Tip & How-To about Computers & Internet
How to Change the ICON of an EXE file
Some times it becomes necessary to change the ICON of an executable(.exe) file so that the exe file get’s a new appearence.Many of the Tools such as TuneUP Winstyler does this job by adjusting the Windows to display a custom icon to the user.But in reality when the file is carried to a different computer, then it shows it’s original ICON itself.This means that inorder to permanantly change the ICON, it is necessary to modify the executable file and embed the ICON inside the file itself.Now when this is done the exe file’s ICON is changed permanantly so that even if you take file to a different computer it show’s a new icon.
For this purpose I have found a nice tool which modifies the exe file and will embed the ICON of your choice into the file itself. ie:The tool changes the exe ICON permanantly.
I’ll give you a step-by-step instruction on how to use this tool to change the icon.
1. Goto www.shelllabs.com and download the trial version of Icon Changer and install it (Works on both XP and Vista).
2. Right-click on the exe file whose ICON is to be changed.
3. Now you will see the option Change Icon…Click on that option.
4. Now the Icon Changer program will open up.
5. Icon changer will search for all the ICONS on your system so that you can select any one of those.
6. Now select the ICON of your choice and click on SET.
7. Now a popup window will appear and ask you to select from either of these two options.
  • Change embeded icon.
  • Adjust Windows to display custom icon.
Select the first option (Change embeded icon).
8. You are done.The ICON get’s changed.
Computers & Internet Logo
Why is this file SSCKbdHk.exe appearing to cause problems?
I can't tell you what to do for your problem, however you have to decide what to do. Check the following information from http://www.file.net/process/ssckbdhk.exe.html
What is SSCKbdHk.exe?
SSCKbdHk.exe is a executable file (a program) within Windows. The filename extension .exe denotes an executable file. You should only run executable files from publishers you trust, because executable files can potentially change your computer settings or harm your computer. The free file information forum can help you determine if SSCKbdHk.exe is a virus, trojan, spyware, or adware that you can remove, or a file belonging to a Windows system or to an application you can trust.
SSCKbdHk.exe file informatiion.
The process known as SSCKbdHk belongs to software Samsung Support Center by SAMSUNG Electronics (www.samsung.com).
Description: SSCKbdHk.exe is not essential for Windows and will often cause problems. The file SSCKbdHk.exe is located in a subfolder of "C:\Program Files". Known file sizes on Windows 7/XP are 91,136 bytes (57% of all occurrences), 1,749,504 bytes and 4 more variants.[img src="http://www.file.net/img/space.gif" alt="http://www.file.net/process/ssckbdhk.exe.html" width="1" height="1">
The program has no visible window. It can change the behavior of other programs or manipulate other programs. SSCKbdHk.exe is not a Windows core file. The software can be uninstalled in the Control Panel. SSCKbdHk.exe is able to record inputs. Therefore the technical security rating is 42% dangerous, however also read the users reviews.
If problems with Samsung Support Center come up, you may want to uninstall it from your computer using the Control Panel applet "Add/Remove programs".
Recommended: Identify SSCKbdHk.exe related errors
Important: Some malware camouflages itself as SSCKbdHk.exe. Therefore, you should check the SSCKbdHk.exe process on your PC to see if it is a threat. We recommend Security Task Manager for verifying your computer's security. This was one of the Top Download Picks of The Washington Post and PC World.
Aug 15, 2014 | Samsung R530 Notebook
i need to dowbnload an audio driver for my computer
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R78742&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=103937
Level of Importance: Recommended
Dell recommends applying this update during your next scheduled update cycle. The update contains feature enhancements or changes that will help keep your system software current and compatible with other system modules (firmware, BIOS, drivers and software).
up_arrow.gif Compatibility
Systems Operating systems
Inspiron 1100
Inspiron 500m
Inspiron 1150
Inspiron 300m
Inspiron 5100
Inspiron 5150
Inspiron 5160
Inspiron 9100
XPS/Inspiron XPS
Inspiron 8600
Inspiron 510m
Inspiron 600m
Latitude D500
Latitude 100L
Latitude X300
Latitude D400
Latitude D505
Latitude D600
Latitude D800
Dell Precision Mobile WorkStation M60
Microsoft Windows 2000
Microsoft Windows XP
up_arrow.gif Installation Instructions
Hard Drive Installation (via WinZip) with Setup.exe File for S5wua12i.exe
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save (Windows XP
users will click Save) this program to disk and click OK. The Save In:
window appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled S5wua12i.exe.
2.The Self-Extracting window appears and prompts you to extract or
unzip to C:\DELL\DRIVERS\r78742. Write down this path so the executable (I.e.
Setup.exe) file can be found later.
3.The Self-Extractor window appears.
4.Click OK.
5.After completing the file extraction, if the Self-Extractor
window is still open, close it.
6.Click the Start button and then click Run.
7.Type C:\DELL\DRIVERS\r78742 in the Open textbox and then click OK.
8.Follow the on-screen installation instructions.
Sep 19, 2011 | Dell Computers & Internet
can notfind webcam
Download driver and install as per instructions
Dont forget to vote thanks
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R160323&SystemID=XPS_M1330&servicetag=&os=WW1&osl=en&deviceid=15135&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=214676
Hard Drive Installation (via WinZip) with Setup.exe File for R160323.EXE
Download
window appears.
Install
1.Double-click the new icon on the desktop labeled R160323.EXE.
unzip to C:DELLDRIVERSR160323. Write down this path so the executable (I.e.
4.Click OK.
7.Type C:DELLDRIVERSR160323 in the Open textbox and then click OK.
Feb 03, 2011 | Dell Studio 1737 Laptop
i have 508 mb of ram which sound driver i would install in my laptop.............
You can download the sound driver from the link below
Download
window appears.
Install
1.Double-click the new icon on the desktop labeled R171789.exe.
unzip to C:\DELL\DRIVERS\R171789. Write down this path so the executable (I.e.
4.Click OK.
7.Type C:\DELL\DRIVERS\R171789 in the Open textbox and then click OK.
if you require more assistance feel free to reply to this post Regards, BA
Jan 14, 2011 | Dell Latitude D630 Notebook
No sound from laptop - no sound icon in bottom right of screen
HI,
The sound drivers on the laptop are missing . Install the latest sound drivers from the folllowing link
http://tinyurl.com/yu5kvy
Download
1. Click Download Now, to download the file.
2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
Install
1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
2. The Self-Extracting window appears and prompts you to extract or unzip to C:\DELL\DRIVERS\R12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
3. The Self-Extractor window appears.
4. Click OK.
5. After completing the file extraction, if the Self-Extractor window is still open, close it.
6. Click the Start button and then click Run.
7. Type C:\DELL\DRIVERS\R12345 in the Open textbox and then click OK.
8. Follow the on-screen installation instructions.
Thanks Proton
Nov 27, 2008 | Dell Latitude D600 Notebook
233 people viewed this tip
David Payne
David Payne
