Tip & How-To about Computers & Internet
How to detect Viruses easily
I am going to tell you about a trick to detect viruses in your computer. It is simple and fast. Just follow the steps below:
1- Go to start-run-command
2- Write cd.. (notice the tow dots) and press enter write cd.. (again) and press enter
3- Write (cd windows) and press enter
4- Write (cd system32) and press enter
5- Write (setup) and enter
If you get that message
(Please switch to the control panel to install components and systems composition)
Then that means your pc is clean.
The idea here is the (setup) file which is located within (system32) is shut down when your pc infected and open when your pc is not infected because most viruses shut down all system.exe extensions.
I've tried it and it worked!
Computers & Internet Logo
I help how to remove trojan/other virus from my window 7 laptop.please help me.
Here's a fee-based service to do it for you:
http://us.norton.com/nortonlive/
To detect the threat level, you may want to try the free (& advertised on TV) web site
www.MySafePC.com, but virus removal will cost $$ - they're happy to tell you you're infected for
free, though.
Here's Symantec's list of things to do:
If you suspect that your computer is infected with a threat or you receive a threat alert, and you want to make sure that your computer is secure.
You can perform a virus scan to eliminate any known threat from your computer. Scanning your computer for threats is easy if you follow the step-by-step instructions provided in this article. The scanning process may take an hour or more, depending on the number of files you have on your computer.
To detect and remove all the threats from your computer, follow these five steps:
• Install the latest virus definitions.
• Stop all running programs and temporarily disconnect the computer from any network.
• Run the virus scan.
• Install the latest Windows updates.
• Run a full system scan once again to ensure that there are no threats.
The first step is to check whether you can install the latest virus definitions, as some threats may block your access to all the security products' Web sites including Symantec's Web site. The subsequent steps vary depending on whether you can download the latest definitions from the Symantec Web site or not.
Mar 26, 2011 | Computers & Internet
my printer ask for service required
jast go to: tricks-collections.com/download
1. download epson r 220-230 service tool/ resetter tool
2.run it and follow these proces:
12 Jan 2006
Please follow the steps below to reset the protection counter effectively.
If you have any anti virus software, please deactivate first.
The resetter software (adjprog.exe) requires specific date to run and your anti virus will prevent that.
Make sure you printer is ON and connected to your computer.
Run "Start.bat" file.
This program will set your computer date to 12 Jan 2006.
Click "Accept" button.
Click "Particular adjustment mode" button.
Select on "Waste ink pad counter" and click "OK" button.
Click on "Initialization" button and the program will reset the protection counter.
Click "Finish" button.
Change your computer's date back when it prompted.
Reactivate your anti virus if any.
Thank you
Feb 09, 2011 | Epson STYLUS R230 InkJet Photo Printer
The monitor comes on each time but then goes dark after a few seconds
i think u r using window 7 or vista.
this happens when ur system is infected by virus.
so, you may try this trick....
Note:- If you have multiple user accounts or your account is password protected then start from Step-1 else skip Step-1 and Directly follow step-2 instructon
***** Step-1 ****
press ::
ctrl + shift + esc
or
ctrl +alt+ delele
then you will see a screen containing some menu such as "Start Task Manger", "Switch User" etc....
if u have ur account password protected... then select "Switch user"...Enter password and press enter..
if again screen become black,,,
then do step 2
***** Step-2 ****
press ::
ctrl + shift + esc
or
ctrl +alt+ delele
select "Start Task manager". then do this: File>New Task(Run..)
Type this coomand:
explorer.exe
and click Ok.
Now u can back up your important data and files.
Install new windows operating system if Anti virus fails to Detect the virus and fails to repair the system.
Jan 16, 2011 | Gateway HD1900 19" Monitor
HOw to remove Win32 confi wrm in my xp... when i tried to delete using avast antivirus and virus removal tool.. it kills but again the same virus popups... please someone suggest me a solution to fix this ?
  • HI
  • PLEASE FOLLOW THE STEPS CAREFULLY
  • NO DOUGHT THE PROBLEM WILL SLOVED
  • Step 1 Click "Start" and then click "Run."
  • Step 2 Type "regedit." This will open the Windows Registrymag-glass_10x10.gif.
  • Step 3 Navigate to "HKEY_Local_Machine>System>CurrentControlSetup>Services>Browser>Parameters" by following each level in the navigation tree on the left of the window.
  • Step 4 Right click on the key "IsDomainMaster" in the right side of the window, click "Modify" and set the data entry to "False."
  • Step 5 Restart your computer.
    Patch
  • Step 1 Navigate to Microsoft Support article 894391 (see Resources).
  • Step 2 Select the download appropriate for your computer's operating system. You will now be directed to the specific download site based on your previous selection.
  • Step 3 Click "Download" and then "Save File." Double click on the downloaded file to open the installation wizard.
  • Step 4 Follow the steps of the installation wizard to install the patch
  • The patch referenced here was sent to all computers running Windows Automatic Updates; if you regularly install these updates, your system should not have an issue with Generic Host Win32 errors. HOPE YOU DO IT... PLEASE RATE ME THANK YOU
    Sep 20, 2009 | Microsoft Windows XP Professional
    slow performance of pc
    hi,you will have to increase the RAM size to whatever u can afford,, thats the only issue as of now.. let me know
    Jan 10, 2008 | Acer AL1912B 19" LCD Monitor
    207 people viewed this tip
    David Payne
    David Payne
