaining transmission attaching bolts.
    31. Remove the support from the transmission and lower the vehicle.
    32. Connect the wiring harness at the two 10-pin connectors.
    33. Connect the coolant temperature sending unit wire and connect the heater hoses. Connect the wiring to the metal heater tubes and the engine coolant temperature, air charge temperature and oxygen sensors.
    34. Connect the transmission filler tube bracket. Connect the manual shift rod and the retracting spring. Connect the throttle valve vacuum line, if equipped.
    35. Connect the accelerator cable and throttle valve cable. Connect the cruise control cable, if equipped.
    36. Connect the fuel lines and the oil pressure sending unit wire.
    37. Install the pulley, water pump belt and fan/clutch assembly.
    38. Position the alternator bracket and install the alternator bolts. Connect the alternator and ground cables. Adjust the drive belt tension.
    39. Unplug and connect the refrigerant lines and connect the electrical connector to the compressor.
    40. Install the power steering drive belt and power steering pump bracket. Connect the power brake vacuum line.
    41. Place the shroud over the fan and install the radiator. Connect the radiator hoses and the transmission oil cooler lines. Position the shroud and install the bolts.
    42. Connect the heater hoses to the heater tubes. Fill the cooling system. Fill the crankcase with the proper type and quantity of engine oil. Adjust the transmission throttle linkage.
    43. Connect the positive and then the negative battery cables. Start the engine and bring to normal operating temperature. Check for leaks. Check all fluid levels.
    44. Install the air intake duct assembly. Install the hood, aligning the marks that were made during removal.
    45. Have a MVAC certified evacuate and charge the air conditioning system.
    46. Road test the vehicle.
    Sep 24, 2010 | 1989 Lincoln Town Car
    WHAT FLUIDS DO I NEED TO CHANGE OUT WHEN CHANGING OUT THE MOTOR
    5.0L Engine
    Aug 11, 2010 | 1992 Lincoln Town Car
    cylinderhead torque stc.
    Cylinder Head Removal & Installation SOHC To Remove:
    1. Relieve fuel system pressure.
    3. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
    4. Loosen lock bolt on tensioner.
    5. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt.
    6. Remove timing belt from camshaft pulley.
    7. Disconnect battery negative cable.
    8. Remove 3 bolts that secure accelerator cable and air intake hose to cylinder head cover.
    9. Detach accelerator cable and place off to side.
    10. Remove the following;
      • Air hose
      • Air ISC air hose
      • Breather hose
      • Vacuum hose from air intake hose
    11. Disconnect mass air flow sensor electrical connector.
    12. Remove air intake hose.
    13. Remove PCV valve from cylinder head cover.
    14. Remove ISC air hose from idle speed actuator.
    15. Remove air hose from behind intake manifold.
    16. Remove 2 screws from high tension wire protectors.
    17. Detach wire loom from holder at rear of cylinder head cover.
    18. Detach vacuum tube at rear of cylinder head cover.
    20. Remove 7 cylinder head cover bolts.
    21. Remove cylinder head cover and gasket.
    22. Disconnect 2 ignition coil electrical connectors.
    23. Disconnect 2 fuel injection electrical connectors at rear of cylinder head.
    24. Disconnect the following electrical connectors;
      • Oxygen sensor
      • Throttle position sensor
      • Idle speed actuator
      • EGR vacuum solenoid valve at intake manifold
    25. Disconnect heater hose from elbow.
    26. Disconnect brake booster vacuum hose and cruise control vacuum hose from surge tank.
    27. Detach wire harness from rear of cylinder head.
    28. Disconnect purge control solenoid vacuum hose from intake manifold.
    29. Disconnect fuel hose from fuel connector assembly.
    30. Remove grounding bracket.
    31. Remove 4 bolts and intake manifold bracket.
    32. Remove starter.
    33. Detach water bypass hose from bypass pipe.
    34. Disconnect water hoses from oil cooler.
    35. Disconnect fuel hose from fuel pipe.
    36. Remove exhaust manifold heat shield.
    37. Remove exhaust flange nuts and front exhaust bracket bolt.
    38. Lower exhaust system. Cylinder head bolt loosening sequence kia-03-20-7050.gif
    39. Loosen cylinder head bolts in 3 steps in proper sequence.
    40. Remove cylinder head bolts and washers.
    41. Remove cylinder head, intake manifold and exhaust manifold as an assembly.
    To Install:
    1. Install NEW cylinder head gasket.
    2. Install cylinder head, intake manifold and exhaust manifold as an assembly.
    3. Tighten cylinder head bolts in 3 steps in reverse sequence that was used during removal. Tighten bolts to 62 ft lb (84 Nm).
