Tip & How-To about Computers & Internet
Most Often Used Keyboard Shortcuts.
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system.
Windows key + R = Run menu
Some More RUN menu Commands.
cmd = Command Prompt
  1. iexplore + "web address" = Internet Explorer
  2. compmgmt.msc = Computer Management
  3. dhcpmgmt.msc = DHCP Management
  4. dnsmgmt.msc = DNS Management
  5. services.msc = Services
  6. eventvwr = Event Viewer
  7. dsa.msc = Active Directory Users and Computers
  8. dssite.msc = Active Directory Sites and Services
  9. devmgmt.msc = Device Manager
  10. msinfo32 = System Information
  11. cleanmgr = Disk Cleanup
  12. ntbackup = Backup or Restore Wizard (Windows Backup Utility)
  13. mmc = Microsoft Management Console
  14. excel = Microsoft Excel (If Installed)
  15. msaccess = Microsoft Access (If Installed)
  16. powerpnt = Microsoft PowerPoint (If Installed)
  17. winword = Microsoft Word (If Installed)
  18. frontpg = Microsoft FrontPage (If Installed)
  19. notepad = Notepad
  20. wordpad = WordPad
  21. calc = Calculator
  22. msmsgs = Windows Messenger
  23. mspaint = Microsoft Paint
  24. wmplayer = Windows Media Player
  25. rstrui = System Restore
  26. netscp6 = Netscape 6.x
  27. netscp = Netscape 7.x
  28. netscape = Netscape 4.x
  29. waol = America Online
  30. control = Opens the Control Panel
  31. control printers = Opens the Printers Dialog
ALT + Tab = Switch between windows
ALT, Space, X = Maximize window
CTRL + Shift + Esc = Task Manager
Windows key + Break = System properties
Windows key + F = Search
Windows key + D = Hide/Display all windows
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Will add some more soon .. Hope its helpful for you guys.
Computers & Internet Logo
how do I progam the programmable keys
I was going to type this out but found the help on logitec is pictorial and might make more sense ;-]
Q: Customizing my S 510 Keyboard Function Keys with Logitech software (SetPoint) trnsp.gif 1954.1.0.jpg How do I use Logitech's Mouse and Keyboard software (SetPoint) to customize my S 510 keyboard Function Keys?
Cordless Desktop S 510
Model Number:
Y-RAK73 (Keyboard)
M-RBN114 or M-RBG114 (Mouse)
trnsp.gif The Function Keys, or F-Keys, are the keys on labelled F1 through F12 above the number keys.
NOTE: To use the programmed F-Key, make sure to toggle on Enhanced F Keys Mode by pressing the F Mode key. The F Mode LED on the receiver will be off in Enhanced F Keys Mode.
11994.1.0.jpg Similar to the Programmable Keys, the F-Keys can also be programmed to perform certain functions.
  1. Click the My Keyboard tab on the top of the screen and select the Keyboard F Key Settings tab on the left.
  2. Select the F key you wish to customize.
  3. Now select the task you want the button to perform under Select Task. You can also click Help to find detailed descriptions of these options.
  4. Click on Apply then click on OK to close SetPoint.
May 04, 2010 | Logitech Cordless Desktop S 510
How do I change www, mail, and search buttons on
Using Logitech's mouse and keyboard software called SetPoint, you can configure and customize your devices to perform specific tasks with a simple keystroke. Depending on the available features of your device, Some examples of SetPoint customization options are:
  • Configure specific button behavior
  • Configure button functionality in specific applications
  • Customize scroll wheel options
  • Adjust pointer options
  • Assign preset keys to perform specific tasks
  • Assign F keys to perform a specific task
HERE is a link to the SetPoint software. Remember to select the correct Operating System
Apr 14, 2010 | Logitech Deluxe Access Keyboard
My optical mouse has started exhibiting problems that are best described as slow to respond to clicks. Also noticed tabs in google chrome stick to the mouse once clicked.
Try taking a can of compressed air (can be found at Walmart for pretty cheap) and blowing out any debris located under the buttons of the mouse. Sounds like the contacts are sticking in the mouse.
You may also check to see if you have processes on the computer that are causing it to slow down. You can right-click on your task bar alone the bottom of the screen, select Task Manager, and click the performance tab to see if you're using a lot of resources.
Nov 25, 2009 | Logitech Cordless Mouse
Must turn off after each use because of batteries?
No, that is not true. The batteries will last a long time in the keyboard and mouse. I use rechargeable batteries in mine and don't have to change them out for 6 months or so. If you installed the Logitech software for the mouse and keyboard, you should get a notification in your task bar (near the clock) that will tell you when the batteries are getting low. Hope this helps.
Apr 30, 2009 | Logitech Wireless Access Duo Optical...
145 people viewed this tip
David Payne
David Payne
