Tip & How-To about Toastess The Storm Electric Kettle
Kettle stoped working...
After the warranty was over, our beautiful electric kettle just stopped working.
Toastess International Kettle
Model: TJK-103 120V, 60 Hz, 1500 W
Here is what I did to fix the problem.
Unplug the kettle and empty it completely.
Remove excess residual water inside.
Remove the bottom cover by removing the screws holding it.
Check the wires inside, the ones connected to the heat element.
On our kettle, one of them was completely burned off and disconnected.
So I replaced it with a heavy duty equivalent copper wire and sauder it in place.
Make sure that you do a good job installing and replacing the new copper wire.
Kettle is now fixed and working perfectly.
Toastess The Storm Electric Kettle Logo
russell hobbs problems
Hi Naomi,
please check the manual.and see if it is has a small hole or opening in kettle to go to outside of steam.
your one must be blocked .
regards.
nuwan
Jan 13, 2014 | Toastess Cordless Electric Glass Kettle...
Need a manual for TJK-319 manual
It's an old product, but most of the manuals of Toastess Kettle are very much alike:http://toastess.com/products/manuals
or email info@toastess.com to get one by mail
Dec 08, 2011 | Toastess TJK-319 Cordless Electric Kettle
Paper Shredder problem Royal JMD500 paper shredder makes a banging noise and paper only shreds about 1 inch in and then stops. You must put machine in reverse to take paper out.
Sounds like shreddder gears are not staying aligned or somethhing is caught in the cutters.
The shredder has a sensor to detect when somethine is insert. Hol the sensor swith down and check for paper clips or staples in the roller/shredding teath. Good Luck and use a match book on the switch to wedge it..
Sep 16, 2009 | Toastess International PV434995 Electric...
1,911 people viewed this tip
Top Toastess Kitchen Appliances - Others Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