    4. Install front exhaust bracket bolt. Tighten bolt to 20 ft lb (27 Nm).
    5. Install NEW lower exhaust flange gasket and 3 nuts. Tighten nuts to 24 ft lb (31 Nm).
    6. Install exhaust manifold heat shield. Tighten nuts to 35 in lb (4 Nm).
    7. Connect fuel hose to pipe.
    8. Connect 2 hoses to oil cooler.
    9. Attach water bypass hose to bypass pipe.
    10. Install starter and bolts. Tighten bolts to 34 ft lb (46 Nm).
    11. Install intake manifolds bracket and 4 bolts. Tighten bolts to 32 ft lb (45 Nm).
    12. Install grounding bracket.
    13. Connect fuel hose to fuel connector assembly.
    14. Connect the following electrical connectors;
      • Oxygen sensor
    15. Connect purge control solenoid vacuum hose to intake manifold.
    16. Attach wire harness from rear of cylinder head.
    17. Connect brake booster vacuum hose and cruise control vacuum hose to surge tank.
    18. Connect heater hose to elbow.
    19. Connect 2 fuel injection electrical connectors at rear of cylinder head.
    20. Connect 2 ignition coil electrical connectors.
    21. Install cylinder head cover.
    22. Install 7 cylinder head cover bolts. Tighten bolts to 60 in lb (7 Nm).
    23. Install vacuum pipe and 2 bolts at rear of cylinder head cover. Tighten bolts to 60 in lb (7 Nm).
    24. Connect vacuum tube to pipe.
    25. Connect loom holder to rear of cylinder head cover.
    26. Install 2 screws to high tension wire protectors.
    27. Install air hose to behind intake manifold.
    28. Install ISC air hose to idle speed actuator.
    29. Install PCV valve to cylinder head cover.
    30. Install air intake hose.
    31. Connect mass air flow sensor electrical connector.
    32. Install the following;
      • Air hose
      • Air ISC air hose
      • Breather hose
    33. Attach accelerator cable.
    34. Install 3 bolts that secure accelerator cable and air intake hose to cylinder head cover. Timing belt pulley timing marks kia-03-20-7035.gif
      NOTE: Timing belt pulley timing mark and timing mark must be aligned.
      NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
    35. Install timing belt.
    36. Install timing belt cover.
    37. Pressurize fuel system.
    38. Start engine and check ignition timing.
    Jul 11, 2010 | 1999 Kia Sportage
    how do you take off a intake manifold
    This is for the 4.6L motor...I'll post for the 5.0L and 5.8L....you didn't post your engine size so please pick the applicable motor:
    4.6L Engine
    CAUTION Fuel injection systems remain under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
    1. If equipped with air suspension, the air suspension switch, located on the right-hand side of the luggage compartment, must be turned to the OFF position before raising the vehicle.
    2. Disconnect the negative battery cable.
    3. Drain the engine cooling system.
    4. Relieve the fuel system pressure as follows:
      1. Remove the fuel tank fill cap to relieve the pressure in the fuel tank.
      2. Remove the cap from the Schrader valve located on the fuel injection supply manifold.
      3. Attach Fuel Pressure Gauge T80L-9974-B or equivalent, to the Schrader valve and drain the fuel through the drain tube into a suitable container.
      4. After the fuel system pressure is relieved, remove the fuel pressure gauge and install the cap on the Schrader valve. Secure the fuel tank fill cap.
    5. Disconnect the fuel supply and return lines.
    6. Remove the windshield wiper governor (module).
    7. Remove the engine air cleaner outlet tube.
    8. Release the drive belt tensioner and remove the accessory drive belt.
    9. Tag and disconnect the ignition wires from the spark plugs. Disconnect the ignition wire brackets from the cylinder head cover studs.
    10. Disconnect the wiring from both ignition coils and the Camshaft Position (CMP) sensor. Tag and disconnect all ignition wires from both ignition coils. Remove 2 bolts retaining the ignition wire bracket to the ignition coil brackets and remove the ignition wire assembly.
