Tip & How-To about Air Tools & Compressors
Protect your air tools
I have been a caprpenter for over 20 years and I have seen alot of air equipment and I want to take a moment to see if I can help anyone with the problems they may be having. I want to talk about air tools because I am not a big fan of electric nailers and staplers.
Pnuematic tools run off of air pressure. Water inside the pnumatic tool is one of the worst things for the tool. The piston and cylinder are there to compress air and water will not compress. Once water is in the cylinder of the tool, it may not have enough air pressure to fire the nail or rotate a blade. The easiest way to fix this is to never get the water there to start with. This can be achieved by draining the air compressor being used daily. I actually drain it just before I use it with the compressor running to force out any moisture that may be in the tank. I also oil my tools every morning and on a long day, I will oil them a second time. The problems I have with tools is due to normal wear and tear because I take care of them. I hope this helps you and you are able to get your monies worth out of all of your air tools
Air Tools & Compressors Logo
iomega doent save a lot of data
Im not sure i understand your problem
(it uploads firs at 43 mb but then get lower and lower to 2 mb or lower and i cant never put alot of space in the moment)
you might have to add the downoad to a zip file
defragment your usb drive to regain space
are you uploading from a disk
downloading from the internet
Dec 23, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
Blowing warm air and making buzzing(error sound) every 20 to 30 seconds.
This is more than likely a blowen capator. Seen alot of these this year. I hope this helps
Aug 25, 2011 | Whirlpool Heating & Cooling
Have an approx 20 year old Honeywell ducted air conditioning unit in my just purchased villa. It is not working. Am having trouble finding someone to quote to repair it. I live in the southern suburbs of Sydney. Any suggestions? Thank You! Linda
If its 20 years old it would benefit you much more to replace it, see the energy star website and it has information on when replacement is the best solution. Over 10 is the general rule of thumb if it over 10 then replacing the equipment will benefit you so much more than a repair. Also honeywell doesn't make equipment anymore and i cant say vie seen one but that doesn't mean its not out there, vie seen Chrysler air conditioners in houses and honeywell dose make controls but not equipment anymore (in fact this is the first honeywell unit vie heard of).
Oct 01, 2010 | Honeywell Heating & Cooling
I have a problem at the moment when I excelerate it is missing alot, then drives ok, mainly happens when approaching hills, does anyone no what this could be? It is very much due for its 100km service, now engine light has come and it is worse once car has warmed up a bit worried it maybe major car not even 4 years old!
Have the codes pulled from a parts store and post the results. May not be anything major but need to see what the codes say. That is why the service engine light is on. There was a problem that the computer has seen and turned the light on to inform you that there is a code set. The parts store doesn't generally charge you anything to pull them.
Nov 25, 2009 | 2006 Subaru Impreza
920 people viewed this tip
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