    11. Disconnect the alternator wiring harness from the junction block at the fender apron and alternator. Remove the bolts retaining the alternator brace to the intake manifold and the alternator to the cylinder block and remove the alternator.
    12. Raise and safely support the vehicle.
    13. Disconnect the oil pressure sensor and power steering control valve actuator wiring and position the wiring harness out of the way.
    14. Disconnect the EGR valve to exhaust manifold tube from the right-hand exhaust manifold.
    15. Lower the vehicle.
    16. Remove and detach the engine/transmission harness connector from the retaining bracket on the power brake booster.
    17. Detach the A/C compressor clutch, Crankshaft Position (CKP) sensor and the canister purge solenoid wiring connectors.
    18. Remove the PCV valve from the cylinder head cover and disconnect the canister purge vent hose from the PCV valve.
    19. Disconnect the accelerator and cruise control cables from the throttle body. Remove the accelerator cable bracket from the intake manifold and position out of the way.
    20. Disconnect the vacuum hose from the throttle body adapter port.
    21. Disconnect both Heated Oxygen Sensors (HO2S) and the heater water hose.
    22. Remove 2 bolts retaining the thermostat housing to the intake manifold and position the upper hose and thermostat housing out of the way.
    The 2 thermostat housing bolts are also used to retain the intake manifold.
    1. Remove 9 bolts retaining the intake manifold to the cylinder heads and remove the intake manifold. Remove and discard the gaskets.
    2. If replacing the intake manifold, swap over the necessary parts.
    To install:
    1. Clean all gasket mating surfaces.
    2. Position new intake manifold gaskets on the cylinder heads. Make sure the alignment tabs on the gaskets are aligned with the holes in the cylinder heads.
    3. Install the intake manifold and 9 retaining bolts. Hand tighten the right-rear bolt (viewed from the front of the engine) before final tightening, then torque the bolts, in sequence, to 15-22 ft. lbs. (20-30 Nm).
    4. Inspect and if necessary, replace the O-ring seal on the thermostat housing. Position the housing and upper hose and install 2 retaining bolts. Torque to 15-22 ft. lbs. (20-30 Nm).
    5. Reconnect the heater water hose.
    6. Reconnect both HO2S wiring connectors.
    7. Reconnect the vacuum hose to the throttle body adapter vacuum port.
    8. Install the accelerator cable bracket on the intake manifold and connect the accelerator and cruise control cables to the throttle body.
    9. Install the PCV valve in the cylinder head cover and connect the canister purge solenoid vent hose. Reconnect the A/C compressor clutch, CKP sensor and canister purge solenoid wiring connectors.
    10. Reconnect the engine/transmission harness connector. Install the connector on the retaining bracket on the power brake booster.
    11. Raise and safely support the vehicle.
    12. Reconnect the EGR valve to exhaust manifold tube to the right-hand exhaust manifold. Torque the tube nut to 26-33 ft. lbs. (35-45 Nm).
    13. Reconnect the power steering control valve actuator and the oil pressure sensor wiring connectors.
    14. Lower the vehicle.
    15. Position the alternator and install 2 retaining bolts. Torque to 15-22 ft. lbs. (20-30 Nm). Install 2 bolts retaining the alternator brace to the intake manifold and torque to 71-106 inch lbs. (8-12 Nm).
    16. Reconnect the alternator wiring harness to the alternator, right-hand fender apron and junction block.
    17. Position the ignition wire assembly on the engine and install 2 bolts retaining the ignition wire bracket to the ignition coil brackets. Torque the bolts to 71-106 inch lbs. (8-12 Nm).
    18. Reconnect the ignition wires to the ignition coils in their proper positions. Reconnect the ignition wires to the spark plugs.
    19. Reconnect the ignition wire brackets on the cylinder head cover studs. Reconnect the wiring connectors to both ignition coils and the CMP sensor.
    20. Install the accessory drive belt.
    21. Install the engine air cleaner outlet tube.
    22. Install the windshield wiper governor.
    23. Reconnect the fuel supply and return lines.
    24. Fill and bleed the engine cooling system.
    25. Reconnect the negative battery cable.
    26. If equipped with air suspension, turn the air suspension switch to the ON position.
    27. Start the engine and check for leaks.
    28. Road test the vehicle and check for proper operation.
    4.6L engine intake manifold torque sequence—1996-98 Models
    Nov 30, 2009 | 1997 Mercury Grand Marquis
    183 people viewed this tip
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
